    《动手学Moveit2》3.安装Moveit2测试
    机械臂运动规划
    动手学moveit2 moveit2教程
    26
    57
    135.4k
      小鱼 技术大佬 @吨吨炖丸子
      @吨吨炖丸子 你的系统版本是?
      尽量提供更多的信息
      吨吨炖丸子吨 3 条回复 最后回复 回复 引用 0
      • 15223469361
        孤缘 @吨吨炖丸子
        @吨吨炖丸子 在 《动手学Moveit2》3.安装Moveit2 中说:
        鱼哥,这种问题你遇到过没
        --- stderr: moveit_ros_planning
        In file included from /home/wadd/moveit2_ws/src/moveit2/moveit_ros/planning/kinematics_plugin_loader/include/moveit/kinematics_plugin_loader/kinematics_plugin_loader.h:42,
                         from /home/wadd/moveit2_ws/src/moveit2/moveit_ros/planning/kinematics_plugin_loader/src/kinematics_plugin_loader.cpp:37:
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp: In member function ‘rcl_interfaces::msg::SetParametersResult kinematics::ParamListener::update(const std::vector<rclcpp::Parameter>&)’:
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:100:59: error: ‘gt_eq’ is not a member of ‘parameter_traits’
          100 |             if(auto validation_result = parameter_traits::gt_eq<double>(param, 0.0);
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:100:65: error: expected primary-expression before ‘double’
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:107:59: error: ‘gt’ is not a member of ‘parameter_traits’
          107 |             if(auto validation_result = parameter_traits::gt<double>(param, 0.0);
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:107:62: error: expected primary-expression before ‘double’
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp: In member function ‘void kinematics::ParamListener::declare_params()’:
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:153:53: error: ‘gt_eq’ is not a member of ‘parameter_traits’
          153 |       if(auto validation_result = parameter_traits::gt_eq<double>(param, 0.0);
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:153:59: error: expected primary-expression before ‘double’
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:159:53: error: ‘gt’ is not a member of ‘parameter_traits’
          159 |       if(auto validation_result = parameter_traits::gt<double>(param, 0.0);
        /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:159:56: error: expected primary-expression before ‘double’
        gmake[2]: *** [kinematics_plugin_loader/CMakeFiles/moveit_kinematics_plugin_loader.dir/build.make:76:kinematics_plugin_loader/CMakeFiles/moveit_kinematics_plugin_loader.dir/src/kinematics_plugin_loader.cpp.o] 错误 1
        gmake[1]: *** [CMakeFiles/Makefile2:460:kinematics_plugin_loader/CMakeFiles/moveit_kinematics_plugin_loader.dir/all] 错误 2
        gmake[1]: *** 正在等待未完成的任务....
        Failed   <<< moveit_ros_planning [2min 3s, exited with code 2]
        Summary: 13 packages finished [11min 29s]
          1 package failed: moveit_ros_planning
          2 packages had stderr output: moveit_configs_utils moveit_ros_planning
          24 packages not processed
        我也遇到了同样的错误,我是在 ros:humble-ros-base-jammy 的官方docker容器里跑的
        小鱼小 10127960511 2 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @1522346936
          @1522346936 将Moveit源码切换到2.5.3 tag试试,应该是跟ros2api相关,你把容器里的ros2版本也更新一下
          10127960511 15223469361 空白空 KarosK 4 条回复 最后回复 回复 引用 0
          • 10127960511
            Haha @小鱼
            @小鱼 鱼哥我也是一样的报错,可以具体说一下怎么解决吗,感谢!
            • 15223469361
              孤缘 @小鱼
              @小鱼 ros2需要更新到哪个版本,最新版本不就是humble吗?
