    自定义话题接口编译错误
    ros2 msg
    5
    15
    6.2k
    • LIL
      LI @小鱼
      @小鱼 基本是复制下来的
      msg:
      string content
      sensor_msgs/Image image
      cmake.txt
      project(demo_interface)
      endif()
        "msg/Novel.msg"
         DEPENDENCIES sensor_msgs
      if(BUILD_TESTING)
      endif()
      ament_package()
      package.xml
      <?xml version="1.0"?>
      <package format="3">
        <name>demo_interface</name>
        <version>0.0.0</version>
        <maintainer email="li-xiaoqiang@outlook.com">li</maintainer>
        <depend>sensor_msgs</depend>
        <build_depend>rosidl_default_generators</build_depend>
        <exec_depend>rosidl_default_runtime</exec_depend>
        <export>
        </export>
      </package>
      安装过anaconda,但编译的时候是关闭的,不在conda环境里。
        小鱼 技术大佬 @LI
        @LI 还真没看出来错误,但是和conda估计还是有些关系,我们再检查一下这个文件,你贴一下里面的内容
        /opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/__init__.py
          小鱼 技术大佬 @LI
          @LI 刚去检索了下,看到一个相同的问题,是出在conda上,你试试打开一个新的终端,运行下面的指令,如果可以成功,那就是conda确实没退出或者对PYTHONPATH产生了什么影响
          $ conda deactivate
          $ python3 -c 'from rosidl_generator_py import generate_py'
          LIL 1 条回复 最后回复 回复 引用 0
          • LIL
            LI @小鱼
            @小鱼 /opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/init.py是这样的
            # Copyright 2014-2015 Open Source Robotics Foundation, Inc.
            # Licensed under the Apache License, Version 2.0 (the "License");
            # you may not use this file except in compliance with the License.
            # You may obtain a copy of the License at
            #     http://www.apache.org/licenses/LICENSE-2.0
            # Unless required by applicable law or agreed to in writing, software
            # distributed under the License is distributed on an "AS IS" BASIS,
            # WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
            # See the License for the specific language governing permissions and
            # limitations under the License.
            import logging
            import traceback
            from .import_type_support_impl import import_type_support
            __all__ = ['import_type_support']
            try:
                from .generate_py_impl import generate_py
                assert generate_py
                __all__.append('generate_py')
            except ImportError:
                logger = logging.getLogger('rosidl_generator_py')
                logger.debug(
                    'Failed to import modules for generating Python structures:\n' + traceback.format_exc())
            尝试了那两行命令,仍旧是同样的报错
              小鱼 技术大佬 @LI
              @LI 那就尝试用pip卸载重新安装写这个缺少的模块,不过这个模块代码应该就在你电脑上
              • LIL
                LI @小鱼
                @小鱼 最后靠着重装ros2,没改文件内容,解决了问题
                  小鱼 技术大佬 @LI
                  @LI 解决环境问题最好的办法就是重装了😂
                  晤易晤 1 条回复 最后回复 回复 引用 0
                  • 晤易晤
                    晤易 @小鱼
                    @小鱼 鱼哥,我也遇到这个问题了。这个问题到底怎么解决呀,重装了ros也没用
                      小鱼 技术大佬 @晤易
                      @晤易 你是哪个版本的ros2
                      • 晤易晤
                        晤易 @小鱼
                        @小鱼 humble 版本的
                        • 沉淀沉
                          沉淀
                          最后由 沉淀 编辑
                          找了半天才找到这个解决办法,系统是22.04,安装ros humble,也是报相同的错误,亲测是Conda和本机环境冲突,需要用鱼哥说的在安装中先conda deactivate
                          晤易晤 1 条回复 最后回复 回复 引用 1
                          • 晤易晤
                            晤易 @沉淀
                            @沉淀 我是 conda deactivate了还是报错,然后把之前的编译文件和日志都删除了,再重新编译就不报错了
                            19144517741 1 条回复 最后回复 回复 引用 0
                            • 小鱼小 小鱼 从 中的 动手学ROS2 移动了该主题
                            • 19144517741
                              LIME @晤易
                              @晤易 我的情况按照你说的解决了,这个坑困扰我了一下午了。
