    fish_protocol串口使用问题
    ros2 fishprotocol 串口
    • 31520790703
      fish_protocol
      里面的普通串口如何在节点里面创建而且在话题回调里面调用发送啊
      • senS
        Sen @小鱼
        @小鱼 @3152079070 之前的仓库已无法访问,小鱼串口文件没办法上传附件我直接贴在下面,这个串口文件目前只有串口,没有了tcp、udp等功能,酌情使用。```
        proto_utils.cpp
         * @brief 文件描述:协议处理工具,打印、crc、转义与反转义
         * @author 小鱼 (fishros@foxmail.com)
         * @version V1.0.0
         * @date 2022-07-17
         * @copyright 版权所有:FishBot Open Source Organization
        #include "fish_protocol/protocol_util.h"
        #include <iostream>
        namespace fish_protocol {
        using namespace std;
        // ------------------------查表法crc8校验-------
        static const uint8_t  crc8tab[] =
        {0x00,0x5e,0xbc,0xe2,0x61,0x3f,0xdd,0x83,0xc2,0x9c,0x7e,0x20,0xa3,0xfd,0x1f,0x41,
        0x9d,0xc3,0x21,0x7f,0xfc,0xa2,0x40,0x1e,0x5f,0x01,0xe3,0xbd,0x3e,0x60,0x82,0xdc,
        0x23,0x7d,0x9f,0xc1,0x42,0x1c,0xfe,0xa0,0xe1,0xbf,0x5d,0x03,0x80,0xde,0x3c,0x62,
        0xbe,0xe0,0x02,0x5c,0xdf,0x81,0x63,0x3d,0x7c,0x22,0xc0,0x9e,0x1d,0x43,0xa1,0xff,
        0x46,0x18,0xfa,0xa4,0x27,0x79,0x9b,0xc5,0x84,0xda,0x38,0x66,0xe5,0xbb,0x59,0x07,
        0xdb,0x85,0x67,0x39,0xba,0xe4,0x06,0x58,0x19,0x47,0xa5,0xfb,0x78,0x26,0xc4,0x9a,
        0x65,0x3b,0xd9,0x87,0x04,0x5a,0xb8,0xe6,0xa7,0xf9,0x1b,0x45,0xc6,0x98,0x7a,0x24,
        0xf8,0xa6,0x44,0x1a,0x99,0xc7,0x25,0x7b,0x3a,0x64,0x86,0xd8,0x5b,0x05,0xe7,0xb9,
        0x8c,0xd2,0x30,0x6e,0xed,0xb3,0x51,0x0f,0x4e,0x10,0xf2,0xac,0x2f,0x71,0x93,0xcd,
        0x11,0x4f,0xad,0xf3,0x70,0x2e,0xcc,0x92,0xd3,0x8d,0x6f,0x31,0xb2,0xec,0x0e,0x50,
        0xaf,0xf1,0x13,0x4d,0xce,0x90,0x72,0x2c,0x6d,0x33,0xd1,0x8f,0x0c,0x52,0xb0,0xee,
        0x32,0x6c,0x8e,0xd0,0x53,0x0d,0xef,0xb1,0xf0,0xae,0x4c,0x12,0x91,0xcf,0x2d,0x73,
        0xca,0x94,0x76,0x28,0xab,0xf5,0x17,0x49,0x08,0x56,0xb4,0xea,0x69,0x37,0xd5,0x8b,
        0x57,0x09,0xeb,0xb5,0x36,0x68,0x8a,0xd4,0x95,0xcb,0x29,0x77,0xf4,0xaa,0x48,0x16,
        0xe9,0xb7,0x55,0x0b,0x88,0xd6,0x34,0x6a,0x2b,0x75,0x97,0xc9,0x4a,0x14,0xf6,0xa8,
        0x74,0x2a,0xc8,0x96,0x15,0x4b,0xa9,0xf7,0xb6,0xe8,0x0a,0x54,0xd7,0x89,0x6b,0x35};
        uint8_t getcrc8tab(const uint8_t *buf, int len) {
          uint8_t crc = 0x00;
          while(len--)
            crc = crc8tab[crc ^ *buf++];
          return crc;
        函数功能:直接计算法获得8位循环冗余校验值
        入口参数:数组地址、长度
        出口参数:校验值
        uint8_t getCrc8(uint8_t *ptr, uint16_t len)
            uint8_t crc, i;
            crc = 0;
            while(len--)
                crc ^= *ptr++;
                for(i = 0; i < 8; i++)
                    if(crc&0x01)
                        crc=(crc>>1)^0x8C;
                    else
                        crc >>= 1;
            return crc;
        int frame_packing(const uint8_t *buf, uint8_t *frame, uint8_t len, uint8_t func) {
            uint8_t cnt = 0;
            frame[cnt++] = FIRST_CODE;
            frame[cnt++] = func;
            frame[cnt++] = len;
            for (int i = 0; i < len; i++) {
                frame[cnt++] = buf[i];
            frame[cnt++] = getcrc8tab(buf, len);
            frame[cnt++] = END_CODE;
            return cnt;
        int inverse_frame(uint8_t *result, const uint8_t *frame, uint8_t len, uint8_t& func) {
            if((frame[0] != FIRST_CODE) || (frame[len - 1] != END_CODE))//  检查帧头帧尾
                return 0;
            for(int i = 3; i < len-2; i++)
                result[i - 3] = frame[i];
            if(getcrc8tab(result, frame[2]) != frame[len - 2])//    检查crc8校验
                return 0;
            func = frame[1];
            return frame[2];
        }  // namespace fish_protocol
        serial_protocol.cpp
         * @brief 文件描述:待完善
         * @version V1.0.0
         * @date 2022-07-24
         * @copyright 版权所有:(鱼香ROS)fishros.org.cn
        #include "fish_protocol/serial_protocol.h"
        namespace serial_protocol {
        /// @brief Flush a serial port's buffers.
