重要提示
社区使用指南—如何添加标签修改密码
已解决 运行自己编写的代码时出现Could not find parameter robot_description_semantic and did……问题
@小鱼 嗯嗯,辛苦小鱼了,我明天再尝试下反馈结果
@空白 好的,保持沟通,应该不是大问题
@小鱼 小鱼,我改了publish_robot_description后问题更大了,连节点启动move_group都出问题了
[robot_state_publisher-4] Error: No name given for the robot. [robot_state_publisher-4] at line 118 in ./urdf_parser/src/model.cpp [robot_state_publisher-4] Failed to parse robot description using: urdf_xml_parser/URDFXMLParser [robot_state_publisher-4] terminate called after throwing an instance of 'std::runtime_error' [robot_state_publisher-4] what(): Unable to initialize urdf::model from robot description [rviz2-2] Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway. [move_group-1] [WARN] [1670671365.891849812] [move_group.move_group]: Falling back to using the the move_group node namespace (deprecated behavior). [move_group-1] Error: No name given for the robot. [move_group-1] at line 118 in ./urdf_parser/src/model.cpp [move_group-1] Failed to parse robot description using: urdf_xml_parser/URDFXMLParser [move_group-1] [INFO] [1670671365.916302193] [moveit_rdf_loader.rdf_loader]: Unable to parse URDF [move_group-1] [ERROR] [1670671365.927268512] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Robot model not loaded [move_group-1] [ERROR] [1670671365.927441140] [moveit.ros_planning_interface.moveit_cpp]: Planning scene not configured [move_group-1] [FATAL] [1670671365.927454969] [moveit.ros_planning_interface.moveit_cpp]: Unable to configure planning scene monitor [move_group-1] terminate called after throwing an instance of 'std::runtime_error' [move_group-1] what(): Unable to configure planning scene monitor [move_group-1] Stack trace (most recent call last): [move_group-1] #12 Object "", at 0xffffffffffffffff, in [move_group-1] #11 Object "/home/pan/moveit2_ws/install/moveit_ros_move_group/lib/moveit_ros_move_group/move_group", at 0x5637b9e6aea4, in _start [move_group-1] #10 Source "../csu/libc-start.c", line 392, in __libc_start_main_impl [0x7f67aac07e3f] [move_group-1] #9 Source "../sysdeps/nptl/libc_start_call_main.h", line 58, in __libc_start_call_main [0x7f67aac07d8f] [move_group-1] #8 Object "/home/pan/moveit2_ws/install/moveit_ros_move_group/lib/moveit_ros_move_group/move_group", at 0x5637b9e6a1e3, in main [move_group-1] #7 Object "/home/pan/moveit2_ws/install/moveit_ros_planning/lib/libmoveit_cpp.so.2.5.4", at 0x7f67ab5cc11b, in moveit_cpp::MoveItCpp::MoveItCpp(std::shared_ptr<rclcpp::Node> const&, moveit_cpp::MoveItCpp::Options const&) [clone .cold] [move_group-1] #6 Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30", at 0x7f67aaed4517, in __cxa_throw [move_group-1] #5 Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30", at 0x7f67aaed42b6, in std::terminate() [move_group-1] #4 Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30", at 0x7f67aaed424b, in [move_group-1] #3 Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30", at 0x7f67aaec8bbd, in [move_group-1] #2 Source "./stdlib/abort.c", line 79, in abort [0x7f67aac067f2] [move_group-1] #1 Source "../sysdeps/posix/raise.c", line 26, in raise [0x7f67aac20475] [move_group-1] #0 | Source "./nptl/pthread_kill.c", line 89, in __pthread_kill_internal [move_group-1] | Source "./nptl/pthread_kill.c", line 78, in __pthread_kill_implementation [move_group-1] Source "./nptl/pthread_kill.c", line 44, in __pthread_kill [0x7f67aac74a7c] [move_group-1] Aborted (Signal sent by tkill() 2895 1000) [rviz2-2] [INFO] [1670671366.652270025] [rviz2]: Stereo is NOT SUPPORTED [rviz2-2] [INFO] [1670671366.652369356] [rviz2]: