    自定义话题接口编译错误
    ros2 msg
    5
    15
    5.5k
      小鱼 技术大佬 @LI
      @LI 贴下你的msg,CmakeLists.txt和packages.xml,另外是否使用了conda等虚拟环境
      LIL 1 条回复 最后回复 回复 引用 0
      • LIL
        LI @小鱼
        @小鱼 基本是复制下来的
        msg:
        string content
        sensor_msgs/Image image
        cmake.txt
        project(demo_interface)
        endif()
          "msg/Novel.msg"
           DEPENDENCIES sensor_msgs
        if(BUILD_TESTING)
        endif()
        ament_package()
        package.xml
        <?xml version="1.0"?>
        <package format="3">
          <name>demo_interface</name>
          <version>0.0.0</version>
          <maintainer email="li-xiaoqiang@outlook.com">li</maintainer>
          <depend>sensor_msgs</depend>
          <build_depend>rosidl_default_generators</build_depend>
          <exec_depend>rosidl_default_runtime</exec_depend>
          <export>
          </export>
        </package>
        安装过anaconda,但编译的时候是关闭的,不在conda环境里。
          小鱼 技术大佬 @LI
          @LI 还真没看出来错误,但是和conda估计还是有些关系,我们再检查一下这个文件,你贴一下里面的内容
          /opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/__init__.py
            小鱼 技术大佬 @LI
            @LI 刚去检索了下,看到一个相同的问题,是出在conda上,你试试打开一个新的终端,运行下面的指令,如果可以成功,那就是conda确实没退出或者对PYTHONPATH产生了什么影响
            $ conda deactivate
            $ python3 -c 'from rosidl_generator_py import generate_py'
            • LIL
              LI @小鱼
              @小鱼 /opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/init.py是这样的
              # Copyright 2014-2015 Open Source Robotics Foundation, Inc.
              # Licensed under the Apache License, Version 2.0 (the "License");
              # you may not use this file except in compliance with the License.
              # You may obtain a copy of the License at
              #     http://www.apache.org/licenses/LICENSE-2.0
              # Unless required by applicable law or agreed to in writing, software
              # distributed under the License is distributed on an "AS IS" BASIS,
              # WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
              # See the License for the specific language governing permissions and
              # limitations under the License.
              import logging
              import traceback
              from .import_type_support_impl import import_type_support
              __all__ = ['import_type_support']
              try:
                  from .generate_py_impl import generate_py
                  assert generate_py
                  __all__.append('generate_py')
              except ImportError:
                  logger = logging.getLogger('rosidl_generator_py')
                  logger.debug(
                      'Failed to import modules for generating Python structures:\n' + traceback.format_exc())
              尝试了那两行命令,仍旧是同样的报错
                小鱼 技术大佬 @LI
                @LI 那就尝试用pip卸载重新安装写这个缺少的模块,不过这个模块代码应该就在你电脑上
                • LIL
                  LI @小鱼
                  @小鱼 最后靠着重装ros2,没改文件内容,解决了问题
                    小鱼 技术大佬 @LI
                    @LI 解决环境问题最好的办法就是重装了😂
                    晤易晤 1 条回复 最后回复 回复 引用 0
                    • 晤易晤
                      晤易 @小鱼
                      @小鱼 鱼哥,我也遇到这个问题了。这个问题到底怎么解决呀,重装了ros也没用
                        小鱼 技术大佬 @晤易
                        @晤易 你是哪个版本的ros2
                        • 晤易晤
                          晤易 @小鱼
                          @小鱼 humble 版本的
                          • 沉淀沉
                            沉淀
                            最后由 沉淀 编辑
                            找了半天才找到这个解决办法,系统是22.04,安装ros humble,也是报相同的错误,亲测是Conda和本机环境冲突,需要用鱼哥说的在安装中先conda deactivate
                            晤易晤 1 条回复 最后回复 回复 引用 1
                            • 晤易晤
                              晤易 @沉淀
                              @沉淀 我是 conda deactivate了还是报错,然后把之前的编译文件和日志都删除了,再重新编译就不报错了
                              19144517741 1 条回复 最后回复 回复 引用 0
                              • 小鱼小 小鱼 从 中的 动手学ROS2 移动了该主题
                              • 19144517741
                                LIME @晤易
                                @晤易 我的情况按照你说的解决了,这个坑困扰我了一下午了。
