    Gazebo与RViz联合仿真时odom消失
    17.7k
    • 9
      924453613
      最后由 924453613 编辑
      irobot.urdf
      <?xml version="1.0" encoding="utf-8"?>
      <robot
        name="irobot">
        <link
          name="base_footprint">
          <visual>
            <geometry>
              <sphere
                radius="0.001" />
            </geometry>
            <material
              name="">
              <color
                rgba="0 0 0 0" />
            </material>
          </visual>
        </link>
        <link
          name="base_link">
          <inertial>
            <origin
              xyz="0.0353 6.2375E-05 0.0378"
              rpy="0 0 0" />
            <mass
              value="4.4466" />
            <inertia
              ixx="0.037776"
              ixy="0"
              ixz="0"
              iyy="0.026331"
              iyz="0"
              izz="0.060251" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://irobot/meshes/base_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="0 0 0 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="base_link2base_footprint"
          type="fixed">
              <parent
                link="base_footprint" />
              <child
                link="base_link" />
              <origin
                xyz="0 0 0.011" />
              <!--irobot_height/2-->
        </joint>
        <link
          name="top_link">
          <inertial>
            <origin
              xyz="-0.005083 -0.000153 0.000877"
              rpy="0 0 0" />
            <mass
              value="0.11187" />
            <inertia
              ixx="0.0008137"
              ixy="0"
              ixz="0"
              iyy="0.00071"
              iyz="0"
              izz="0.001524" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://irobot/meshes/top_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="0 1 0 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="top_joint"
          type="fixed">
          <origin
            xyz="0 0 0.0699"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="top_link" />
          <axis
            xyz="0 0 0" />
          <limit
            lower="0"
            upper="0"
            effort="0"
            velocity="0" />
        </joint>
        <link
          name="laser_link">
          <inertial>
            <origin
              xyz="-4.0578E-09 2.09E-09 0.00303"
              rpy="0 0 0" />
            <mass
              value="0.001737" />
            <inertia
              ixx="4.1116E-08"
              ixy="0"
              ixz="0"
              iyy="4.1116E-08"
              iyz="0"
              izz="7.8771E-08" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://irobot/meshes/laser_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 0 0 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="laser_joint"
          type="fixed">
          <origin
            xyz="0.155 0 0.07433"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="laser_link" />
          <axis
            xyz="0 0 0" />
          <limit
            lower="0"
            upper="0"
            effort="0"
            velocity="0" />
        </joint>
        <link
          name="driven_link">
          <inertial>
            <origin
              xyz="0 -4.6809E-19 4.3368E-19"
              rpy="0 0 0" />
            <mass
              value="0.014137" />
            <inertia
              ixx="1.2723E-06"
              ixy="0"
              ixz="0"
              iyy="1.2723E-06"
              iyz="0"
              izz="1.2723E-06" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://irobot/meshes/driven_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="driven_joint"
          type="continuous">
          <origin
            xyz="0.13 0 0.00438"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="driven_link" />
          <axis
            xyz="0 0 1" />
          <limit
            lower="-3.14"
            upper="3.14"
            effort="0"
            velocity="0" />
        </joint>
        <link
          name="left_wheel_link">
          <inertial>
            <origin
              xyz="5.9165E-31 -1.3878E-17 3.4694E-18"
              rpy="0 0 0" />
            <mass
              value="0.066366" />
            <inertia
              ixx="2.2972E-05"
              ixy="0"
              ixz="0"
              iyy="2.2972E-05"
              iyz="0"
              izz="4.3005E-05" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://irobot/meshes/left_wheel_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="left_wheel_joint"
          type="continuous">
          <origin
            xyz="0 -0.10045 0.02538"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="left_wheel_link" />
          <axis
            xyz="0 -1 0" />
          <limit
            lower="-3.14"
            upper="3.14"
            effort="0"
            velocity="0" />
        </joint>
        <link
          name="right_wheel_link">
          <inertial>
            <origin
              xyz="-1.5766E-18 1.3878E-17 3.4694E-18"
              rpy="0 0 0" />
            <mass
              value="0.066366" />
            <inertia
              ixx="2.2972E-05"
              ixy="0"
              ixz="0"
              iyy="2.2972E-05"
              iyz="0"
              izz="4.3005E-05" />
          </inertial>
          <visual>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
                filename="package://irobot/meshes/right_wheel_link.STL" />
            </geometry>
            <material
              name="">
              <color
                rgba="1 1 1 1" />
            </material>
          </visual>
          <collision>
            <origin
              xyz="0 0 0"
              rpy="0 0 0" />
            <geometry>
              <mesh
            </geometry>
          </collision>
        </link>
        <joint
          name="right_wheel_joint"
          type="continuous">
          <origin
            xyz="0 0.10045 0.02538"
            rpy="0 0 0" />
          <parent
            link="base_link" />
          <child
            link="right_wheel_link" />
          <axis
            xyz="0 -1 0" />
          <limit
            lower="-3.14"
            upper="3.14"
            effort="0"
            velocity="0" />
        </joint>
      <!--color-->
        <gazebo reference="base_link">
        </gazebo>
        <gazebo reference="top_link">
          <material>Gazebo/Green</material>
