    使用激光雷达和rf2o算法在cartographer建图出现漂移重叠
    cartographer ros2 rf2o 激光雷达
    744
    • 10392910161
      1039291016
      背景:
      最近在搞激光雷达建图,使用的是思岚a2m12激光雷达,然后尝试直接使用单激光雷达建图,发现地图漂移重叠比较严重,查询后得知可能需要里程计来提高精度,但由于我们的小车结构还在改,没确定最后方案,因此使用rf2o算法来获取里程计数据,结果使用过程就出现了两个问题
      首先先将相关代码文件放上来吧
      雷达的launch文件
          ## ***** Launch arguments *****
          use_sim_time_arg = DeclareLaunchArgument('use_sim_time', default_value = 'False')
          ## ***** File paths ******
          pkg_share = FindPackageShare('cartographer_ros').find('cartographer_ros')
          urdf_dir = os.path.join(pkg_share, 'urdf')
          urdf_file = os.path.join(urdf_dir, 'backpack_2d.urdf')
          with open(urdf_file, 'r') as infp:
              robot_desc = infp.read()
          ## ***** Nodes *****
              package = 'robot_state_publisher',
              executable = 'robot_state_publisher',
              parameters=[
                  {'robot_description': robot_desc},
                  {'use_sim_time': LaunchConfiguration('use_sim_time')}],
              output = 'screen'
          cartographer_node = Node(
              package = 'cartographer_ros',
              executable = 'cartographer_node',
              parameters = [{'use_sim_time': LaunchConfiguration('use_sim_time')}],
              arguments = [
                  '-configuration_directory', FindPackageShare('cartographer_ros').find('cartographer_ros') + '/configuration_files',
                  '-configuration_basename', 'backpack_2d.lua'],
              remappings = [('scan','scan'),
                  ('odom','odom_rf2o'),
                  ('odom','odom_rf2o')],#('scan','scan')('odom','/odom_rf2o')('imu','/camera/camera/imu')echoes,horizontal_laser_2d
              output = 'screen'
          # 可视化节点
          rviz_node = Node(
              package='rviz2',
              namespace='rviz2',
              executable='rviz2',
              name='rviz2',
              output='screen')
          cartographer_occupancy_grid_node = Node(
              executable = 'cartographer_occupancy_grid_node',
              parameters = [
                  {'use_sim_time': False},
                  {'resolution': 0.05}],
          return LaunchDescription([
              use_sim_time_arg,
              # Nodes
              robot_state_publisher_node,
              rviz_node,
              cartographer_node,
              cartographer_occupancy_grid_node,
      rf2o的launch文件
                  Node(
                      package='rf2o_laser_odometry',
                      executable='rf2o_laser_odometry_node',
                      name='rf2o_laser_odometry',
                      output='screen',
                      parameters=[{
                          'laser_scan_topic' : '/scan',
                          'odom_topic' : '/odom_rf2o',#/odom_rf2o
                          'publish_tf' : True,
                          'base_frame_id' : 'base_link',
                          'odom_frame_id' : 'odom',
                          'init_pose_from_topic' : '',
                          'freq' : 10.0}],
      cartograoher的launch文件
              parameters=[
              output = 'screen'
              arguments = [
              output = 'screen'
          # 可视化节点
          rviz_node = Node(
              package='rviz2',
              namespace='rviz2',
              executable='rviz2',
              name='rviz2',
              output='screen')
              parameters = [
              use_sim_time_arg,
              # Nodes
              rviz_node,
              cartographer_node,
      cartographer的lua文件
      include "map_builder.lua"
      include "trajectory_builder.lua"
      options = {
        map_builder = MAP_BUILDER,
        trajectory_builder = TRAJECTORY_BUILDER,
        map_frame = "map",
        tracking_frame = "base_link",--camera_imu_optical_frame base_link
        published_frame = "odom",-- laser_frame base_link
        odom_frame = "odom",
        provide_odom_frame = false,
        publish_frame_projected_to_2d = false,
        use_pose_extrapolator = true,
        use_odometry = true,
        use_nav_sat = false,
        use_landmarks = false,
        num_laser_scans = 1,
        num_multi_echo_laser_scans = 0,
        num_subdivisions_per_laser_scan = 1,-- 10
        num_point_clouds = 0,
        lookup_transform_timeout_sec = 0.2,
        submap_publish_period_sec = 0.3,
        pose_publish_period_sec = 5e-3,
        trajectory_publish_period_sec = 30e-3,
        rangefinder_sampling_ratio = 1.,
        odometry_sampling_ratio = 0.5,
        fixed_frame_pose_sampling_ratio = 1.,
        imu_sampling_ratio = 1.,
        landmarks_sampling_ratio = 1.,
      MAP_BUILDER.use_trajectory_builder_2d = true
      TRAJECTORY_BUILDER_2D.num_accumulated_range_data = 35 --10
      TRAJECTORY_BUILDER_2D.min_range = 0.3
      TRAJECTORY_BUILDER_2D.max_range = 8.
