    fishbot小车的odom话题消息因为qos不对而接收不了
    fishbot ros2话题 qos
    679
    • siviechenS
      砖头
      我想要自己写一个节点来对fishbot小车发布的odom数据进行evo文件排版的储存,但是终端提示qos策略不对,/odom话题是best_effort。以下是此种情况的代码和日志:
      #!/usr/bin/env python3
      # -*- coding: utf-8 -*-
      import rclpy
      from rclpy.node import Node
      from nav_msgs.msg import Odometry
      from rclpy.qos import QoSProfile, QoSReliabilityPolicy, QoSHistoryPolicy
      class NodeToEvo(Node):
          def __init__(self,name):
              super().__init__(name)
              self.get_logger().info("transformation starts")
              self.subscribe = self.create_subscription(Odometry,"odom",self.callback,10)
              self.path = "/home/cxw"
              self.file = self.path + "/ground_truth_odom" + '.txt'
              self.writter = open(self.file,'w')
          def callback(self,msg):
              position = msg.pose.pose.position
              orientation = msg.pose.pose.orientation
              self.writter.write(position.x+'\t'+position.y+'\t'+position.z+'\t'+orientation.x+'\t'+orientation.y+'\t'+orientation.z+'\t'+orientation.w+'\n')
      def main(args=None):
          rclpy.init(args=args)
          node = NodeToEvo("ToEvo")
          rclpy.spin(node)
          node.destroy_node()
          rclpy.shutdown()
      然后启动microros接收小车的数据
      编译和source完后,ros2 run前面的py程序,日志报错如下:
      cxw@pc:~/dev_ws$ ros2 run learning_topic toEvo
      [INFO] [1691715773.163893894] [ToEvo]: transformation starts
      [WARN] [1691715774.291494228] [ToEvo]: New publisher discovered on topic 'odom', offering incompatible QoS. No messages will be received from it. Last incompatible policy: RELIABILITY
      然后查看小车odom的info:
      cxw@pc:~/dev_ws$ ros2 topic info --verbose /odom
      Type: nav_msgs/msg/Odometry
      Publisher count: 1
      Node name: fishbot_motion_control
      Node namespace: /
      Topic type: nav_msgs/msg/Odometry
      Endpoint type: PUBLISHER
      GID: 01.0f.bc.e6.2d.00.ca.28.01.00.00.00.00.00.01.03.00.00.00.00.00.00.00.00
      QoS profile:
        Reliability: BEST_EFFORT
        History (Depth): UNKNOWN
        Durability: VOLATILE
        Lifespan: Infinite
        Deadline: Infinite
        Liveliness: AUTOMATIC
      Subscription count: 0
      然后我去网上查,查到了一些在程序里修改qos策略的贴子,但是还是没有跑起来。修改后的代码:
      import rclpy
              qos_profile = QoSProfile(
      			reliability = QoSReliabilityPolicy.BEST_EFFORT,
      			history = QoSHistoryPolicy.UNKNOWN,
                  depth = 10
              self.subscribe = self.create_subscription(Odometry,"odom",self.callback,qos_profile)
          rclpy.spin(node)
          node.destroy_node()
          rclpy.shutdown()
      编译后运行的终端log:
      [INFO] [1691716079.532903710] [ToEvo]: transformation starts
      >>> [rcutils|error_handling.c:108] rcutils_set_error_state()
      This error state is being overwritten:
        'Unknown QoS history policy, at ./src/qos.cpp:61'
      with this new error message:
        'create_publisher() failed setting topic QoS, at ./src/subscription.cpp:221'
      rcutils_reset_error() should be called after error handling to avoid this.
        'create_publisher() failed setting topic QoS, at ./src/subscription.cpp:221, at ./src/rcl/subscription.c:108'
        'invalid allocator, at ./src/rcl/subscription.c:218'
        File "/home/cxw/dev_ws/install/learning_topic/lib/learning_topic/toEvo", line 33, in <module>
          sys.exit(load_entry_point('learning-topic==0.0.0', 'console_scripts', 'toEvo')())
        File "/home/cxw/dev_ws/install/learning_topic/lib/python3.10/site-packages/learning_topic/toEvo.py", line 34, in main
        File "/home/cxw/dev_ws/install/learning_topic/lib/python3.10/site-packages/learning_topic/toEvo.py", line 20, in __init__
        File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/node.py", line 1370, in create_subscription
          subscription_object = _rclpy.Subscription(
      rclpy._rclpy_pybind11.RCLError: Failed to create subscription: invalid allocator, at ./src/rcl/subscription.c:218
      这下我就找不到解答这个的贴子了,求大佬指教😳
        小鱼 技术大佬 @siviechen
        @siviechen 这样写
                    Odometry,
                    '/odom',
                    self.listener_callback,
                    rclpy.qos.qos_profile_sensor_data)
        siviechenS 2 条回复 最后回复 回复 引用 0
        • siviechenS
          砖头 @小鱼
          @小鱼 成功了,感谢小鱼👏
          • siviechenS
            砖头 @小鱼
            @小鱼 这个语句是指自动去匹配发布者的qos吗?
              小鱼 技术大佬 @siviechen
              @siviechen 不是,传感器类型是默认的best_effort
