    MicroRos 学习笔记2 创建节点/消息使用
    MicroROS
    microros stm32 ros2 humble
    • 26762394302
      Tony Kerman
      MicroROS 官方demo: github
      创建rclc 节点
      创建一个最小的rclc节点,由于没有使用executor,所以该节点只能使用 publisher
      环境: stm32+freeRTOS 使用串口DMA传输方式
      // include rclc
      #include <rcl/rcl.h>
      #include <rcl/error_handling.h>
      #include <rclc/rclc.h>
      #include <rclc/executor.h>
      #include <uxr/client/transport.h>
      #include <rmw_microxrcedds_c/config.h>
      #include <rmw_microros/rmw_microros.h>
      //include 使用的msgs
      #include <std_msgs/msg/int32_multi_array.h>
      //当本文件是.cpp文件时
      #ifdef __cplusplus
      extern "C"
      #endif
      bool cubemx_transport_open(struct uxrCustomTransport * transport);
      bool cubemx_transport_close(struct uxrCustomTransport * transport);
      size_t cubemx_transport_write(struct uxrCustomTransport* transport, const uint8_t * buf, size_t len, uint8_t * err);
      size_t cubemx_transport_read(struct uxrCustomTransport* transport, uint8_t* buf, size_t len, int timeout, uint8_t* err);
      void * microros_allocate(size_t size, void * state);
      void microros_deallocate(void * pointer, void * state);
      void * microros_reallocate(void * pointer, size_t size, void * state);
      void * microros_zero_allocate(size_t number_of_elements, size_t size_of_element, void * state);
      //当本文件是.cpp文件时
      #ifdef __cplusplus
      #endif
      // micro-ROS 节点线程
      void UserStartDefaultTask(void *argument)
          // micro-ROS configuration
          if(rmw_uros_set_custom_transport(
                  true,
                  (void *) &huart6, //修改为通信串口
                  cubemx_transport_open,
                  cubemx_transport_close,
                  cubemx_transport_write,
                  cubemx_transport_read) == RMW_RET_ERROR)
          rcl_allocator_t freeRTOS_allocator = rcutils_get_zero_initialized_allocator();
          freeRTOS_allocator.allocate = microros_allocate;
          freeRTOS_allocator.deallocate = microros_deallocate;
          freeRTOS_allocator.reallocate = microros_reallocate;
          freeRTOS_allocator.zero_allocate =  microros_zero_allocate;
          if (!rcutils_set_default_allocator(&freeRTOS_allocator)) {
              //printf("Error on default allocators (line %d)\n", __LINE__);
          // micro-ROS app
          rclc_support_t support;
          rcl_allocator_t allocator;
          rcl_node_t node;
          //create init_options  Note:这里卡死,可能原因:没打开串口中断
          // 创建 node
          rclc_node_init_default(&node, "stm32_node", "", &support);
          for(;;)
              HAL_GPIO_TogglePin(LDG_GPIO_Port, LDG_Pin);
              osDelay(300);
      编译运行时,要在上位机打开MicroRos agent 否则程序会卡在初始化中
      rclc Msg 消息使用
      消息分为两种 不带MultiArray的和带MultiArray的,初始化方法有所不同
      示例
      Int32
      不带MultiArray的msg,例如 Int32 Pose2d等
      使用方法比较方便
      //创建
      std_msgs__msg__Int32 msg;
      //使用
      msg.data++;
      Int32MultiArray
      带MultiArray的msg在使用前要手动分配内存
      // 创建
      std_msgs__msg__Int32MultiArray msg;
      //rclc_publisher_init_default()放在这里
      // 初始化 Int32MultiArray 消息
      std_msgs__msg__Int32MultiArray__init(&multi_array_msg);
      //为数组类消息分配内存
      multi_array_msg.data.capacity = 5;
      multi_array_msg.data.size = 5;
      multi_array_msg.data.data = (int32_t *)malloc(sizeof(int32_t) * 5);
      其中 multi_array_msg.data.data = (int32_t *)malloc(sizeof(int32_t) * 5);
      也可以改成
      char array_buf[5];
      multi_array_msg.data.data=array_buf;
      或使用FreeRTOS 提供的pvPortMalloc
      Tips
      1. 可以使用Freertos创建其他线程,但是不要在其中使用micro_ros的内容,包括使用publisher等,会卡死
      2. 其他线程不运行,可能是microros任务占用了太多的内存导致其他任务初始化失败,方法:在cubeMX->FreeRTOS中增大TOTAL_HEAP_SIZE
      小鱼小 1 条回复 最后回复 回复 引用 1
        小鱼 技术大佬 @2676239430
        @2676239430 加油!
