重要提示
未解决 vm虚拟机+ubuntu20+ros2,添加接口后报错,cmake过不去
vm虚拟机+ubuntu20+ros2
添加接口后报错,按照4.3.2教程复制过去,单独编译package.xml可以通过,cmake过不去 -
请问解决了吗?我也遇到了这个问题
@一只活跃的新手 没有
@练剑的书生 请问你也是之前一直用Python的吗
@一只活跃的新手 刚开始学习
@练剑的书生 我也是,我在前面章节都是用的Python实现,用的rclpy
到这就出问题了 -
@练剑的书生 提供下Novel.msg内容和你的目录结构,另外试试直接colcon build所有的试试。
@练剑的书生 可以用复制粘贴的方式把报错贴一下吗,我好去检索下
gsl@gsl-virtual-machine:~/桌面/colcon_test/town_ws$ colcon build Starting >>> village_interfaces Starting >>> village_li --- stderr: village_interfaces CMake Error at /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:240 (list): list index: 1 out of range (-1, 0) Call Stack (most recent call first): CMakeLists.txt:37 (rosidl_generate_interfaces) CMake Error at /opt/ros/foxy/share/rosidl_generator_c/cmake/rosidl_generator_c_generate_interfaces.cmake:65 (message): Target dependency '/colcon_test/town_ws/build/village_interfaces/rosidl_adapter/village_interfaces/msg/Novel.idl' does not exist Call Stack (most recent call first): /opt/ros/foxy/share/ament_cmake_core/cmake/core/ament_execute_extensions.cmake:48 (include) /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:286 (ament_execute_extensions) CMakeLists.txt:37 (rosidl_generate_interfaces) make: *** [Makefile:222:cmake_check_build_system] 错误 1 --- Failed <<< village_interfaces [1.01s, exited with code 2] Aborted <<< village_li [1.20s] Summary: 0 packages finished [1.42s] 1 package failed: village_interfaces 1 package aborted: village_li 1 package had stderr output: village_interfaces 1 package not processed
@练剑的书生 我找了下源码测试下,发现没有问题,同foxy版本。
root@097c0c2d6b66:/home/mouse/code/github/ros2_town# colcon build Starting >>> village_interfaces Finished <<< village_interfaces [6.30s] Starting >>> village_li Starting >>> village_wang Starting >>> village_zhang Finished <<< village_li [0.89s] Finished <<< village_zhang [4.31s] Finished <<< village_wang [7.31s] Summary: 4 packages finished [13.7s] root@097c0c2d6b66:/home/mouse/code/github/ros2_town# echo $ROS_DISTRO foxy
源码地址:https://github.com/fishros/ros2_town
请你下载源码后直接编译看看,排除是代码问题
@小鱼 下载下来编译还是这个样子,像是cmake环境有问题了
@练剑的书生 你装的是桌面版的ROS2吗,我也怀疑编译工具问题,你在village_interfaces文件夹下试一下下面的语句
source /opt/ros/foxy/setup.bash mkdir build cd build cmake .. make
@小鱼 是桌面版
-- The C compiler identification is GNU 9.4.0
-- The CXX compiler identification is GNU 9.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Found ament_cmake: 0.9.9 (/opt/ros/foxy/share/ament_cmake/cmake)
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.10", minimum required is "3")
-- Using PYTHON_EXECUTABLE: /usr/bin/python3
-- Found sensor_msgs: 2.0.5 (/opt/ros/foxy/share/sensor_msgs/cmake)
-- Found rosidl_adapter: 1.2.1 (/opt/ros/foxy/share/rosidl_adapter/cmake)
-- Found OpenSSL: /usr/lib/x86_64-linux-gnu/libcrypto.so (found version "1.1.1f")
-- Found FastRTPS: /opt/ros/foxy/include
-- Found rosidl_default_generators: 1.0.1 (/opt/ros/foxy/share/rosidl_default_generators/cmake)
-- Found PythonInterp: /usr/bin/python3 (found version "3.8.10")
CMakeLists.txt:26 (rosidl_generate_interfaces)CMake Error at /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:240 (list):
CMakeLists.txt:26 (rosidl_generate_interfaces)CMake Error at /opt/ros/foxy/share/rosidl_generator_c/cmake/rosidl_generator_c_generate_interfaces.cmake:65 (message):
Target dependency
'/src/examples/src/village_interfaces/build/rosidl_adapter/village_interfaces/msg/Novel.idl'
does not exist
CMakeLists.txt:26 (rosidl_generate_interfaces)-- Configuring incomplete, errors occurred!
See also "/home/gsl/桌面/src/examples/src/village_interfaces/build/CMakeFiles/CMakeOutput.log". -
@练剑的书生 先去掉sensor_msgs依赖以及Novel.msg中的image字段试试
@小鱼 Starting >>> village_interfaces
CMake Error at /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:162 (message):
rosidl_generate_interfaces() the passed dependency 'sensor_msgs' has not
been found before using find_package()
Failed <<< village_interfaces [0.45s, exited with code 1]
Summary: 0 packages finished [0.65s]
3 packages not processed -
@练剑的书生 在 vm虚拟机+ubuntu20+ros2,添加接口后报错,cmake过不去 中说:
been found before using find_package()看到这个错误了,你把CMakeLists.txt中的find_package(sensor_msgs)去掉
@练剑的书生 屏蔽了之后编译是这样的
@练剑的书生 贴一下你的CMakeLists.txt,应该是没删除干净
@小鱼 cmake_minimum_required(VERSION 3.5)
project(village_interfaces)Default to C99
if(NOT CMAKE_C_STANDARD)
set(CMAKE_C_STANDARD 99)
endif()Default to C++14
if(NOT CMAKE_CXX_STANDARD)
set(CMAKE_CXX_STANDARD 14)
endif()if(CMAKE_COMPILER_IS_GNUCXX OR CMAKE_CXX_COMPILER_ID MATCHES "Clang")
endif()find dependencies
#find_package(sensor_msgs REQUIRED)
find_package(rosidl_default_generators REQUIRED)uncomment the following section in order to fill in
further dependencies manually.
find_package(<dependency> REQUIRED)
if(BUILD_TESTING)
find_package(ament_lint_auto REQUIRED)the following line skips the linter which checks for copyrights
uncomment the line when a copyright and license is not present in all source files
uncomment the line when this package is not in a git repo
endif()rosidl_generate_interfaces(${PROJECT_NAME}
"msg/Novel.msg"
DEPENDENCIES sensor_msgs
)ament_package()
