    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    722.7k
      1664486711 @1664486711
        279401783 @948287217
        @948287217 在 [FishBot教程] 6. 雷达驱动及建图测试 中说:
        @小鱼 在 [FishBot教程] 6. 雷达驱动及建图测试 中说:
        ist,查看是否有scan话题。
        找不到/scan的话题
        我也是同样的问题 没有scan 出来 系统是ubuntu24.04 jazzy 版本,这个要怎么解决
          小鱼 技术大佬 @279401783
          @279401783 大概要换系统,或者使用后面的源码方式使用
            3120044269 @小鱼
              请问这个是什么问题呀,出现下面这个错误,已知ping可以正常运行,雷达是转的,跳线帽也是对的,ip地址配置正确,处于RUN MODE模式
              [ydlidar_node-2] [2024-12-22 15:13:32][error] Check Sum 0x4B26 != 0x74C6
              [ydlidar_node-2] [2024-12-22 15:13:32][info] Scan Frequency: 5.00Hz
              [ydlidar_node-2] [2024-12-22 15:13:32][info] Fixed Size: 720
              [ydlidar_node-2] [2024-12-22 15:13:32][info] Sample Rate: 3.00K
              [ydlidar_node-2] [2024-12-22 15:13:32][info] Single Fixed Size: 310
              [ydlidar_node-2] [2024-12-22 15:13:32][info] Successed to check the lidar, Elapsed time 386 ms
              [ydlidar_node-2] [2024-12-22 15:13:32][info] Now lidar is scanning...
              [ydlidar_node-2] [2024-12-22 15:13:33][error] Check Sum 0x6C52 != 0x4370
              [ydlidar_node-2] [2024-12-22 15:13:34][error] Check Sum 0x7CF6 != 0x5C74
              [ydlidar_node-2] [ERROR] [1734880416.377512451] [ydlidar_node]: Failed to get scan
              [ydlidar_node-2] [2024-12-22 15:13:36][error] Timeout count: 1
              [ydlidar_node-2] [YDLIDAR ERROR]: -1 Operation timed out
              [ydlidar_node-2] [ERROR] [1734880417.378154871] [ydlidar_node]: Failed to get scan
              [ydlidar_node-2] [2024-12-22 15:13:37][error] Timeout count: 2
              [ydlidar_node-2] [ERROR] [1734880418.379028243] [ydlidar_node]: Failed to get scan
              [ydlidar_node-2] [2024-12-22 15:13:38][error] Timeout count: 3
              [ydlidar_node-2] [ERROR] [1734880419.379892913] [ydlidar_node]: Failed to get scan
                小鱼 技术大佬 @3120044269
                @3120044269 把前面部分也截取一下
                3 1 条回复 最后回复 回复 引用 0
                  3120044269 @小鱼
                  @小鱼 [INFO] [launch]: All log files can be found below /root/.ros/log/2024-12-22-15-43-42-718761-ea6d2dcc0496-58
                  [tcp_server-1] [INFO] [1734882223.432319749] [tcp_socket_server_node]: TCP端口:8888,已映射到串口设备:/tmp/tty_laser
                  [tcp_server-1] [INFO] [1734882223.432845278] [tcp_socket_server_node]: 等待接受连接..
                  [INFO] [ydlidar_node-2]: process started with pid [82]
                  [ydlidar_node-2] [INFO] [1734882226.288480684] [ydlidar_node]: [YDLIDAR INFO] Current ROS Driver Version: 1.0.1
                  [ydlidar_node-2]
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] SDK initializing
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] SDK has been initialized
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] SDK Version: 1.2.9
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] Connect elapsed time 0 ms
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] Lidar successfully connected [/tmp/tty_laser:115200]
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] Lidar running correctly! The health status good
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] Current Lidar Model Code 12
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] Check status, Elapsed time 0 ms
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] Lidar init success, Elapsed time [1]ms
                  [ydlidar_node-2] [2024-12-22 15:43:46][info] Start to getting intensity flag
                  [ydlidar_node-2] [2024-12-22 15:43:49][info] [YDLIDAR] End to getting intensity flag
                  [ydlidar_node-2] [2024-12-22 15:43:49][info] [YDLIDAR] Create thread 0xF7E00640
                  [ydlidar_node-2] [2024-12-22 15:43:49][info] Successed to start scan mode, Elapsed time 3564 ms
                    小鱼 技术大佬 @3120044269
                    @3120044269 在 [FishBot教程] 6. 雷达驱动及建图测试 中说:
                    应该是没有连接成功,emm,方便加一下我微信吗
                      3120044269 @小鱼
                      @小鱼 好的,怎么加呀
                        小鱼 技术大佬 @3120044269
                        @3120044269 公众号下方有二维码
                          3120044269 @小鱼
                          @小鱼 加啦加啦,韓.
