    MicroROS
    fishbot 树莓派 agent 手动编译过程
    27
    93
    169.4k
      1976933473 @小鱼
      哥,请问有什么办法提高micro-ros与ROS2之间的通信速度不
      1,想过提高串口连接agent的波特率,但是波特率超过921600 ,agent就不工作了(查阅资料显示esp32s3最高波特率可以达到4500000),请问有办法提高连接agent的波特率不
      2,请问使esp32s3运行micro-ros可以通过网线连接agent不
        小鱼 技术大佬 @1976933473
        @1976933473 走网线
        • 南京嵌入之梦南
          南京嵌入之梦
          按此操作,在最后一步(colcon build)出现问题:
          dq@dq-virtual-machine:~/Desktop/microros_ws$ colcon build
          Starting >>> micro_ros_msgs
          Finished <<< micro_ros_msgs [17.1s]
          Starting >>> micro_ros_agent
          [Processing: micro_ros_agent]
          --- stderr: micro_ros_agent
          Cloning into 'xrceagent'...
          Switched to a new branch 'ros2'
          HEAD is now at c25243c Enable Domain Override on Reference and XML Participant (#351)
          The package name passed to find_package_handle_standard_args (tinyxml2)
          does not match the name of the calling package (TinyXML2). This can lead
          to problems in calling code that expects find_package result variables
          In file included from /home/dq/Desktop/microros_ws/src/micro-ROS-Agent/micro_ros_agent/src/main.cpp:15:
          /home/dq/Desktop/microros_ws/src/micro-ROS-Agent/micro_ros_agent/include/agent/Agent.hpp:18:10: fatal error: uxr/agent/AgentInstance.hpp: No such file or directory
          18 | #include <uxr/agent/AgentInstance.hpp>
          compilation terminated.
          gmake[5]: *** [CMakeFiles/micro_ros_agent.dir/build.make:76: CMakeFiles/micro_ros_agent.dir/src/main.cpp.o] Error 1
          gmake[4]: *** [CMakeFiles/Makefile2:137: CMakeFiles/micro_ros_agent.dir/all] Error 2
          gmake[3]: *** [Makefile:146: all] Error 2
          gmake[2]: *** [CMakeFiles/micro_ros_agent.dir/build.make:86: micro_ros_agent-prefix/src/micro_ros_agent-stamp/micro_ros_agent-build] Error 2
          gmake[1]: *** [CMakeFiles/Makefile2:111: CMakeFiles/micro_ros_agent.dir/all] Error 2
          gmake: *** [Makefile:91: all] Error 2
          Failed <<< micro_ros_agent [3min 26s, exited with code 2]
          Summary: 1 package finished [3min 44s]
          1 package failed: micro_ros_agent
          1 package had stderr output: micro_ros_agent
          问题出在哪里?
          系统是 ubuntu 22.04 虚拟机(VMware),一键安装的 ROS2(humble)。
          开始用 docker 试过,也不成功。
          盼指点……
          谢谢!
          • 南京嵌入之梦南
            南京嵌入之梦
            我在 unbuntu22.04 虚拟机上参考此方式安装 MicroRos Agent,编译失败
            直接用您的一键安装 ROS2 ,已正常运行,现在想和单片机通讯,按照文章先尝试了 Docker 模式,提示 MicroROS agent 没有找到,担心是外网问题,看到有直接安装在本地运行的方式,便参照实施。
            前几步均正常,到编译(colcon build)这一步时,出错,尝试了很多方式,最终现象停留在:
            dq@dq-virtual-machine:~/Desktop$ cd microros_ws
            Finished <<< micro_ros_msgs [1.67s]
            In file included from /home/dq/Desktop/microros_ws/src/micro-ROS-Agent/micro_ros_agent/src/agent/Agent.cpp:18:
            gmake[2]: *** [CMakeFiles/micro_ros_agent.dir/build.make:76: CMakeFiles/micro_ros_agent.dir/src/main.cpp.o] Error 1
            gmake[2]: *** Waiting for unfinished jobs....
            gmake[2]: *** [CMakeFiles/micro_ros_agent.dir/build.make:90: CMakeFiles/micro_ros_agent.dir/src/agent/Agent.cpp.o] Error 1
            gmake[1]: *** [CMakeFiles/Makefile2:137: CMakeFiles/micro_ros_agent.dir/all] Error 2
            gmake: *** [Makefile:146: all] Error 2
            Failed <<< micro_ros_agent [0.28s, exited with code 2]
            Summary: 1 package finished [2.47s]
            似乎是少安装了什么,搜相关问题,按其不同方式做,均问化解,故在此请教,望版主抽空回复,谢谢!
            南京嵌入之梦南 1 条回复 最后回复 回复 引用 0
            • 南京嵌入之梦南
              南京嵌入之梦 @南京嵌入之梦
              @南京嵌入之梦
              此问题已化解。
              将ubuntu虚拟机重新安装,再一步步按照鱼香ROS的教程安装,虽说还是有点坎坷,但总算安装完成了,并且成功运行,可以接收到数据,只是不太圆满,遇到了新的问题,正常查找问题。
              我是参考这个帖子将 microros agnet 安装在本地的。
              顺利完成教程中第一个 MicroROS节点,并运行。
              目前运行的现象是:
              不知道有人遇到过吗?盼指点!