        </gazebo>
          <material>Gazebo/Red</material>
        </gazebo>
        <gazebo reference="camera_link">
        </gazebo>
        <gazebo reference="driven_link">
          <material>Gazebo/White</material>
        </gazebo>
        <gazebo reference="left_wheel_link">
        </gazebo>
        <gazebo reference="right_wheel_link">
        </gazebo>
        <!-- controller -->
        <transmission name="left_wheel_joint_trans">
          <type>transmission_interface/SimpleTransmission</type>
          <joint name="left_wheel_joint">
            <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface>
          </joint>
          <actuator name="left_wheel_joint_motor">
            <mechanicalReduction>1</mechanicalReduction>
          </actuator>
        </transmission>
        <transmission name="right_wheel_joint_trans">
          <joint name="right_wheel_joint">
          </joint>
          <actuator name="right_wheel_joint_motor">
          </actuator>
        </transmission>
        <gazebo>
          <plugin filename="libgazebo_ros_diff_drive.so" name="differential_drive_controller">
            <rosDebugLevel>Debug</rosDebugLevel>
            <publishWheelTF>true</publishWheelTF>
            <robotNamespace>/</robotNamespace>
            <publishTf>1</publishTf>
            <publishWheelJointState>true</publishWheelJointState>
            <alwaysOn>true</alwaysOn>
            <updateRate>100.0</updateRate>
            <legacyMode>true</legacyMode>
            <leftJoint>left_wheel_joint</leftJoint>
            <rightJoint>right_wheel_joint</rightJoint>
            <wheelSeparation>0.277</wheelSeparation>
            <wheelDiameter>0.073</wheelDiameter>
            <broadcastTF>1</broadcastTF>
            <wheelTorque>30</wheelTorque>
            <wheelAcceleration>1.8</wheelAcceleration>
            <commandTopic>cmd_vel</commandTopic>
            <odometryFrame>odom</odometryFrame>
            <odometryTopic>odom</odometryTopic>
            <robotBaseFrame>base_footprint</robotBaseFrame>
          </plugin>
        </gazebo>
        <!--laser-->
          <sensor name="rplidar" type="ray">
            <pose>0 0 0 0 0 0</pose>
            <visualize>true</visualize>
            <update_rate>5.5</update_rate>
            <ray>
              <scan>
                <horizontal>
                  <samples>360</samples>
                  <resolution>1</resolution>
                  <min_angle>-3</min_angle>
                  <max_angle>3</max_angle>
                </horizontal>
              </scan>
              <range>
                <min>0.10</min>
                <max>30.0</max>
                <resolution>0.01</resolution>
              </range>
              <noise>
                <type>gaussian</type>
                <mean>0.0</mean>
                <stddev>0.01</stddev>
              </noise>
            </ray>
            <plugin filename="libgazebo_ros_laser.so" name="gazebo_rplidar">
              <topicName>/scan</topicName>
              <frameName>laser_link</frameName>
            </plugin>
          </sensor>
        </gazebo>
      </robot>
      odom_gazebo.launch
      <launch>
        <param
          name="robot_description"
          textfile="$(find irobot)/urdf/irobot.urdf" />
        <include
          file="$(find gazebo_ros)/launch/empty_world.launch"/>
        <node
          name="tf_footprint_base"
          pkg="tf"
          type="static_transform_publisher"
          args="0 0 0 0 0 0 base_link base_footprint 40" />
        <node
          pkg="gazebo_ros"
          type="spawn_model"
          name="model"
          args="-urdf -model irobot -param robot_description"  />
        <node
          name="fake_joint_calibration"
          pkg="rostopic"
          type="rostopic"
          args="pub /calibrated std_msgs/Bool true" />
      </launch>
      odom_rviz.launch
      <launch>
          <param
        <node
          name="rviz"
          pkg="rviz"
          type="rviz"
          args="-d $(find irobot)/config/irobot.rviz" />
        <node
          name="joint_state_publisher_gui"
          pkg="joint_state_publisher_gui"
          type="joint_state_publisher_gui" />
        <node
          name="robot_state_publisher"
          pkg="robot_state_publisher"
          type="robot_state_publisher" />
        <node name="arbotix" pkg="arbotix_python" type="arbotix_driver" output="screen">
          <rosparam file="$(find irobot)/config/diff_controller.yaml" command="load" />
          <param name="sim" value="true" />
        </node>
      </launch>
        小鱼 技术大佬
        初步估计是TF问题,晚点我看一下,代码可以改成用代码块包裹一下,太长了,不好看。
        • 9
          924453613
          小伊小 1 条回复 最后回复 回复 引用 0
            机器人小伊 @924453613
            @924453613 每个帖子都可以再次编辑和删除的,不用再发一个哈哈,菜单在右下角。
              小鱼 技术大佬 @924453613
              @924453613
              需要补充一些内容
              • 补充一下rqt_tf_tree的截图
              • 补充一下gazebo版本系统版本和ros版本
              • 补充config/diff_controller.yaml文件内容
              同时做如下的尝试:
              • 从odom_rviz.launch删除arbotix节点后运行
              • 9
                924453613
                rqt_tf_tree
                ubuntu18.04-melodic-gazebo11
                # 该文件是控制器配置,一个机器人模型可能有多个控制器,比如: 底盘、机械臂、夹持器(机械手)....
                # 因此,根 name 是 controller
                controllers: {
                   # 单控制器设置
                   base_controller: {
                          #类型: 差速控制器
                       type: diff_controller,
                       #参考坐标
                       base_frame_id: base_footprint,
                       #两个轮子之间的间距
                       base_width: 0.277,
                       #控制频率
                       ticks_meter: 2000,
                       #PID控制参数,使机器人车轮快速达到预期速度
                       Kp: 12,
                       Kd: 12,
                       Ki: 0,
                       Ko: 50,
                       #加速限制
                       accel_limit: 1.0
                删除arbotix结果
                  小鱼 技术大佬 @924453613
                  @924453613 看一下rqt_grapher,有几个joint_states的发布者。
                  9 1 条回复 最后回复 回复 引用 0
                  • 9
                    924453613 @小鱼
                    @小鱼 只有一个
                      小鱼 技术大佬 @924453613
                      @924453613 这个rqt_graph看起来非常不对劲。因为两轮差速这边也会发布机器人的joint_states,所以不需要再启动joint_state_publisher。
                      修改odom_rviz.py
                      <launch>
                          <param
