    roscore无法运行
    ubuntu20.04 ros noetic
    2.1k
    • 无妄无
      无妄
      wzy@wzy-KLVC-WXX9:~$ roscore
      WARNING: unable to configure logging. No log files will be generated
      Checking log directory for disk usage. This may take awhile.
      Press Ctrl-C to interrupt
      Resource not found: roslaunch
      The traceback for the exception was written to the log file
      File "/usr/lib/python3/dist-packages/roslaunch/init.py", line 322, in main
      p.start()
      File "/usr/lib/python3/dist-packages/roslaunch/parent.py", line 277, in start
      self._start_infrastructure()
      File "/usr/lib/python3/dist-packages/roslaunch/parent.py", line 226, in _start_infrastructure
      self._load_config()
      File "/usr/lib/python3/dist-packages/roslaunch/parent.py", line 137, in _load_config
      self.config = roslaunch.config.load_config_default(self.roslaunch_files, self.port,
      File "/usr/lib/python3/dist-packages/roslaunch/config.py", line 447, in load_config_default
      load_roscore(loader, config, verbose=verbose)
      File "/usr/lib/python3/dist-packages/roslaunch/config.py", line 92, in load_roscore
      f_roscore = get_roscore_filename()
      File "/usr/lib/python3/dist-packages/roslaunch/config.py", line 84, in get_roscore_filename
      return os.path.join(r.get_path('roslaunch'), 'resources', 'roscore.xml')
      File "/usr/lib/python3/dist-packages/rospkg/rospack.py", line 207, in get_path
      raise ResourceNotFound(name, ros_paths=self._ros_paths)
      rospkg.common.ResourceNotFound: roslaunch
        小鱼 技术大佬 @无妄
        @无妄
        • 无妄无
          无妄
          过一段时间不用ros后,再运行roscore后出现了报错
            小鱼 技术大佬 @无妄
            @无妄 😂 系统版本?ROS版本?是否尝试重装?
              我要打开机械臂的urdf模型,出现这样的情况:
              ros@ros-virtual-machine:~/ws_rmrobot$ roslaunch rm_65_description display.launch
              ... logging to /home/ros/.ros/log/d1d2da90-bb76-11ee-8b04-75a2d050c8aa/roslaunch-ros-virtual-machine-6789.log
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/init.py", line 347, in main
              p.start()
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/parent.py", line 305, in start
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/parent.py", line 254, in _start_infrastructure
              self._load_config()
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/parent.py", line 156, in _load_config
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/config.py", line 461, in load_config_default
              loader.load(f, config, argv=args, verbose=verbose)
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/xmlloader.py", line 761, in load
              self._load_launch(launch, ros_config, is_core=core, filename=filename, argv=argv, verbose=verbose)
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/xmlloader.py", line 733, in _load_launch
              self._recurse_load(ros_config, launch.childNodes, self.root_context, None, is_core, verbose)
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/xmlloader.py", line 679, in _recurse_load
              self._param_tag(tag, context, ros_config, verbose=verbose)
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/xmlloader.py", line 96, in call
              return f(*args, **kwds)
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/xmlloader.py", line 271, in _param_tag
              value = self.param_value(verbose, name, ptype, *vals)
              File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/loader.py", line 478, in param_value
              with open(textfile, 'r') as f:
              FileNotFoundError: [Errno 2] No such file or directory: '/home/ros/ws_rmrobot/src/rm_robot/rm_65_description/robots/rm_65_description.urdf'
                1615798592 @1615798592
                @1615798592 我的是ros noetic版本