                小鱼 技术大佬 @1522346936
                @1522346936 相同版本但某个包的api接口不一定不变,小版本还是在更新,humble只是一个维护的大版本代称
                • 空白空
                  空白 @小鱼
                  @小鱼 鱼哥我也遇到了一样的问题,版本是双系统ubuntu22.04 humble,完全按照步骤来的,然后最后一步出现了一模一样的问题
                  • 10127960511
                    Haha @1522346936
                    • KarosK
                      Karos @小鱼
                      最后由 Karos 编辑
                      @小鱼 https://moveit.picknik.ai/humble/doc/tutorials/getting_started/getting_started.html 鱼哥看看这个,好像是因为多了一个vcstool的安装,我按照这个来的很顺利
                        小鱼 技术大佬 @Karos
                        @Karos 好的,我测试下,然后更新下文档。
                        • 吨吨炖丸子吨
                          吨吨炖丸子 @小鱼
                          最后由 吨吨炖丸子 编辑
                          • 吨吨炖丸子吨
                            吨吨炖丸子 @小鱼
                            • 吨吨炖丸子吨
                              吨吨炖丸子 @小鱼
                              @小鱼 不好意思鱼哥,我这段时间没上网站,刚看到,我下次会注意。我的系统是22.04,ros2版本是humble,我按照你新发布的安装方法安装成功了,但是在安装过程中出现了以下几处异常的地方,请问有没有影响,该怎么解决?
                              --- stderr: launch_param_builder
                                warnings.warn(
                              Finished <<< launch_param_builder [1.23s]
                              Starting >>> rosparam_shortcuts
                              --- stderr: moveit_configs_utils
                                warnings.warn(
                              Finished <<< moveit_configs_utils [1.26s]
                              [Processing: moveit_setup_srdf_plugins]
                              --- stderr: moveit_setup_srdf_plugins
                              /home/wadd/moveit2_ws/src/moveit2/moveit_setup_assistant/moveit_setup_srdf_plugins/include/moveit_setup_srdf_plugins/rotated_header_view.hpp:0: Note: No relevant classes found. No output generated.
                              Finished <<< moveit_setup_srdf_plugins [4min 5s]
                                小鱼 技术大佬 @吨吨炖丸子
                                @吨吨炖丸子 前两个 SetuptoolsDeprecationWarning 错误之前有发过解决方案,你可以再右上角搜一下。
                                @小鱼 在 [常见问题]Colcon编译 Setuptools DeprecationWarning: setup.py install is deprecated. 中说:
                                该问题是使用Colcon编译Python功能包出现的。
                                --- stderr: example_parameters_rclpy
                                warnings.warn(
                                解决方案如下:
                                sudo pip install setuptools==58.2.0 --upgrade
                                至于另外一个错误应该也没关系,只是个warn。
                                另外下次可以新提一个帖子,这个楼盖的太高了,不好爬~哈
                                吨吨炖丸子吨 1 条回复 最后回复 回复 引用 0
                                • 吨吨炖丸子吨
                                  吨吨炖丸子 @小鱼
                                  @小鱼 好的鱼哥,感谢
                                  • 26306857122
                                    吕树
                                    小鱼如果要控制实际机械臂,但都是launch.py 文件我需要修改哪些东西
                                    • 8095858718
                                      Dream&#39;s蓝袍
                                      在配置助手生成的功能包里,config文件夹没有 ompl.ymal 的文件,是因为二进制安装的moveit2无法调用ompl库里的其他算法吗。
                                      1 条回复 最后回复 回复 引用 2
                                      • 降维煎饼兔降
                                        降维煎饼兔
                                        小鱼老师,这是什么问题?以前从没出现过。
                                        • 11989270601
                                          星河 @小鱼
                                          @小鱼 鱼哥,我的系统是ubuntu20.6,用你的一键安装,里面没有humble版本,只有rolling版本,咋回事
                                          • 11989270601
                                            星河
                                            在克隆moveit2_tutorials.repos的时候出现这么多错误,咋回事,鱼哥
                                            11989270601 1 条回复 最后回复 回复 引用 0