        /// @param serial_port Port to flush.
        /// @param what Determines the buffers to flush.
        /// @param error Set to indicate what error occurred, if any.
        void SerialProtocol::flush_serial_port(
                boost::asio::serial_port& serial_port,
                flush_type what,
                boost::system::error_code& error)
            if (0 == ::tcflush(serial_port.lowest_layer().native_handle(), what))
                error = boost::system::error_code();
            else
                error = boost::system::error_code(errno,
                    boost::asio::error::get_system_category());
        SerialProtocol::~SerialProtocol()
            io_service_.stop();
            serial_port_.cancel();
            serial_port_.close();
        void SerialProtocol::_initSerialProtocol() {
            boost::system::error_code ec;
            try
                serial_port_.open(protocol_config_.serial_address_, ec);
                if(!serial_port_.is_open())
                    throw ec;
            catch(boost::system::error_code& ec)
                std::cout << ec.message() << std::endl;
                return ;
            std::cout << "串口已打开:" << protocol_config_.serial_address_ << std::endl;
            serial_port_.set_option(spb::baud_rate(protocol_config_.serial_baut_));
            serial_port_.set_option(spb::character_size(8));
            serial_port_.set_option(spb::stop_bits(spb::stop_bits::one));
            serial_port_.set_option(spb::parity(spb::parity::none));
            serial_port_.set_option(spb::flow_control(spb::flow_control::none));
            boost::thread td(boost::bind(&boost::asio::io_service::run, &io_service_));
            _asyncReadSomeData();
        void SerialProtocol::_recvDataCallback(const boost::system::error_code& error,
                                                size_t bytes_transferred) {
            if (bytes_transferred > 0) {
                // 回调数据
                if(recv_uint8_callback)
                    recv_uint8_callback(recv_data_buffer_, bytes_transferred);
        void SerialProtocol::_asyncReadSomeData() {
            serial_port_.async_read_some(
                boost::asio::buffer(recv_data_buffer_, sizeof(recv_data_buffer_)),
                boost::bind(&SerialProtocol::_recvDataCallback, this,
                            boost::placeholders::_1, boost::placeholders::_2));
        int SerialProtocol::ProtocolSendString(const std::string& data) {
            serial_port_.write_some(boost::asio::buffer(data.data(), data.size()));
            return 0;
        int SerialProtocol::ProtocolSenduint8_t(const std::uint8_t* data, const std::uint8_t len) {
            serial_port_.write_some(boost::asio::buffer(data, len));
            return 0;
        void SerialProtocol::SetDataRecvCallback(
                std::function<void(const std::uint8_t*, const std::uint8_t)> callback) {
            recv_uint8_callback = callback;
        protocol_util.h
         * @brief 文件描述:待完善
         * @version V1.0.0
         * @date 2022-07-24
        #ifndef _FISH_PROTOCOL_PROTO_UTIL_H_
        #define _FISH_PROTOCOL_PROTO_UTIL_H_
        #include <cstdint>
        #include <cstdio>
        #define FIRST_CODE 0x55
        #define END_CODE 0xBB
         * @brief 截取指定位数据并赋值
         *        小端模式: 高位在前(低内存),低位在后(高内存)
        #define SET_SUB_BYTES1(target, data) target = (data & 0xFF)
        #define SET_SUB_BYTES2(target, data) target |= ((data << 8) & 0xFF00)
         * @brief 查表法crc8校验
         * @param buf 输入数组
         * @param len 数组长度
         * @return uint8_t
        uint8_t getcrc8tab(const uint8_t *buf, int len);
         * @brief 直接计算法crc8校验
         * @param buf 输入数组
         * @param len 数组长度
         * @return uint8_t
        uint8_t getCrc8(const uint8_t *buf, int len);
         * @brief 将数据进行转义
         * @param frame 帧数据
         * @param result 结果
         * @param len 长度
         * @return int 转义完成后新的帧的大小
        int frame_packing(const uint8_t *buf, uint8_t *frame, uint8_t len, uint8_t func);
         * @brief 将数据帧进行反转义
         * @param frame 帧数据
         * @param result 结果
         * @param len 长度
         * @return int
        int inverse_frame(uint8_t *result, const uint8_t *frame, uint8_t len, uint8_t& func);
        #endif  // _PROTO_UTILS_H_
        serial_protocol.h
         * @brief 文件描述:待完善
         * @version V1.0.0
         * @date 2022-07-24
        #ifndef _FISH_PROTOCOL_SERIAL_PROTOCOL_H_
        #define _FISH_PROTOCOL_SERIAL_PROTOCOL_H_
        #include <unistd.h>
        #include <boost/asio.hpp>
        #include <boost/bind.hpp>
        #include <boost/system/error_code.hpp>
        #include <boost/system/system_error.hpp>
        #include <boost/thread.hpp>
        #include <iostream>