      TRAJECTORY_BUILDER_2D.missing_data_ray_length = 5.
      TRAJECTORY_BUILDER_2D.use_imu_data = false
      TRAJECTORY_BUILDER_2D.use_online_correlative_scan_matching = true
      TRAJECTORY_BUILDER_2D.real_time_correlative_scan_matcher.linear_search_window = 0.1
      TRAJECTORY_BUILDER_2D.real_time_correlative_scan_matcher.translation_delta_cost_weight = 10.
      TRAJECTORY_BUILDER_2D.real_time_correlative_scan_matcher.rotation_delta_cost_weight = 1e-1
      POSE_GRAPH.optimization_problem.huber_scale = 1e2
      POSE_GRAPH.optimize_every_n_nodes = 35
      POSE_GRAPH.constraint_builder.min_score = 0.65
      return options
      问题一:
      当我配置好文件然后建图时,cartographer弹出了这样的报错:
      [cartographer_node-3] F0716 14:47:49.030234 58418 map_by_time.h:43] Check failed: data.time > std::prev(trajectory.end())->first (638567092688185279 vs. 638567092688185279)
      [cartographer_node-3] [FATAL] [1721112469.031000008] [cartographer logger]: F0716 14:47:49.000000 58418 map_by_time.h:43] Check failed: data.time > std::prev(trajectory.end())->first (638567092688185279 vs. 638567092688185279)
      [cartographer_node-3] F0716 14:47:49.132308 58386 imu_tracker.cc:67] Check failed: (orientation_ * gravity_vector_).z() > 0. (-nan vs. 0)
      [cartographer_node-3] [FATAL] [1721112469.132508442] [cartographer logger]: F0716 14:47:49.000000 58386 imu_tracker.cc:67] Check failed: (orientation_ * gravity_vector_).z() > 0. (-nan vs. 0)
      [cartographer_node-3] *** Check failure stack trace: ***
      [cartographer_node-3]     @     0x757905eb2b03  google::LogMessage::Fail()
      [cartographer_node-3]     @     0x757905eba9d1  google::LogMessage::SendToLog()
      [cartographer_node-3]     @     0x757905eb27c2  google::LogMessage::Flush()
      [cartographer_node-3]     @     0x757905eb478f  google::LogMessageFatal::~LogMessageFatal()
      [cartographer_node-3]     @     0x62b1b0616669  cartographer::mapping::optimization::OptimizationProblem2D::AddOdometryData()
      [cartographer_node-3]     @     0x62b1b05a4143  _ZNSt17_Function_handlerIFN12cartographer7mapping8WorkItem6ResultEvEZNS1_11PoseGraph2D15AddOdometryDataEiRKNS0_6sensor12OdometryDataEEUlvE_E9_M_invokeERKSt9_Any_data
      [cartographer_node-3]     @     0x62b1b05a3af9  cartographer::mapping::PoseGraph2D::DrainWorkQueue()
      [cartographer_node-3]     @     0x62b1b066fac5  cartographer::common::Task::Execute()
      [cartographer_node-3]     @     0x62b1b0590381  cartographer::common::ThreadPool::DoWork()
      [cartographer_node-3]     @     0x7579052dc253  (unknown)
      [cartographer_node-3]     @     0x757904e94ac3  (unknown)
      [cartographer_node-3]     @     0x757904f26850  (unknown)
      [ERROR] [cartographer_node-3]: process has died [pid 58386, exit code -6, cmd '/home/murphy/fishbot_ws/install/cartographer_ros/lib/cartographer_ros/cartographer_node -configuration_directory /home/murphy/fishbot_ws/install/cartographer_ros/share/cartographer_ros/configuration_files -configuration_basename backpack_2d.lua --ros-args --params-file /tmp/launch_params_fm5bsshm -r scan:=scan -r odom:=odom_rf2o -r odom:=odom_rf2o'].
      这似乎是雷达的scan和rf2o的odom信息转换间的时间戳出现了问题,但网上查询后有一个解决方法,就是将cartographer的luan文件中的参数odometry_sampling_ratio = 1.,,这个odom采样率从1.0降低,降低到0.51左右就不会报错了,但我认为这种方法实际上是丢失了大量的odom信息,值时将原有问题掩盖而已,所以想问问各位是否遇见过这个问题,有没有什么办法解决?
