    源码安装 Nav2,在如下截图的方式下编译运行生成包并且能查看到,但是在执行
    Nav2
    cartographer nav2源码安装有错误提示 编译故障
    • vico1999V
      vico1999
       源码编译
      Error(s) in package '/home/vico/fishbot_ws/src/fishbot_navigation2/package.xml':
      Error(s):
      • The generic dependency on 'nav2_bringup' is redundant with: exec_depend
        vico@wp:~/fishbot_ws$ colcon build --packages-up-to navigation2
        [0.424s] WARNING:colcon.colcon_core.package_identification:Failed to parse ROS package manifest in 'src/fishbot_navigation2': Error(s) in package 'src/fishbot_navigation2/package.xml':
        Error(s):
        [0.641s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
        'nav2_map_server' is in: /opt/ros/humble
        If the overridden package is used by another package in any underlay, then the overriding package in the overlay must be API and ABI compatible or undefined behavior at run time may occur.
      If you understand the risks and want to override a package anyways, add the following to the command line:
      --allow-overriding nav2_map_server
      This may be promoted to an error in a future release of colcon-override-check.
      Starting >>> nav2_common
      Starting >>> nav_2d_msgs
      Finished <<< nav2_common [0.83s]
      Starting >>> nav2_msgs
      Starting >>> nav2_voxel_grid
      Finished <<< nav2_voxel_grid [0.81s]
      Finished <<< nav_2d_msgs [1.81s]
      Starting >>> dwb_msgs
      Aborted <<< dwb_msgs [0.47s] ..
      Aborted <<< nav2_msgs [2.16s]
      Summary: 3 packages finished [3.38s]
      2 packages aborted: dwb_msgs nav2_msgs
      编译后的包查看
      vico@wp:~/fishbot_ws$ ros2 pkg list | grep navigation2
      navigation2
      为fishbot 编译导航包
      vico@wp:~/fishbot_ws/src$ colcon build --packages-up-to fishbot_navigation2
      [0.654s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      'nav2_map_server' is in: /home/vico/fishbot_ws/install/nav2_map_server, /opt/ros/humble
      Finished <<< nav2_common [0.91s]
      Finished <<< nav2_voxel_grid [0.49s]
      Finished <<< nav_2d_msgs [2.01s]
      Aborted <<< dwb_msgs [0.54s]
      Aborted <<< nav2_msgs [1.66s]
      Summary: 3 packages finished [2.96s]
      2 packages had stderr output: dwb_msgs nav2_msgs
      32 packages not processed
      [0.638s] WARNING:colcon.colcon_core.package_selection:Some selected packages are already built in one or more underlay workspaces:
      Finished <<< nav2_common [0.92s]
      Finished <<< nav2_voxel_grid [0.46s]
      Finished <<< nav_2d_msgs [1.98s]
      --- stderr: nav2_msgs
      CMake Warning at /opt/ros/humble/share/nav_msgs/cmake/ament_cmake_export_include_directories-extras.cmake:11 (message):
      Package 'nav_msgs' exports the include directory
      '/opt/ros/humble/share/nav_msgs/cmake/../../../include/nav_msgs' which
      doesn't exist
      /opt/ros/humble/share/nav_msgs/cmake/nav_msgsConfig.cmake:41 (include)
      CMakeLists.txt:7 (find_package)
      CMake Error in CMakeLists.txt:
      Imported target "nav_msgs::nav_msgs__rosidl_generator_c" includes
      non-existent path
      "/opt/ros/humble/include/nav_msgs"
      in its INTERFACE_INCLUDE_DIRECTORIES. Possible reasons include:
      • The path was deleted, renamed, or moved to another location.
      • An install or uninstall procedure did not complete successfully.
      • The installation package was faulty and references files it does not
        provide.
      Imported target "nav_msgs::nav_msgs__rosidl_typesupport_fastrtps_c"
      includes non-existent path
        provide.
      Imported target "nav_msgs::nav_msgs__rosidl_typesupport_fastrtps_cpp"
        provide.
      Imported target "nav_msgs::nav_msgs__rosidl_typesupport_introspection_c"
        provide.
      Imported target "nav_msgs::nav_msgs__rosidl_typesupport_introspection_cpp"
        provide.
      Imported target "nav_msgs::nav_msgs__rosidl_generator_cpp" includes
      non-existent path
        provide.
        provide.
        provide.
        小鱼 技术大佬 @vico1999
        @vico1999 在 源码安装 Nav2,在如下截图的方式下编译运行生成包并且能查看到,但是在执行 中说:
        重装下系统中的ROS试试
