    ros2 nav2 bt_navigator-7 process has died
    Nav2
    ros2 ros2 rviz2
    2.7k
    • 运动男孩运
      运动男孩
      您好,我跑实际机器人导航,跑的是turtlebot3的源码,加载自己的地图,遇到下面的问题,地图能加载,但是没有出现global costmap 和local costmap。检查过雷达数据和历程计的数据都没有问题,使用cartographer能建图。请问一下还有什么其他的原因会出现这种情况呢?非常期待您的帮助,谢谢
        小鱼 技术大佬 @运动男孩
        @运动男孩 ros还是tos2?
        运动男孩运 1 条回复 最后回复 回复 引用 0
        • 运动男孩运
          运动男孩 @小鱼
          @小鱼 不好意思,之前没有说清楚,是ROS2,导航的时候报下面的错误
          [rviz2-10] [WARN] [1672714773.264824298] [rcl.logging_rosout]: Publisher already registered for provided node name. If this is due to multiple nodes with the same name then all logs for that logger name will go out over the existing publisher. As soon as any node with that name is destructed it will unregister the publisher, preventing any further logs for that name from being published on the rosout topic.
          [rviz2-10] [ERROR] [1672714773.352966602] [rviz2]: Vertex Program:rviz/glsl120/indexed_8bit_image.vert Fragment Program:rviz/glsl120/indexed_8bit_image.frag GLSL link result :
          [rviz2-10] active samplers with a different type refer to the same texture image unit
          [ERROR] [bt_navigator-7]: process has died [pid 2818, exit code -6, cmd '/home/longto/tb2_ws/install/nav2_bt_navigator/lib/nav2_bt_navigator/bt_navigator --ros-args -r __node:=bt_navigator --params-file /tmp/tmp6wu_tntj -r /tf:=tf -r /tf_static:=tf_static'].
          LorryL 1 条回复 最后回复 回复 引用 0
          • LorryL
            Lorry @运动男孩
            @运动男孩 你可以先查看一下tf树是否正确
            • 运动男孩运
              运动男孩 @Lorry
              @Lorry 不好意思,打扰了。我重新下载代码,编译之后就没问题了。
