    机器人在单点导航时不规划路径
    Nav2
    nav2 导航 ros2
    5.2k
      小鱼 技术大佬 @1814638019
      @1814638019 在 机器人在单点导航时不规划路径 中说:
      [rviz2-2] [INFO] [1722310347.323473487] [rviz2]: NavigateToPose will be called using the BT Navigator's default behavior tree.
      [rviz2-2] [ERROR] [1722310347.323740453] [rviz2]: Goal was rejected by server
      应该还有更进一步的日志信息
      1 2 条回复 最后回复 回复 引用 0
        1814638019 @小鱼
        @小鱼 终端内的能截取到的全部代码
        [component_container_isolated-1] [INFO] [1722328690.796172177] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328690.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328690.796172158] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328690.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328690.862376438] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328690.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328690.862376512] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328690.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328690.929077694] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328690.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328690.929077741] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328690.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328692.926502540] [lifecycle_manager_navigation]: Server behavior_server connected with bond.
        [component_container_isolated-1] [INFO] [1722328692.926562950] [lifecycle_manager_navigation]: Activating bt_navigator
        [component_container_isolated-1] [INFO] [1722328692.926919164] [bt_navigator]: Activating
        [component_container_isolated-1] [ERROR] [1722328692.927391217] [bt_navigator]: Caught exception in callback for transition 13
        [component_container_isolated-1] [ERROR] [1722328692.927425842] [bt_navigator]: Original error: Error at line 12: -> Node not recognized: RemovePassedGoals
        [component_container_isolated-1] [WARN] [1722328692.927490205] [bt_navigator]: Error occurred while doing error handling.
        [component_container_isolated-1] [FATAL] [1722328692.927522578] [bt_navigator]: Lifecycle node bt_navigator does not have error state implemented
        [component_container_isolated-1] [ERROR] [1722328692.927960623] [lifecycle_manager_navigation]: Failed to change state for node: bt_navigator
        [component_container_isolated-1] [ERROR] [1722328692.927993540] [lifecycle_manager_navigation]: Failed to bring up all requested nodes. Aborting bringup.
        [component_container_isolated-1] [INFO] [1722328693.261125604] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328692.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.261125486] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328692.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.328029683] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.328058336] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.394960022] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.395025228] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.461230244] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.461284224] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.528123912] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.528132964] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.595115140] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.595178439] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.661358248] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.661360080] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.728752758] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.728786474] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.795139915] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.795190506] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.862338103] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.862341684] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.929241307] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.929241211] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.996267304] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328693.996277213] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.062965045] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.063067200] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.129994316] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.130068307] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.196350259] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.196350253] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.263199813] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.263200010] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328693.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.329758524] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.329758713] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.396765256] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.396819624] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.462762505] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.462789260] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.529939233] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.530058021] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.596301286] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.596302698] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.663413611] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.663413718] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.730333632] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.730535289] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.796904071] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.796904433] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.863666504] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.863701495] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.929720717] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.929762923] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.996976483] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328694.996983951] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328695.063808607] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328695.063808565] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328695.130950916] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328695.131014258] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328695.197405303] [global_costmap.global_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [component_container_isolated-1] [INFO] [1722328695.197411902] [local_costmap.local_costmap]: Message Filter dropping message: frame 'laser_link' at time 1722328694.000 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
        [rviz2-2] Start navigation
        [rviz2-2] [INFO] [1722328746.600351549] [rviz2]: NavigateToPose will be called using the BT Navigator's default behavior tree.
        [rviz2-2] [ERROR] [1722328746.602093016] [rviz2]: Goal was rejected by server
          1814638019 @小鱼
          @小鱼 感谢您的回复
            小鱼 技术大佬 @1814638019
            问题应该出在这里,你有修改行为树吗
            1 3 条回复 最后回复 回复 引用 0
              1814638019 @小鱼
              @小鱼 没修改过
                1814638019 @小鱼
                @小鱼 从学ros2 那里下载的源码 只修改了fishbot文件夹里面launch和params部分
                  1814638019 @小鱼
                  @小鱼 是这里的代码吗?
                  navigation2/nav2_bt_navigator/behavior_trees navigate_to_pose_w_replanning_goal_patience_and_recovery.xml
                    This Behavior Tree replans the global path periodically at 1 Hz through an array of poses continuously
                     and it also has recovery actions specific to planning / control as well as general system issues.
                  <root main_tree_to_execute="MainTree">
                    <BehaviorTree ID="MainTree">
                      <RecoveryNode number_of_retries="6" name="NavigateRecovery">
                        <PipelineSequence name="NavigateWithReplanning">
                          <RateController hz="0.333">
                            <RecoveryNode number_of_retries="1" name="ComputePathThroughPoses">
                              <ReactiveSequence>
                                <RemovePassedGoals input_goals="{goals}" output_goals="{goals}" radius="0.7"/>
                                <ComputePathThroughPoses goals="{goals}" path="{path}" planner_id="GridBased"/>
                              </ReactiveSequence>
                              <ClearEntireCostmap name="ClearGlobalCostmap-Context" service_name="global_costmap/clear_entirely_global_costmap"/>
                            </RecoveryNode>
                          </RateController>
                          <RecoveryNode number_of_retries="1" name="FollowPath">
                            <FollowPath path="{path}" controller_id="FollowPath"/>
                            <ClearEntireCostmap name="ClearLocalCostmap-Context" service_name="local_costmap/clear_entirely_local_costmap"/>
                          </RecoveryNode>
                        </PipelineSequence>
                        <ReactiveFallback name="RecoveryFallback">
                          <GoalUpdated/>
                          <RoundRobin name="RecoveryActions">
                            <Sequence name="ClearingActions">
                              <ClearEntireCostmap name="ClearLocalCostmap-Subtree" service_name="local_costmap/clear_entirely_local_costmap"/>
                              <ClearEntireCostmap name="ClearGlobalCostmap-Subtree" service_name="global_costmap/clear_entirely_global_costmap"/>
                            </Sequence>
                            <Spin spin_dist="1.57"/>
                            <Wait wait_duration="5"/>
                            <BackUp backup_dist="0.30" backup_speed="0.05"/>
                          </RoundRobin>
                        </ReactiveFallback>
                      </RecoveryNode>
                    </BehaviorTree>
                  </root>
                    小鱼 技术大佬 @1814638019
                    @1814638019 你下载的是哪个版本的
                      1814638019 @小鱼
                        1814638019 @小鱼
                        大佬,我直接用的你的工作空间😏
                          小鱼 技术大佬 @1814638019
                          @1814638019 这个版本我还真不确定能不能用,主要是参数比较老了,nav2在更新,建议手动的按照教程配一遍参数,推荐下新书里的导航配置过程:书籍&社区铭牌购买链接:https://item.taobao.com/item.htm?id=819899547761
