    catkin_make报错
    ros1 一键安装 docker ros
    1.5k
    • 谁知谁
      谁知
      catkin_make报错
      系统 虚拟机ubuntu 22.04
      出现的问题 运行catkin_make时,报错
      错误指令:
       CMake Error at /opt/ros/melodic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
      any of the following names:
      styd_msgsConfig.cmake
      styd_msgs-config.cmake
      been installed.
      谁知谁 2 条回复 最后回复 回复 引用 0
      • 谁知谁
        谁知 @谁知
        @谁知 会不会是docker导致找不到文件,本小白已经找了一下午解决方案,实在是解决不了了
        • 谁知谁
          谁知 @谁知
          最后由 谁知 编辑
          @小鱼 再发一遍完整的代码过程,求助求助
          root@0286770e46d5:/home/tian/catkin_ws# catkin_make
          Base path: /home/tian/catkin_ws
          Source space: /home/tian/catkin_ws/src
          Build space: /home/tian/catkin_ws/build
          Devel space: /home/tian/catkin_ws/devel
          Install space: /home/tian/catkin_ws/install
          #### Running command: "make cmake_check_build_system" in "/home/tian/catkin_ws/build"
          -- Using CATKIN_DEVEL_PREFIX: /home/tian/catkin_ws/devel
          -- Using CMAKE_PREFIX_PATH: /opt/ros/melodic
          -- This workspace overlays: /opt/ros/melodic
          -- Found PythonInterp: /usr/bin/python2 (found suitable version "2.7.17", minimum required is "2")
          -- Using PYTHON_EXECUTABLE: /usr/bin/python2
          -- Using Debian Python package layout
          -- Using empy: /usr/bin/empy
          -- Using CATKIN_ENABLE_TESTING: ON
          -- Call enable_testing()
          -- Using CATKIN_TEST_RESULTS_DIR: /home/tian/catkin_ws/build/test_results
          -- Found gtest sources under '/usr/src/googletest': gtests will be built
          -- Found gmock sources under '/usr/src/googletest': gmock will be built
          -- Found PythonInterp: /usr/bin/python2 (found version "2.7.17")
          -- Using Python nosetests: /usr/bin/nosetests-2.7
          -- catkin 0.7.29
          -- BUILD_SHARED_LIBS is on
          -- ~~  traversing 1 packages in topological order:
          -- ~~  - learning_topic
          -- +++ processing catkin package: 'learning_topic'
          -- ==> add_subdirectory(learning_topic)
          -- Could NOT find styd_msgs (missing: styd_msgs_DIR)
          -- Could not find the required component 'styd_msgs'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
            been installed.
           *  History restored
            小鱼 技术大佬 @谁知
            @谁知 在 catkin_make报错 中说:
            styd_msgsConfig
            你的名字搞错了,std_msgs ,全程标准消息接口, styd_msgs自然找不到.
            谁知谁 1 条回复 最后回复 回复 引用 0
            • 谁知谁
              谁知 @小鱼
              @小鱼 我没有写过有关styd的代码鸭,请问应该怎样改动
                小鱼 技术大佬 @谁知
                @谁知 你在创建功能包的时候,手抖多敲了一个y,你自己没注意到而已,删掉重新创建一个即可.
                  小鱼 技术大佬 @谁知
                  @谁知 你看看键盘,t右边那个字母是不是y,明显是你手抖了
                  • 谁知谁
                    谁知 @小鱼
                    @小鱼 收到,我去实验下,谢谢
                    • 谁知谁
                      谁知 @小鱼
                      程序可以运行了!👍 👍 👍
                      小鱼,你是我的神!👍 👍 👍
