    ros2 jazzy 显示没有那个文件或目录
    ros2 rosjazzy ros2编译
    7.1k
    • Z
      zio @zio
      @zio 在 ros2 jazzy 显示没有那个文件或目录 中说:
      各位大佬下午好,新手问题😞 cca78149-5945-4b20-9ac5-bc45b42ff58d-image.png 文件确实在这里(图中方框),路径是直接复制的,但是显示没有那个文件或路径
      之前找别的文件是正常的,就这条指令最后一句一直找不到io@zio-VMware-Virtual-Platform:~/d2lros2/chapt2$ g++ first_ros2_node.cpp \ -I/opt/ros/jazzy/include/rclcpp/
      -I /opt/ros/jazzy/include/rcl/
      -I /opt/ros/jazzy/include/rcutils/
      -I /opt/ros/jazzy/include/rmw
      -I /opt/ros/jazzy/include/rcl_yaml_param_parser/
      -I /opt/ros/jazzy/include/rosidl_runtime_c
      -I /opt/ros/jazzy/include/rosidl_typesupport_interface
      -I /opt/ros/jazzy/include/rcpputils
      -I /opt/ros/jazzy/include/builtin_interfaces
      -I /opt/ros/jazzy/include/rosidl_runtime_cpp
      -I /opt/ros/jazzy/include/tracetools
      -I /opt/ros/jazzy/include/rcl_interfaces
      -I /opt/ros/jazzy/include/libstatistics_collector
      -I /opt/ros/jazzy/include/statistics_msgs \
      -I /opt/ros/jazzy/include/service_msgs/service_msgs/msg/detail
      In file included from /opt/ros/jazzy/include/rcl_interfaces/rcl_interfaces/srv/list_parameters.hpp:7,
      from /opt/ros/jazzy/include/rclcpp/rclcpp/copy_all_parameter_values.hpp:21,
      from /opt/ros/jazzy/include/rclcpp/rclcpp/rclcpp.hpp:171,
      from first_ros2_node.cpp:3:
      /opt/ros/jazzy/include/rcl_interfaces/rcl_interfaces/srv/detail/list_parameters__struct.hpp:267:10: fatal error: service_msgs/msg/detail/service_event_info__struct.hpp: 没有那个文件或目录
      267 | #include "service_msgs/msg/detail/service_event_info__struct.hpp"
      compilation terminated.
      zio@zio-VMware-Virtual-Platform:~/d2lros2/chapt2$ echo $ROS_PACKAGE_PATH
      :/home/siat/ccny/ccny_vision:/home/siat/catkin_ws/src
      Z 1 条回复 最后回复 回复 引用 0
      • Z
        zio @zio
        @zio 已解决
        1 2 条回复 最后回复 回复 引用 0
          1499744277 @zio
          @zio 求解 我也遇到这个问题了
          • Z
            zio @1499744277
            @1499744277 我的问题不一定跟你的相同。路径只到报错那提示的前面一个
              1499744277 @zio
              @zio cfee3632-34a3-48c2-842a-5182480ad226-image.png 我的报错是这个 还不知道怎么解决
              • Z
                zio @1499744277
                @1499744277 未找到命令,应该是你那个-L格式有问题
                  1499744277 @zio
                  @zio 第一个报错一直解决不掉
                  c7356b33-fdde-4eb5-a812-e76eb9b6879f-image.png 后面那个好说 主要是前面的
                  • Z
                    zio @1499744277
                    @1499744277 解决了吗 ,你这是运行命令时的位置错了
                      1499744277 @zio
                      @zio 解决了,虽然报错和小鱼的文章还是不太一样 但是终于是往前走了一步了
                        1499744277 @zio
                        @zio 你这个是咋解决的,马上就遇到你这个问题了🤔
                        Z 2 条回复 最后回复 回复 引用 0
                        • Z
                          zio @1499744277
                          @1499744277 路径到他提示的前面一个就过了
                          • Z
                            zio @1499744277
                            @1499744277 https://fishros.com/d2lros2/#/
                            你可以看这个操作
                              1499744277 @zio
                              @zio 解决了,感激不尽,谢谢你!
                                1499744277 @zio
                                @zio 不好意思,又打扰你了,我现在出现这个报错 而且我文件夹里也找不到这个文件5152b374-d435-4085-b3db-d5dabf38ded8-image.png 小鱼的命令里面我没找到关于这个的。
                                • Z
                                  zio @1499744277
                                  @1499744277 都是一样的解决办法
                                  • A
                                    amazgrace
                                    输入命令如下:
                                    -I /opt/ros/jazzy/include/rclcpp/
                                    -I /opt/ros/jazzy/include/type_description_interfaces
                                    -I /opt/ros/jazzy/include/rosidl_dynamic_typesupport
                                    -I /opt/ros/jazzy/include/rosidl_typesupport_introspection_cpp
                                    -L /opt/ros/jazzy/lib/
                                    -lrclcpp -lrcutils