              • 苛
                苛性钠zzz 年度VIP
                @小鱼 鱼哥是不是用了树莓派,按照步骤来,把开发板弄成串行模式,然后雷达直接连树莓派,两个板子是不是都不用连WiFi了呀,只用树莓派连就行了
                  小鱼 技术大佬 @苛性钠zzz
                  @苛性钠zzz 是的,你好聪明
                    萌新 @小鱼
                      萌新 @小鱼
                      @小鱼 小鱼,能启动microros_agent,都在一个WiFi下,ping的通也是udp模式,但是启动键盘控制后小车不会动是为什么啊,硬件也重新烧录了最新的,是不是PIO也要重新烧一下
                      micro ROS:
                      [1742892712.396319] debug | UDPv4AgentLinux.cpp | recv_message | [==>> UDP <<==] | client_key: 0x1007FDF9, len: 324, data:
                      0000: 81 01 05 07 01 3C 01 05 E4 00 15 A8 6E E2 67 00 60 E3 16 04 00 00 00 69 6D 75 00 00 00 00 A0
                      0020: E8 35 63 BF 00 00 00 80 28 C4 86 BF 00 00 00 A0 5D E3 BF 3F 00 00 00 60 AA BF EF 3F 00 00 00 00
                      0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                      0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                      0080: 00 00 00 00 00 00 00 40 36 65 06 C0 00 00 00 00 18 39 00 40 00 00 00 A0 3D 7E 1B C0 00 00 00 00
                      00A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                      00C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                      00E0: 00 00 00 00 00 00 00 80 ED 7C 66 BF 00 00 00 40 87 56 88 BF 00 00 00 00 14 55 F0 3F 00 00 00 00
                      0100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                      0120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                      0140: 00 00 00 00
                      ping小车ip:
                      orangepi@orangepi5plus:~$ ping 10.10.10.230
                      PING 10.10.10.230 (10.10.10.230) 56(84) bytes of data.
                      64 bytes from 10.10.10.230: icmp_seq=1 ttl=64 time=13.2 ms
                      64 bytes from 10.10.10.230: icmp_seq=2 ttl=64 time=6.53 ms
                      64 bytes from 10.10.10.230: icmp_seq=3 ttl=64 time=8.17 ms
                      64 bytes from 10.10.10.230: icmp_seq=4 ttl=64 time=8.73 ms
                      64 bytes from 10.10.10.230: icmp_seq=5 ttl=64 time=9.80 ms
                      64 bytes from 10.10.10.230: icmp_seq=6 ttl=64 time=5.36 ms
                      64 bytes from 10.10.10.230: icmp_seq=7 ttl=64 time=10.4 ms
                      64 bytes from 10.10.10.230: icmp_seq=8 ttl=64 time=6.55 ms
                      64 bytes from 10.10.10.230: icmp_seq=9 ttl=64 time=5.61 ms
                      64 bytes from 10.10.10.230: icmp_seq=10 ttl=64 time=13.5 ms
                      64 bytes from 10.10.10.230: icmp_seq=11 ttl=64 time=14.3 ms
                      64 bytes from 10.10.10.230: icmp_seq=12 ttl=64 time=11.0 ms
                      ^C
                      --- 10.10.10.230 ping statistics ---
                      12 packets transmitted, 12 received, 0% packet loss, time 11019ms
                      rtt min/avg/max/mdev = 5.362/9.421/14.280/2.997 ms
                        萌新 @小鱼
                          小鱼 技术大佬 @2431039560
                          @2431039560 固件用的哪一个
                            萌新 @小鱼
                            @小鱼 最新V1.2.3的配置助手二驱板烧录的,具体是这个https://fishros.org.cn/forum/assets/uploads/files/1736172779188-fishbot_motion_control_v1.7.2.alpha.241229.bin
                              小鱼 技术大佬 @2431039560
                              @2431039560 开关供电都正常吗,线连接是否正常,确认下控制命令是否发布出去了,比如开个新的终端订阅,小车的oled屏幕会不会闪烁
                              2 2 条回复 最后回复 回复 引用 0
                                萌新 @小鱼
                                  萌新 @小鱼
                                  @小鱼 其他的好像都是正常的,然后cmd_vel发送出去了小车好像没收到,小车不会动,屏幕的线速度也都是0
                                    小鱼 技术大佬 @2431039560
                                    @2431039560 agent用的docker版本的吗
                                      小鱼 技术大佬 @2431039560
                                      @2431039560 有没有设置什么DOMAIN_ID
                                      2 3 条回复 最后回复 回复 引用 0
                                        萌新 @小鱼
                                        @小鱼 docker版本的好像下载不了,docker用一键安装以后get镜像那里出问题了,然后启动是这样的
                                        拉镜像:
                                        Run CMD Task:[sudo docker pull ros:humble ]
                                        启动不了:
                                        docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged --net=host registry.cn-hangzhou.aliyuncs.com/fishros/micro-ros-agent:$ROS_DISTRO udp4 --port 8888 -v6
                                        然后DOMAIN_ID设为了0,这里我看站内有树莓派的教程说默认是=0
                                          萌新 @小鱼
                                            萌新 @小鱼
                                            @小鱼 鱼,我把domain_id删了,然后docker也下好了,也可以启动的,但还是和之前一样,能发数据也能正常启动,小车也连上了但还是启动键盘控制后不会动,其他还需要配置什么嘛,要不要在PIO里重新上传一下