                        <node
                          name="rviz"
                          pkg="rviz"
                          type="rviz"
                        <node
                        </node>
                      </launch>
                      • 9
                        924453613 @小鱼
                        @小鱼 有rqt_graph了 RViz中tf还是断开的
                          小鱼 技术大佬 @924453613
                          @924453613 你看这里,一个话题有两个发布者,robot_state_publisher都不知道听谁的,所以导致TF错误,按照我上一条回复把joint_state_publisher干掉试试。
                          • 9
                            924453613 @小鱼
                            最后由 924453613 编辑
                            干掉之后是这样的 RViz中tf还是断开的
                              小鱼 技术大佬 @924453613
                              @924453613 现在还是有两个发布者在发布joint_states,只需要一个gazebo即可,请按照之前帖子里的提示删掉arbotix控制器程序。
                              另外需要注意的是,arbotix的功能和urdf中配置的differential_drive_controller功能是相同(从两者的配置可以看出,都有轮子名称,轮子间距等配置),但differential_drive_controller才是用于gazebo仿真使用的。
                              • 9
                                924453613 @小鱼
                                @小鱼 感谢鱼总这么晚还在解答我的问题 我删除arbotix后 我重新查看tf树发现以下问题
                                1.odom到base_link断开
                                2.tf树与最初发布帖子时不同
                                134c18e1-4b0f-444f-b50e-7eb83f18b6f8-图片.png 6a5ec88e-d9c5-4a38-845e-653cfe0cb7cb-图片.png
                                rqt_graph如下
                                  小鱼 技术大佬 @924453613
                                  @924453613 首先恭喜你,离成功越来越近了,注意两轮差速模型的配置项robotBaseFrame,该项为其发布的joint_states参考的frame名称。
                                      </plugin>
                                  尝试进一步修改:
                                  1. 将 <robotBaseFrame>的base_footprint->base_link,这样gazebo发布数据时应该会将base_link->left/right_joint
                                  2. 尝试删除静态发布footprint->base_link,因为在我看来,它也是多余的,两者之间的关系在URDF中已经给出。
                                    <node
                                      pkg="tf"
                                  • 9
                                    924453613 @小鱼
                                    @小鱼 感谢鱼总,目前tf树仍有问题,夜已深鱼总早点休息,明早我会继续尝试,非常感谢。
                                      小鱼 技术大佬 @924453613
                                      @924453613 ok,目前看到对应的tf还是没有链接起来,需要注意的地方就是上文中提到的,可以多次修改尝试,祝早日成功,早点休息。
                                      • 9
                                        924453613 @小鱼
                                        @小鱼 非常感谢鱼总的解答目前已经解决,问题大概率是出现在odom_rviz.launch中重复出现了/arbotix,导致tf树出错了,谢谢👍
                                          小鱼 技术大佬 @924453613
                                          @924453613 很高兴能够看到该问题被解决掉,如果方便可以贴一下解决后的代码在本帖子中,方便其他小伙伴在遇到相同问题提供帮助。
                                          • 9
                                            924453613
                                            解决后代码:
                                            irobot.urdf
                                            <robot
                                              name="irobot">
                                              <link
                                                name="base_link">
                                                <inertial>
                                                  <origin
                                                    xyz="0.035298 6.2375E-05 0.0016857"
                                                    rpy="0 0 0" />
                                                  <mass
                                                    value="5" />
                                                  <inertia
                                                    ixx="0.038"
                                                    ixy="0"
                                                    ixz="0"
                                                    iyy="0.026"
                                                    iyz="0"
                                                    izz="0.06" />
                                                </inertial>
                                                <visual>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                  </geometry>
                                                  <material
                                                    name="">
                                                    <color
                                                      rgba="0 0 0 1" />
                                                  </material>
                                                </visual>
                                                <collision>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                  </geometry>
                                                </collision>
                                              </link>
                                              <link
                                                name="top_link">
                                                <inertial>
                                                  <origin
                                                    xyz="-0.0050829 -0.00015289 0.0008765"
                                                    rpy="0 0 0" />
                                                  <mass
                                                    value="0.2" />
                                                  <inertia
                                                    ixx="0.00081"
                                                    ixy="0"
                                                    ixz="0"
                                                    iyy="0.00071"
                                                    iyz="0"
                                                    izz="0.0015" />
                                                </inertial>
                                                <visual>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                  </geometry>
                                                  <material
                                                    name="">
                                                    <color
                                                      rgba="0 1 0 1" />
                                                  </material>
                                                </visual>
                                                <collision>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                  </geometry>