                            lvjiaming2007
                            orange pi how to do
                            exec /startup.sh: exec format error
                            • J
                              jerry_88965294
                              @小鱼 我在四驱版使用时,雷达驱动第2步,驱动雷达报错,这步报错也会导致第3步报错,请问怎么回事呢?
                              S 1 条回复 最后回复 回复 引用 0
                                sunhao2202 年度VIP
                                雷达驱动问题:
                                [ydlidar_node-2] [2025-01-03 11:31:56][error] Check Sum 0x68D7 != 0x1569
                                [ydlidar_node-2] [2025-01-03 11:31:59][error] Check Sum 0x5DEA != 0x1B19
                                [ydlidar_node-2] [ERROR] [1735903928.417755598] [ydlidar_node]: Failed to get scan
                                [ydlidar_node-2] [2025-01-03 11:32:08][error] Timeout count: 1
                                [ydlidar_node-2] [2025-01-03 11:32:08][error] Check Sum 0x121C != 0x0233
                                [ydlidar_node-2] [2025-01-03 11:32:34][error] Check Sum 0xB856 != 0x868F
                                [ydlidar_node-2] [2025-01-03 11:32:34][error] Check Sum 0xBF44 != 0xD5E3
                                [ydlidar_node-2] [2025-01-03 11:32:35][error] Check Sum 0x53E4 != 0x51BD
                                [ydlidar_node-2] [2025-01-03 11:32:36][error] Check Sum 0xD974 != 0x87D3
                                [ydlidar_node-2] [2025-01-03 11:32:50][error] Check Sum 0x1E40 != 0x0FDE
                                [ydlidar_node-2] [ERROR] [1735903972.437430773] [ydlidar_node]: Failed to get scan
                                [ydlidar_node-2] [2025-01-03 11:32:52][error] Timeout count: 1
                                [ydlidar_node-2] [ERROR] [1735903973.437858047] [ydlidar_node]: Failed to get scan
                                [ydlidar_node-2] [2025-01-03 11:32:53][error] Timeout count: 2
                                [ydlidar_node-2] [2025-01-03 11:32:53][error] Check Sum 0x1A71 != 0x15AB
                                [ydlidar_node-2] [INFO] [1735903974.800384796] [rclcpp]: signal_handler(signum=2)
                                [ERROR] [tcp_server-1]: process has died [pid 59, exit code -2, cmd '/workspace/install/ros_serail2wifi/lib/ros_serail2wifi/tcp_server --ros-args --params-file /tmp/launch_params_s0dvbmtk --params-file /tmp/launch_params_4auj8l85'].
                                [tcp_server-1] Traceback (most recent call last):
                                [tcp_server-1] File "/workspace/install/ros_serail2wifi/lib/ros_serail2wifi/tcp_server", line 33, in <module>
                                [tcp_server-1] sys.exit(load_entry_point('ros-serail2wifi==0.0.0', 'console_scripts', 'tcp_server')())
                                [tcp_server-1] File "/workspace/install/ros_serail2wifi/lib/python3.10/site-packages/ros_serail2wifi/tcpserver.py", line 76, in main
                                [tcp_server-1] node.run()
                                [tcp_server-1] File "/workspace/install/ros_serail2wifi/lib/python3.10/site-packages/ros_serail2wifi/tcpserver.py", line 49, in run
                                雷达建图问题:
                                [ydlidar_node-6] [2025-01-03 11:26:54][error] Timeout count: 2
                                [ydlidar_node-6] [2025-01-03 11:26:54][error] Timeout count: 3
                                [cartographer_node-3] [INFO] [1735903614.135216721] [cartographer logger]: I0103 11:26:54.000000 63 node.cpp:569] Shutdown the subscriber of [scan]
                                [cartographer_node-3] [INFO] [1735903614.135283530] [cartographer logger]: I0103 11:26:54.000000 63 map_builder_bridge.cpp:152] Finishing trajectory with ID '0'...
                                [cartographer_node-3] [WARN] [1735903614.135465851] [cartographer logger]: W0103 11:26:54.000000 63 node.cpp:773] Can't run final optimization if there are one or more active trajectories. Trying to finish trajectory with ID 0 now.
                                [cartographer_node-3] [INFO] [1735903614.135520310] [cartographer logger]: I0103 11:26:54.000000 63 node.cpp:551] Trajectory 0 already pending to finish.
