    在第17章建图实现第3节odom话题发布不出来
    动手学ROS2
    动手学ros2 雷达 humble
    1.7k
    • twj0011001010T
      twj0011001010
      #include <rclcpp/rclcpp.hpp>
      #include <tf2/utils.h>
      public:
      // 创建一个订阅者,订阅"odom"话题的nav_msgs::msg::Odometry类型消息
      std::bind(&TopicSubscribe01::odom_callback, this, std::placeholders::_1));
      tf_broadcaster_ = std::make_unique<tf2_ros::TransformBroadcaster>(this);
      private:
      // 回调函数,处理接收到的odom消息
      (void)msg;
      RCLCPP_INFO(this->get_logger(), "接收到里程计信息->底盘坐标系 tf :(%f,%f)",
      msg->pose.pose.position.x, msg->pose.pose.position.y);
      // 更新odom_msg_的姿态信息
      public:
      // 发布坐标变换信息
      void publish_tf()
      // 广播坐标变换信息
      // 初始化ROS节点
      rclcpp::init(argc, argv);
      // 创建一个TopicSubscribe01节点
      // 设置循环频率
      rclcpp::WallRate loop_rate(20.0);
      while (rclcpp::ok())
      // 处理回调函数
      rclcpp::spin_some(node);
      // 发布坐标变换信息
      node->publish_tf();
      // 控制循环频率
      loop_rate.sleep();
      // 关闭ROS节点
      rclcpp::shutdown();
      return 0;
      cmakelist文件
      project(fishbot_bringup)
      endif()
      find dependencies
      find_package(rclcpp REQUIRED)
      find_package(geometry_msgs REQUIRED)
      find_package(nav_msgs REQUIRED)
      find_package(tf2 REQUIRED)
      find_package(tf2_ros REQUIRED)
      set(dependencies
      rclcpp
      geometry_msgs
      nav_msgs
      tf2
      tf2_ros
      uncomment the following section in order to fill in
      further dependencies manually.
      find_package(<dependency> REQUIRED)
      add_executable(fishbot_bringup src/fishbot_bringup.cpp)
      target_include_directories(fishbot_bringup PUBLIC
      $<BUILD_INTERFACE:${CMAKE_CURRENT_SOURCE_DIR}/include>
      $<INSTALL_INTERFACE:include>)
      target_compile_features(fishbot_bringup PUBLIC c_std_99 cxx_std_17) # Require C99 and C++17
      ament_target_dependencies(fishbot_bringup
      ${dependencies}
      install(TARGETS fishbot_bringup
      DESTINATION lib/${PROJECT_NAME})
      if(BUILD_TESTING)
      the following line skips the linter which checks for copyrights
      comment the line when a copyright and license is added to all source files
      comment the line when this package is in a git repo and when
      endif()
      ament_package()
      twj0011001010T 1 条回复 最后回复 回复 引用 0
      • twj0011001010T
        twj0011001010 @twj0011001010
        @小鱼 鱼哥,请问这是怎么回事
          小鱼 技术大佬 @twj0011001010
          @twj0011001010 请按照模板提问:https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