                                                </collision>
                                              </link>
                                              <joint
                                                name="top_link2base_link"
                                                type="fixed">
                                                <origin
                                                  xyz="0 0 0.033795"
                                                  rpy="0 0 0" />
                                                <parent
                                                  link="base_link" />
                                                <child
                                                  link="top_link" />
                                                <axis
                                                  xyz="0 -1 0" />
                                                <limit
                                                  lower="0"
                                                  upper="0"
                                                  effort="0"
                                                  velocity="0" />
                                              </joint>
                                              <link
                                                name="laser_link">
                                                <inertial>
                                                  <origin
                                                    xyz="1.1845E-09 4.4075E-09 0.0030295"
                                                    rpy="0 0 0" />
                                                  <mass
                                                    value="0.1" />
                                                  <inertia
                                                    ixx="4.11E-08"
                                                    ixy="0"
                                                    ixz="0"
                                                    iyy="4.11E-08"
                                                    iyz="0"
                                                    izz="7.88E-08" />
                                                </inertial>
                                                <visual>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                  </geometry>
                                                  <material
                                                    name="">
                                                    <color
                                                      rgba="1 0 0 1" />
                                                  </material>
                                                </visual>
                                                <collision>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                  </geometry>
                                                </collision>
                                              </link>
                                              <joint
                                                name="laser_link2base_link"
                                                type="fixed">
                                                <origin
                                                  xyz="0.155 0 0.038215"
                                                  rpy="0 0 0" />
                                                <parent
                                                  link="base_link" />
                                                <child
                                                <axis
                                                  xyz="0 -1 0" />
                                                <limit
                                                  lower="0"
                                                  upper="0"
                                                  effort="0"
                                                  velocity="0" />
                                              </joint>
                                              <link
                                                name="right_wheel">
                                                <inertial>
                                                  <origin
                                                    xyz="-1.0317E-18 1.3878E-17 -1.7347E-18"
                                                    rpy="0 0 0" />
                                                  <mass
                                                    value="0.05" />
                                                  <inertia
                                                    ixx="2.3E-05"
                                                    ixy="0"
                                                    ixz="0"
                                                    iyy="4.3E-05"
                                                    iyz="0"
                                                    izz="2.3E-05" />
                                                </inertial>
                                                <visual>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                      filename="package://irobot/meshes/right_wheel.STL" />
                                                  </geometry>
                                                  <material
                                                    name="">
                                                    <color
                                                      rgba="1 1 1 1" />
                                                  </material>
                                                </visual>
                                                <collision>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                  </geometry>
                                                </collision>
                                              </link>
                                              <joint
                                                name="right_wheel2base_link"
                                                type="continuous">
                                                <origin
                                                  xyz="0 0.10045 -0.010735"
                                                  rpy="0 0 0" />
                                                <parent
                                                  link="base_link" />