        #include <string>
        namespace serial_protocol{
        class ProtocolConfig {
         public:
          // serial
          int serial_baut_;
          std::string serial_address_;
          ProtocolConfig& operator=(const ProtocolConfig& config) {
            serial_baut_ = config.serial_baut_;
            serial_address_ = config.serial_address_;
            return *this;
         public:
          ProtocolConfig(){};
          ~ProtocolConfig(){};
        enum flush_type
          flush_receive = TCIFLUSH,
          flush_send = TCOFLUSH,
          flush_both = TCIOFLUSH
        class SerialProtocol{
            using spb = boost::asio::serial_port_base;
        protected:
            std::function<void(const std::uint8_t*, const std::uint8_t)> recv_uint8_callback;
            ProtocolConfig protocol_config_;
        private:
            void _asyncReadSomeData();
            void _initSerialProtocol();
            void _recvDataCallback(const boost::system::error_code& error,
                                size_t bytes_transferred);
            void flush_serial_port(
                    flush_type what,
                    boost::system::error_code& error);
        public:
            SerialProtocol(const ProtocolConfig& protocol_config)
                : io_service_(),
                serial_port_(io_service_) {
                this->protocol_config_ = protocol_config;
            ~SerialProtocol();
            int ProtocolSendString(const std::string& data);
            int ProtocolSenduint8_t(const std::uint8_t* data, const std::uint8_t len);
            void SetDataRecvCallback(std::function<void(const std::uint8_t*, const std::uint8_t)> callback);
        private:
            unsigned char recv_data_buffer_[1024] = {0};
            boost::asio::io_service io_service_;
            boost::asio::serial_port serial_port_;
        #endif  // _FISH_PROTOCOL_SERIAL_PROTOCOL_H_
        1 条回复 最后回复 回复 引用 1
          小鱼 技术大佬 @3152079070
          @3152079070 可以参考开源库中的ros2串口例程,你只需要将对象封装成一个成员变量即可。
          可以参考这位同学的代码:
          @sen 在 使用小鱼的串口代码间歇性串口打开失败 中说:
          这是我的代码的github仓库:https://github.com/SenHe524/AGV.git
          senS 1 条回复 最后回复 回复 引用 0
          • senS
            Sen @小鱼
            proto_utils.cpp
             * @version V1.0.0
             * @date 2022-07-17
            #include <iostream>
              uint8_t crc = 0x00;
              while(len--)
              return crc;
            入口参数:数组地址、长度
            出口参数:校验值
                uint8_t crc, i;
                crc = 0;
                while(len--)
                    crc ^= *ptr++;
                        if(crc&0x01)
                            crc=(crc>>1)^0x8C;
                        else
                            crc >>= 1;
                return crc;
                uint8_t cnt = 0;
                frame[cnt++] = len;
                return cnt;
                    return 0;
                    return 0;
                func = frame[1];
                return frame[2];
            serial_protocol.cpp
             * @brief 文件描述:待完善
             * @version V1.0.0
             * @date 2022-07-24
                    flush_type what,
                else
                io_service_.stop();
                try
                        throw ec;
                    return ;
                    // 回调数据
                return 0;
                return 0;
            protocol_util.h
             * @brief 文件描述:待完善
             * @version V1.0.0
             * @date 2022-07-24
            #include <cstdint>
            #include <cstdio>
             * @brief 截取指定位数据并赋值
             * @brief 查表法crc8校验
             * @param buf 输入数组
             * @param len 数组长度
             * @return uint8_t
             * @param buf 输入数组
             * @param len 数组长度
             * @return uint8_t
             * @brief 将数据进行转义
             * @param frame 帧数据
             * @param result 结果
             * @param len 长度
             * @brief 将数据帧进行反转义
             * @param frame 帧数据
             * @param result 结果
             * @param len 长度
             * @return int
            serial_protocol.h
             * @brief 文件描述:待完善
             * @version V1.0.0
             * @date 2022-07-24
            #include <unistd.h>
            #include <iostream>
            #include <string>
             public:
              // serial
              int serial_baut_;
                return *this;
             public:
              ProtocolConfig(){};
            enum flush_type
            protected:
            private:
                        flush_type what,
            public:
                    : io_service_(),
                ~SerialProtocol();
            private:
            1 条回复 最后回复 回复 引用 1
            • 小鱼小 小鱼 将这个主题标记为已解决,在
