fishbot小车的odom话题消息因为qos不对而接收不了
我想要自己写一个节点来对fishbot小车发布的odom数据进行evo文件排版的储存,但是终端提示qos策略不对,/odom话题是best_effort。以下是此种情况的代码和日志:
#!/usr/bin/env python3 # -*- coding: utf-8 -*- import rclpy from rclpy.node import Node from nav_msgs.msg import Odometry from rclpy.qos import QoSProfile, QoSReliabilityPolicy, QoSHistoryPolicy class NodeToEvo(Node): def __init__(self,name): super().__init__(name) self.get_logger().info("transformation starts") self.subscribe = self.create_subscription(Odometry,"odom",self.callback,10) self.path = "/home/cxw" self.file = self.path + "/ground_truth_odom" + '.txt' self.writter = open(self.file,'w') def callback(self,msg): position = msg.pose.pose.position orientation = msg.pose.pose.orientation self.writter.write(position.x+'\t'+position.y+'\t'+position.z+'\t'+orientation.x+'\t'+orientation.y+'\t'+orientation.z+'\t'+orientation.w+'\n') def main(args=None): rclpy.init(args=args) node = NodeToEvo("ToEvo") rclpy.spin(node) node.destroy_node() rclpy.shutdown()然后启动microros接收小车的数据
sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged --net=host microros/micro-ros-agent:$ROS_DISTRO udp4 --port 8888 -v6编译和source完后,ros2 run前面的py程序,日志报错如下:
cxw@pc:~/dev_ws$ ros2 run learning_topic toEvo [INFO] [1691715773.163893894] [ToEvo]: transformation starts [WARN] [1691715774.291494228] [ToEvo]: New publisher discovered on topic 'odom', offering incompatible QoS. No messages will be received from it. Last incompatible policy: RELIABILITY然后查看小车odom的info:
cxw@pc:~/dev_ws$ ros2 topic info --verbose /odom Type: nav_msgs/msg/Odometry Publisher count: 1 Node name: fishbot_motion_control Node namespace: / Topic type: nav_msgs/msg/Odometry Endpoint type: PUBLISHER GID: 01.0f.bc.e6.2d.00.ca.28.01.00.00.00.00.00.01.03.00.00.00.00.00.00.00.00 QoS profile: Reliability: BEST_EFFORT History (Depth): UNKNOWN Durability: VOLATILE Lifespan: Infinite Deadline: Infinite Liveliness: AUTOMATIC Liveliness lease duration: Infinite Subscription count: 0然后我去网上查,查到了一些在程序里修改qos策略的贴子,但是还是没有跑起来。修改后的代码:
import rclpy from rclpy.node import Node from nav_msgs.msg import Odometry from rclpy.qos import QoSProfile, QoSReliabilityPolicy, QoSHistoryPolicy class NodeToEvo(Node): def __init__(self,name): super().__init__(name) qos_profile = QoSProfile( reliability = QoSReliabilityPolicy.BEST_EFFORT, history = QoSHistoryPolicy.UNKNOWN, depth = 10 ) self.get_logger().info("transformation starts") self.subscribe = self.create_subscription(Odometry,"odom",self.callback,qos_profile) self.path = "/home/cxw" self.file = self.path + "/ground_truth_odom" + '.txt' self.writter = open(self.file,'w') def callback(self,msg): position = msg.pose.pose.position orientation = msg.pose.pose.orientation self.writter.write(position.x+'\t'+position.y+'\t'+position.z+'\t'+orientation.x+'\t'+orientation.y+'\t'+orientation.z+'\t'+orientation.w+'\n') def main(args=None): rclpy.init(args=args) node = NodeToEvo("ToEvo") rclpy.spin(node) node.destroy_node() rclpy.shutdown()编译后运行的终端log:
cxw@pc:~/dev_ws$ ros2 run learning_topic toEvo [INFO] [1691716079.532903710] [ToEvo]: transformation starts >>> [rcutils|error_handling.c:108] rcutils_set_error_state() This error state is being overwritten: 'Unknown QoS history policy, at ./src/qos.cpp:61' with this new error message: 'create_publisher() failed setting topic QoS, at ./src/subscription.cpp:221' rcutils_reset_error() should be called after error handling to avoid this. <<< >>> [rcutils|error_handling.c:108] rcutils_set_error_state() This error state is being overwritten: 'create_publisher() failed setting topic QoS, at ./src/subscription.cpp:221, at ./src/rcl/subscription.c:108' with this new error message: 'invalid allocator, at ./src/rcl/subscription.c:218' rcutils_reset_error() should be called after error handling to avoid this. <<< invalid allocator, at ./src/rcl/subscription.c:218 Traceback (most recent call last): File "/home/cxw/dev_ws/install/learning_topic/lib/learning_topic/toEvo", line 33, in <module> sys.exit(load_entry_point('learning-topic==0.0.0', 'console_scripts', 'toEvo')()) File "/home/cxw/dev_ws/install/learning_topic/lib/python3.10/site-packages/learning_topic/toEvo.py", line 34, in main node = NodeToEvo("ToEvo") File "/home/cxw/dev_ws/install/learning_topic/lib/python3.10/site-packages/learning_topic/toEvo.py", line 20, in __init__ self.subscribe = self.create_subscription(Odometry,"odom",self.callback,qos_profile) File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/node.py", line 1370, in create_subscription subscription_object = _rclpy.Subscription( rclpy._rclpy_pybind11.RCLError: Failed to create subscription: invalid allocator, at ./src/rcl/subscription.c:218 [ros2run]: Process exited with failure 1这下我就找不到解答这个的贴子了,求大佬指教
@siviechen 这样写
from nav_msgs.msg import Odometry self.subscription = self.create_subscription( Odometry, '/odom', self.listener_callback, rclpy.qos.qos_profile_sensor_data) -
@小鱼 成功了,感谢小鱼
@小鱼 这个语句是指自动去匹配发布者的qos吗?
@siviechen 不是,传感器类型是默认的best_effort