                                                <child
                                                  link="right_wheel" />
                                                <axis
                                                  xyz="0 -1 0" />
                                                <limit
                                                  lower="-3.14"
                                                  upper="3.14"
                                                  effort="100"
                                                  velocity="2" />
                                              </joint>
                                              <link
                                                name="left_wheel">
                                                <inertial>
                                                  <origin
                                                    xyz="-1.1842E-18 0 -1.7347E-18"
                                                    rpy="0 0 0" />
                                                  <mass
                                                    value="0.05" />
                                                  <inertia
                                                    ixx="2.3E-05"
                                                    ixy="0"
                                                    ixz="0"
                                                    iyy="4.3E-05"
                                                    iyz="0"
                                                    izz="2.3E-05" />
                                                </inertial>
                                                <visual>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                      filename="package://irobot/meshes/left_wheel.STL" />
                                                  </geometry>
                                                  <material
                                                    name="">
                                                    <color
                                                      rgba="1 1 1 1" />
                                                  </material>
                                                </visual>
                                                <collision>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                  </geometry>
                                                </collision>
                                              </link>
                                              <joint
                                                name="left_wheel2base_link"
                                                type="continuous">
                                                <origin
                                                  xyz="0 -0.10045 -0.010735"
                                                  rpy="0 0 0" />
                                                <parent
                                                  link="base_link" />
                                                <child
                                                  link="left_wheel" />
                                                <axis
                                                  xyz="0 -1 0" />
                                                <limit
                                                  lower="-3.14"
                                                  upper="3.14"
                                                  effort="100"
                                                  velocity="2" />
                                              </joint>
                                              <link
                                                name="driven_wheel">
                                                <inertial>
                                                  <origin
                                                    xyz="0 -3.4443E-19 0"
                                                    rpy="0 0 0" />
                                                  <mass
                                                    value="0.02" />
                                                  <inertia
                                                    ixx="1.27E-06"
                                                    ixy="0"
                                                    ixz="0"
                                                    iyy="1.27E-06"
                                                    iyz="0"
                                                    izz="1.27E-06" />
                                                </inertial>
                                                <visual>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                      filename="package://irobot/meshes/driven_wheel.STL" />
                                                  </geometry>
                                                  <material
                                                    name="">
                                                    <color
                                                      rgba="1 1 1 1" />
                                                  </material>
                                                </visual>
                                                <collision>
                                                  <origin
                                                    xyz="0 0 0"
                                                    rpy="0 0 0" />
                                                  <geometry>
                                                    <mesh
                                                  </geometry>
                                                </collision>
                                              </link>
                                              <joint
                                                name="driven_wheel2base_link"
                                                type="fixed">
                                                <origin
                                                  xyz="0.13 0 -0.031735"
                                                  rpy="0 0 0" />
                                                <parent
                                                  link="base_link" />
                                                <child
                                                  link="driven_wheel" />
                                                <axis