      问题二:
      第二个问题是我在将问题一暂且搁置,采用降低采样率进行建图后出现的问题,就是发现即使加上了里程计,其地图依旧出现漂移和重叠,感觉和没加上odom没有区别,这又是怎么一回事呢?望各位大神解答
      ![地图漂移重叠](07da5451-6cfe-4a36-8fa8-1fdf75d6009d-image.png 图片地址)
      ![tf树](b034bae8-e206-465c-8d6d-9b43a2ff747e-image.png 图片地址)
      ![话题节点订阅关系](55fa3680-35ab-4799-8f1e-5acd0bffafda-image.png 图片地址)
        小鱼 技术大佬 @1039291016
        @1039291016 我之前测试的效果都比较不错,建图的时候旋转要慢一些,也可以试试 slam_toobox 方案
        10392910161 1 条回复 最后回复 回复 引用 0
          针对您遇到的问题,我将分别给出可能的解决方案和建议。
          问题一:时间戳问题
          报错信息表明 Cartographer 在处理来自激光雷达和 RF2O 提供的里程计数据时,时间戳发生了冲突或不一致。map_by_time.h 和 imu_tracker.cc 中的检查失败通常与数据的时间戳处理有关。
          1. 确保时间同步:首先,确保激光雷达和 RF2O 节点都使用相同的时间源(如果可能,使用硬件时间戳)。如果激光雷达和 RF2O 节点运行在仿真中,请确保仿真时间是同步的,并检查 use_sim_time 参数是否正确设置。
          2. 检查时间戳的生成:确保 RF2O 生成的里程计消息的时间戳是递增的,并且与激光雷达扫描的时间戳保持合理的一致性。如果 RF2O 的输出频率远低于激光雷达的扫描频率,可能需要插值或调整时间戳以匹配。
          3. 调整采样率:虽然降低 odometry_sampling_ratio 可以暂时避免错误,但这并不是长期解决方案。考虑在保持精度的同时增加 RF2O 的输出频率,或者对激光雷达数据进行下采样以匹配 RF2O 的频率。
          4. 检查配置参数:确保 Cartographer 的配置文件中其他与时间相关的参数(如 lookup_transform_timeout_sec)设置得当。
          问题二:地图漂移和重叠
          如果在使用里程计数据后仍然出现地图漂移和重叠,这通常是由于以下几个原因:
          1. 里程计精度:RF2O 提供的里程计数据可能不够精确,导致 Cartographer 无法准确估计机器人的位置。考虑使用其他里程计算法或传感器(如 IMU)来提高精度。
          2. 配置问题:检查 Cartographer 的配置文件,特别是与扫描匹配、位姿图优化等相关的参数。可能需要调整这些参数以适应您的具体硬件和环境。
          3. 初始化问题:确保机器人在建图开始前有一个合理的初始位置和朝向。错误的初始位置可能导致整个地图的漂移。
          4. 环境问题:某些环境特征(如重复的结构、缺乏纹理的区域)可能导致扫描匹配失败,从而导致地图漂移。尝试在不同的环境中测试您的系统,并观察是否仍然出现漂移。
          5. TF树和话题关系:确保 TF 树正确设置,并且 Cartographer 节点订阅了正确的里程计和激光雷达话题。您可以使用 rosrun tf view_frames 命令来可视化 TF 树,并使用 rostopic echo 命令来检查话题数据。
          6. 硬件问题:最后,考虑检查激光雷达和里程计传感器的硬件连接和校准。硬件问题(如松动的连接线、传感器故障等)也可能导致地图漂移。
            小鱼 技术大佬 @1039291016
            @1039291016 在 使用激光雷达和rf2o算法在cartographer建图出现漂移重叠 中说:
            rf2o
            使用 rf2o 不如直接用carto纯激光建图
            10392910161 2 条回复 最后回复 回复 引用 0
            • 10392910161
              1039291016 @小鱼
              @小鱼 一开始就是使用carto纯激光建图,但地图也会漂移重叠😢
                小鱼 技术大佬 @1039291016
                • 10392910161
                  1039291016 @小鱼
                  @小鱼 ok,我再试试纯激光建图的方案,还有slam_toolbox的方案有相关教程或者例子吗?想学习一下,感谢小鱼😙
                  • 10392910161
                    1039291016 @小鱼
                    @小鱼 在 使用激光雷达和rf2o算法在cartographer建图出现漂移重叠 中说:
                    rf2o
                    还有想问问为啥不推荐使用rf2o,是因为精度很差吗?
                      小鱼 技术大佬 @1039291016
                      @1039291016 从本质上来讲,并没有增加传感器
                        小鱼 技术大佬 @1039291016
                        @1039291016 直接搜,有很多,社区的fishbot资料中也有
                        • 10392910161
                          1039291016 @小鱼
                          @小鱼 ok,感谢小鱼
                          • 小鱼小 小鱼 将这个主题标记为已解决,在
