    ros2,colcon build 报错
    ros2 colcon
    • 24491549692
      纯纯牛马小卢
      By not providing "Findexample_ros2_interfaces.cmake" in CMAKE_MODULE_PATH
      this project has asked CMake to find a package configuration file provided
      by "example_ros2_interfaces", but CMake did not find one.
      "example_ros2_interfaces" with any of the following names:
      example_ros2_interfacesConfig.cmake
      example_ros2_interfaces-config.cmake
      Add the installation prefix of "example_ros2_interfaces" to
      CMAKE_PREFIX_PATH or set "example_ros2_interfaces_DIR" to a directory
      containing one of the above files. If "example_ros2_interfaces" provides a
      separate development package or SDK, be sure it has been installed.
      LorryL 1 条回复 最后回复 回复 引用 0
      • LorryL
        Lorry @2449154969
        @2449154969 在 ros2,colcon build 报错 中说:
        你当前的环境变量没有example_ros2_interfaces这个包,把那个包激活以后再编译
        1 条回复 最后回复 回复 引用 1
