    动手学ros2 catrographer建图,没有/map话题但是Rviz2中不显示,Rviz2里也看不到雷达
    ros2 humble rviz2不能显示模型问题 rviz2不显示
    1.9k
    • 11941006571
      @灵思皇后
      c015de47-ccf0-4368-b688-ae12fc1e5b88-Screenshot-3.png /home/ljy/图片/Screenshot-3.png
      ac4c93ea-1b6d-4e32-ac03-55e394f755ba-Screenshot-5.png /home/ljy/图片/Screenshot-5.png
      4cc1ce4a-e51f-40d9-9401-f5a4e7ba61a3-Screenshot-6.png /home/ljy/图片/Screenshot-6.png
      这是cmakelists
      project(fishbot_cartographer)
      endif()
      install(
        DIRECTORY config launch rviz
        DESTINATION share/${PROJECT_NAME}
      # find dependencies
      if(BUILD_TESTING)
        # comment the line when a copyright and license is added to all source files
        # comment the line when this package is in a git repo and when
        # a copyright and license is added to all source files
      endif()
      ament_package()
      ROS2学习 第十章 3. 配置Fishbot进行建图
      有时候运行node list里有/map话题,但是rviz2里不显示有。把install那几句换了几个位置也都不对。
        小鱼 技术大佬 @1194100657
        @1194100657 直接运行slam_toolbox 建图试试:
        ros2 launch slam_toolbox online_async_launch.py use_sim_time:=False
        [INFO] [launch]: All log files can be found below /home/fishros/.ros/log/2023-10-02-22-52-36-917373-fishros-linux-79801
        [INFO] [async_slam_toolbox_node-1]: process started with pid [79802]
        [async_slam_toolbox_node-1] [INFO] [1696258356.969203979] [slam_toolbox]: Node using stack size 40000000
        [async_slam_toolbox_node-1] [INFO] [1696258356.987488838] [slam_toolbox]: Using solver plugin solver_plugins::CeresSolver
        [async_slam_toolbox_node-1] [INFO] [1696258356.987606280] [slam_toolbox]: CeresSolver: Using SCHUR_JACOBI preconditioner.
        [async_slam_toolbox_node-1] [WARN] [1696258357.129191771] [slam_toolbox]: maximum laser range setting (20.0 m) exceeds the capabilities of the used Lidar (8.0 m)
          尼古拉斯斯斯
          我也遇到同样的问题呀,不得其解,你解决了么?
          10293022331 1 条回复 最后回复 回复 引用 0
          • 10293022331
            1029302233 @yangchunlong1987
            @yangchunlong1987 我也是这个问题,就用那个存起来的图片,然后开启rviz2,加载地图,rviz2就是显示没有收到/map,好奇怪