                                [cartographer_node-3] [INFO] [1735903614.135590080] [cartographer logger]: I0103 11:26:54.000000 63 map_builder_bridge.cpp:161] Running final trajectory optimization...
                                [cartographer_node-3] [INFO] [1735903614.136761950] [cartographer logger]: I0103 11:26:54.000000 116 pose_graph_2d.cc:538] Remaining work items in queue: 2
                                [cartographer_node-3] [INFO] [1735903614.136858631] [cartographer logger]: I0103 11:26:54.000000 116 constraint_builder_2d.cc:290] 21 computations resulted in 0 additional constraints.
                                [cartographer_node-3] [INFO] [1735903614.137078579] [cartographer logger]: I0103 11:26:54.000000 116 constraint_builder_2d.cc:292] Score histogram:
                                [cartographer_node-3] Count: 4 Min: 0.664706 Max: 0.9 Mean: 0.749173
                                [cartographer_node-3] [0.664706, 0.688235) ##### Count: 1 (25%) Total: 1 (25%)
                                [cartographer_node-3] [0.688235, 0.711765) ##### Count: 1 (25%) Total: 2 (50%)
                                [cartographer_node-3] [0.711765, 0.735294) ##### Count: 1 (25%) Total: 3 (75%)
                                [cartographer_node-3] [0.735294, 0.758824) Count: 0 (0%) Total: 3 (75%)
                                [cartographer_node-3] [0.758824, 0.782353) Count: 0 (0%) Total: 3 (75%)
                                [cartographer_node-3] [0.782353, 0.805882) Count: 0 (0%) Total: 3 (75%)
                                [cartographer_node-3] [0.805882, 0.829412) Count: 0 (0%) Total: 3 (75%)
                                [cartographer_node-3] [0.829412, 0.852941) Count: 0 (0%) Total: 3 (75%)
                                [cartographer_node-3] [0.852941, 0.876471) Count: 0 (0%) Total: 3 (75%)
                                [cartographer_node-3] [0.876471, 0.900000] ##### Count: 1 (25%) Total: 4 (100%)
                                [cartographer_node-3] [INFO] [1735903614.159599813] [cartographer logger]: I0103 11:26:54.000000 116 pose_graph_2d.cc:538] Remaining work items in queue: 1
                                [cartographer_node-3] [INFO] [1735903614.159673485] [cartographer logger]: I0103 11:26:54.000000 116 constraint_builder_2d.cc:290] 0 computations resulted in 0 additional constraints.
                                [cartographer_node-3] [INFO] [1735903614.160093412] [cartographer logger]: I0103 11:26:54.000000 116 constraint_builder_2d.cc:292] Score histogram:
                                [cartographer_node-3] [INFO] [1735903614.175929395] [cartographer logger]: I0103 11:26:54.000000 115 constraint_builder_2d.cc:290] 0 computations resulted in 0 additional constraints.
                                [cartographer_node-3] [INFO] [1735903614.176097541] [cartographer logger]: I0103 11:26:54.000000 115 constraint_builder_2d.cc:292] Score histogram:
                                [cartographer_node-3] [INFO] [1735903614.194124283] [cartographer logger]: I0103 11:26:54.000000 114 constraint_builder_2d.cc:290] 0 computations resulted in 0 additional constraints.
                                [cartographer_node-3] [INFO] [1735903614.194258427] [cartographer logger]: I0103 11:26:54.000000 114 constraint_builder_2d.cc:292] Score histogram:
                                Optimizing: Done.
                                Optimizing: Done.
                                [ydlidar_node-6] [YDLIDAR ERROR]: -1 Device is not open
                                [ydlidar_node-6] [ERROR] [1735903615.059047626] [ydlidar_node]: Failed to get scan
                                  sunhao2202 年度VIP @jerry_88965294
                                  @jerry_88965294 我这也是这个问题,后面都是这样的报错,建图一直跳
                                    小鱼 技术大佬 @sunhao2202
                                    @sunhao2202 您好,使用的是哪个版本的固件,网络质量如何
                                      小鱼 技术大佬 @sunhao2202
                                      @sunhao2202 在 [FishBot教程] 9.0.6. 雷达驱动及建图测试 中说:
                                      驱动正常后再尝试建图
                                      S Y 2 条回复 最后回复 回复 引用 0
                                        sunhao2202 年度VIP @小鱼
                                        @小鱼 烧录最新固件,我再试试
                                          yongyong @小鱼
                                            yongyong @1216898523
