    [FishBot教程] 9.0.5. 雷达固件烧录及配置
    fishbot 雷达
    29
    71
    127.2k
      小鱼 技术大佬 @862524030
      @862524030 请贴出使用的命令
      8 1 条回复 最后回复 回复 引用 0
      • 8
        862524030 年度VIP @小鱼
        @小鱼 ~$ xhost + && sudo docker run -it --rm -p 8889:8889 -p 8889:8889/udp -v /dev:/dev -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY registry.cn-hangzhou.aliyuncs.com/fishros/fishbot_laser
        1. WIFI转串口测试
        2. 驱动雷达
        3. 建图测试
        4. 退出
          #? 1
          [INFO] [launch]: All log files can be found below /root/.ros/log/2025-07-30-16-19-12-964512-0279608df313-58
          [tcp_server-1] [INFO] [1753892353.208186223] [tcp_socket_server_node]: TCP端口:8888,已映射到串口设备:/tmp/tty_laser
          [tcp_server-1] [INFO] [1753892353.208416185] [tcp_socket_server_node]: 等待接受连接..
          最后由 1178152552 编辑
          ad4f5a9c-17a6-4b75-9cb4-d73eec606053-image.png 不管下载哪个版本固件都显示这个错误,是什么原因
            小鱼 技术大佬 @2251581333
            @2251581333 在 [FishBot教程] 9.0.5. 雷达固件烧录及配置 中说:
            烧录的时候说芯片不对,怎么解决呀鱼哥
            2023-04-08 07:37:37 > 准备从https://www.fishros.org.cn/forum/assets/uploads/files/1673413115955-fishbot_laser_control_v1.0.0.230111.bin下载固件到/dev/ttyUSB0对应芯片为esp8266
            2023-04-08 07:37:37 > 准备从网址下载固件...
            2023-04-08 07:37:39 >
            2023-04-08 07:37:39 > --2023-04-08 07:37:36-- https://www.fishros.org.cn/forum/assets/uploads/files/1673413115955-fishbot_laser_control_v1.0.0.230111.bin
            2023-04-08 07:37:39 > Resolving www.fishros.org.cn (www.fishros.org.cn)... 124.222.2.110
            2023-04-08 07:37:39 > Connecting to www.fishros.org.cn (www.fishros.org.cn)|124.222.2.110|:443... connected.
            2023-04-08 07:37:39 > HTTP request sent, awaiting response... 200 OK
            2023-04-08 07:37:39 > Length: 532320 (520K) [application/octet-stream]
            2023-04-08 07:37:39 > Saving to: ‘esp8266.bin’
            2023-04-08 07:37:39 > 固件下载完成!
            2023-04-08 07:37:39 > 开始烧录固件...
            2023-04-08 07:37:39 > esptool.py v4.4
            2023-04-08 07:37:39 > Serial port /dev/ttyUSB0
            2023-04-08 07:37:39 > Connecting....
            2023-04-08 07:37:39 > A fatal error occurred: This chip is ESP32 not ESP8266. Wrong --chip argument?
            2023-04-08 07:37:39 > [错误]固件写入失败,请检查日志或重试。。。
            @1178152552
            • 8
              825255301
              鱼哥,雷达的sever_ip地址找不到是为什么?
                MerHm @862524030
                @862524030 请问解决了吗,一样的问题
                  MerHm
                  Quicker_20251026_230102.png Quicker_20251026_230142.png 大佬,遇到雷达测试一直没有数据的问题,求助
                  • Z
                    zlfdtc1983
                    我的雷达连上了ubuntu 22.04的电脑了,但是 /scan话题频率特别低。无线和串口都试了。
                    552bd328-0f67-487e-a4c8-89ab1262a299-img_v3_02sr_070896fb-ea9c-45a8-9ba8-2dc83970233g.jpg
                    c90e7056-f007-4079-8cfb-66f51c06d770-img_v3_02sr_d28c59ff-412d-4dfa-b0b9-297990d51e2g.jpg
                    • 8
                      862524030 年度VIP @2609771027
                      @2609771027 没有
                      • 11394353241
                        单车 @朔风
                        @朔风 你的问题解决了吗?我也遇到跳线帽正确,但是模式一直为运行模式
                          sxjj @张剑锋
                          @小鱼 我的雷达上电怎么不转啊
                          • Q
                            qyz @张剑锋
                            @张剑锋 切成2.4G的可以
                              关于在nc -l 8889这一步终端没有回复的人,可能是ubuntu防火墙,sudo ufw disable,关闭防火墙,再运行指令,就可以收到一堆乱码了。