OpenGl version: 4.3 (GLSL 4.3) [rviz2-2] [INFO] [1670671366.665326153] [rviz2]: Stereo is NOT SUPPORTED [rviz2-2] Warning: class_loader.impl: SEVERE WARNING!!! A namespace collision has occurred with plugin factory for class rviz_default_plugins::displays::InteractiveMarkerDisplay. New factory will OVERWRITE existing one. This situation occurs when libraries containing plugins are directly linked against an executable (the one running right now generating this message). Please separate plugins out into their own library or just don't link against the library and use either class_loader::ClassLoader/MultiLibraryClassLoader to open. [rviz2-2] at line 253 in /opt/ros/humble/include/class_loader/class_loader/class_loader_core.hpp [ERROR] [robot_state_publisher-4]: process has died [pid 2901, exit code -6, cmd '/opt/ros/humble/lib/robot_state_publisher/robot_state_publisher --ros-args -r __node:=robot_state_publisher --params-file /tmp/launch_params_srky38s1']. [ERROR] [move_group-1]: process has died [pid 2895, exit code -6, cmd '/home/pan/moveit2_ws/install/moveit_ros_move_group/lib/moveit_ros_move_group/move_group --ros-args --params-file /tmp/launch_params_cz20p03m --params-file /tmp/launch_params_ct3y8_i6 --params-file /tmp/launch_params_0ortefko --params-file /tmp/launch_params_t6ts9z45 --params-file /tmp/launch_params_camlgkvc --params-file /tmp/launch_params_2sclyplm --params-file /tmp/launch_params_qhbrrs6c']. [rviz2-2] [ERROR] [1670671369.787600339] [moveit_ros_visualization.motion_planning_frame]: Action server: /recognize_objects not available [rviz2-2] [INFO] [1670671369.798753966] [moveit_ros_visualization.motion_planning_frame]: MoveGroup namespace changed: / -> . Reloading params. [rviz2-2] Error: No name given for the robot. [rviz2-2] at line 118 in ./urdf_parser/src/model.cpp [rviz2-2] Failed to parse robot description using: urdf_xml_parser/URDFXMLParser [rviz2-2] [INFO] [1670671369.858143117] [moveit_rdf_loader.rdf_loader]: Unable to parse URDF [rviz2-2] [ERROR] [1670671369.864293830] [moveit_ros.planning_scene_monitor.planning_scene_monitor]: Robot model not loaded r
具体原因不知道为啥,不过我看moveit2_tutorials里面关于robot_model部分确实是需要设置publish_robot_description部分的,现在基本上部分功能包废掉了,打算重新弄个
@小鱼 最终解决了,思路还是在publish部分设置为true就可以,后面的报错和问题无关,其实是在尝试的过程中修改了太多文件乱了,重新回档后修改了launch的参数即可。谢谢小鱼了
@空白 你好,请问你是怎么解决的,publish部分是指哪个文件啊
@空白 你好,publish你是指的哪个文件呢
@zhuq97 你好,请问您解决了吗,我也遇到类似的问题
请问您说的publish指的是哪块的呢
@小鱼 鱼哥,这个问题我还是存在,看你们交流了很多,还是没有给出解决方案啊,哪个publish没说是哪个啊,这问题困扰好久了。可以指明详细一点吗?
er
[ERROR] [1659434560.178463185] [moveit_ur_test]: Could not find parameter robot_description_semantic and did not receive robot_description_semantic via std_msgs::msg::String subscription within 10.000000 seconds. Error: Could not parse the SRDF XML File. Error=XML_ERROR_EMPTY_DOCUMENT ErrorID=13 (0xd) Line number=0 at line 715 in /home/******/ws_moveit2/src/srdfdom/src/model.cpp [ERROR] [1659434560.193027035] [moveit_rdf_loader.rdf_loader]: Unable to parse SRDF [FATAL] [1659434560.193493008] [move_group_interface]: Unable to construct robot model. Please make sure all needed information is on the parameter server. terminate called after throwing an instance of 'std::runtime_error' what(): Unable to construct robot model. Please make sure all needed information is on the parameter server. [ros2run]: Aborted -
@3226860024 在 运行自己编写的代码时出现Could not find parameter robot_description_semantic and did……问题 中说:
这个话题的内容是text格式的URDF文件,一般的名字都叫robot_description,你注意下你系统里有没有robot_description话题,内容对不对,已经它要的这个话题有没有发布,发布的内容是什么
