『求助』
vscode 安装PlatformIO插件打开open一直显示loading,这个怎么解决
@小鱼 系统版本ubuntu22.04LTS,ROS2-humble版本,安装了PlatformIO插件,点击open,一直显示loading,报了如下错误:
Error: Error: Could not create PIO Core Virtual Environment. Please report to https://github.com/platformio/platformio-core-installer/issues -> Installer version: 1.1.2 Platform: Linux-5.19.0-41-generic-x86_64-with-glibc2.35
Python version: 3.10.6 (main, Mar 10 2023, 10:55:28) [GCC 11.3.0]
Python path: /usr/bin/python3
Creating a virtual environment at /home/pzh/.platformio/penv
/usr/bin/python3 at /home/pzh/.vscode/extensions/platformio.platformio-ide-3.0.0-linux-x64/node_modules/platformio-node-helpers/dist/index.js:1:5362
at ChildProcess.o (/home/pzh/.vscode/extensions/platformio.platformio-ide-3.0.0-linux-x64/node_modules/platformio-node-helpers/dist/index.js:1:4660)
at ChildProcess... -
@2567524644 换个网络环境试试
@小鱼 谢谢,解决了
