    编译时colcon build 报stderr错误
    ros2 stderr错误 colcon build
    523
    • Z
      zyg_sddy
      这个是我编写的服务端代码
      #include "rclcpp/rclcpp.hpp"
      #include "underwater_interfaces/srv/jointvalue.hpp"
      class Joint_value: public rclcpp::Node
          private:
              rclcpp::Service<underwater_interfaces::srv::Jointvalue>::SharedPtr joint_value_calculate;
              void Joint_calculate01(const underwater_interfaces::srv::Jointvalue::Request::SharedPtr request,
                                     const underwater_interfaces::srv::Jointvalue::Response::SharedPtr response)
                  RCLCPP_INFO(this->get_logger(),"Joint calcuater started!");
                  response->joint0=77.66;
                  response->joint1=77.66;
                  response->joint2=77.66;
                  response->joint3=77.66;
          public:
              Joint_value(std::string name): Node (name)
                  RCLCPP_INFO(this->get_logger(),"Joint_value service is started!");
                  joint_value_calculate = this->create_service<underwater_interfaces::srv::Jointvalue>("joint_value_calculater",
        std::bind(&Joint_value::Joint_calculate01,this,
        std::placeholders::_1,std::placeholders::_2));
      int main(int argc ,char  **argv)
          rclcpp::init(argc,argv);
          auto node=std::make_shared<rclcpp::Node>("joint_value_calculate");
          RCLCPP_INFO(node->get_logger(),"joint_value_calculate started!");
          rclcpp::spin(node);
          rclcpp::shutdown();
          return 0;
      报错如下:
      stderr: robot_joint
      /home/mansenjoy/robot/src/robot_joint/src/robot_joint.cpp: In member function ‘void Joint_value::Joint_calculate01(underwater_interfaces::srv::Jointvalue_Request_<std::allocator<void> >::SharedPtr, underwater_interfaces::srv::Jointvalue_Response_<std::allocator<void> >::SharedPtr)’:
      自定义的接口
      float32 x
      float32 y
      float32 z
      float32 joint0
      float32 joint1
      float32 joint2
      float32 joint3
        小鱼 技术大佬 @zyg_sddy
        @zyg_sddy 给一下完整的错误,有些错误没关系,你给的信息不太全
        Z 1 条回复 最后回复 回复 引用 0
        • Z
          zyg_sddy @小鱼
          @小鱼 我看了,底下是一个警告,警告我在服务的回调函数里定义了request但是没有调用,然后我调用了以后上面的stderr错误也没了,我又尝试了定义别的变量不引用,也会报这个错误。
            小鱼 技术大佬 @zyg_sddy
            @zyg_sddy 可以在不用的变量前加个void,即
            (void)xxxx;
            • Z
              zyg_sddy @小鱼
              @小鱼 好的谢谢