                                                  xyz="0 -1 0" />
                                                <limit
                                                  lower="0"
                                                  upper="0"
                                                  effort="0"
                                                  velocity="0" />
                                              </joint>
                                              <link
                                                <visual>
                                                  <geometry>
                                                    <sphere
                                                      radius="0.001" />
                                                  </geometry>
                                                  <material
                                                    name="">
                                                    <color
                                                      rgba="0 0 0 0" />
                                                  </material>
                                                </visual>
                                              </link>
                                              <joint
                                                type="fixed">
                                                    <parent
                                                    <child
                                                      link="base_link" />
                                                    <origin
                                                      xyz="0 0 0.047" />
                                              </joint>
                                            <!--color-->
                                              </gazebo>
                                              </gazebo>
                                              </gazebo>
                                              </gazebo>
                                              <gazebo reference="driven_wheel">
                                              </gazebo>
                                              <gazebo reference="left_wheel">
                                              </gazebo>
                                              <gazebo reference="right_wheel">
                                              </gazebo>
                                              <!-- controller -->
                                              <transmission name="left_wheel2base_link_trans">
                                                <joint name="left_wheel2base_link">
                                                </joint>
                                                <actuator name="left_wheel2base_link_motor">
                                                </actuator>
                                              </transmission>
                                              <transmission name="right_wheel2base_link_trans">
                                                <joint name="right_wheel2base_link">
                                                </joint>
                                                <actuator name="right_wheel2base_link_motor">
                                                </actuator>
                                              </transmission>
                                              <gazebo>
                                                  <leftJoint>left_wheel2base_link</leftJoint>
                                                  <rightJoint>right_wheel2base_link</rightJoint>
                                                </plugin>
                                              </gazebo>
                                              <!--laser-->
                                                  <ray>
                                                    <scan>
                                                      <horizontal>
                                                      </horizontal>
                                                    </scan>
                                                    <range>
                                                      <min>0.10</min>
                                                      <max>30.0</max>
                                                    </range>
                                                    <noise>
                                                      <mean>0.0</mean>
                                                    </noise>
                                                  </ray>
                                                  </plugin>
                                                </sensor>
                                              </gazebo>
                                            </robot>
                                            odom_gazebo.launch
                                            <launch>
                                              <include
                                                file="$(find gazebo_ros)/launch/empty_world.launch" />
                                              <node
                                                name="spawn_model"
                                                pkg="gazebo_ros"
                                                type="spawn_model"
                                                args="-file $(find irobot)/urdf/irobot.urdf -urdf -model irobot"
                                                output="screen" />
                                              <node
                                                pkg="rostopic"
                                                type="rostopic"
                                            </launch>
                                            odom_rviz.launch
                                            <launch>
                                              <param
                                              <node
                                              <node
                                              <node
                                                name="rviz"
                                                pkg="rviz"
                                                type="rviz"
                                            </launch>
                                            • 小鱼小 小鱼 将这个主题转为问答主题,在
                                            • 小鱼小 小鱼 将这个主题标记为已解决,在
