    Nav2 自动 launch AMCL
    Nav2
    nav2 amcl ros2 galactic
    2.9k
    • 杜守钰杜
      杜守钰
      版本: galactic, ubuntun 20.04
      我根据 @小鱼的教程跑nav2 的仿真。https://fishros.com/d2lros2/#/humble/chapt11/get_started/3.使用FishBot进行自主导航
      但我根据我project的需求,不设置 AMCL 在我的fishbot_navigation2.yaml 文件里面。
      但奇怪的是,当我launch我的 nav2时,会给我报AMCL的错误。
      并且我还可以通过 以下的CLI看到AMCL node, 但我并没有在我的nav2 yaml文件里面设置它。
      shouyu@shouyu-Nitro-AN515-55:~/nav2_ws$ ros2 node list
      WARNING: Be aware that are nodes in the graph that share an exact name, this can have unintended side effects.
      /amcl
      /amcl_rclcpp_node
      /bt_navigator
      /bt_navigatornavigate_through_poses_rclcpp_node
      /bt_navigatornavigate_to_pose_rclcpp_node
      /controller_server
      /controller_server_rclcpp_node
      /depth_camera_controller
      /diff_drive
      /ekf_filter_node
      /gazebo
      /global_costmap/global_costmap
      /global_costmap/global_costmap_rclcpp_node
      /global_costmap_client
      /imu_plugin
      /laserscan
      /lifecycle_manager_localization
      /lifecycle_manager_navigation
      /local_costmap/local_costmap
      /local_costmap/local_costmap_rclcpp_node
      /local_costmap_client
      /map_server
      /planner_server
      /planner_server_rclcpp_node
      /recoveries_server
      /recoveries_server_rclcpp_node
      /robot_state_publisher
      /rviz2
      /rviz2
      /rviz2
      /rviz2
      /static_transform_publisher_DBYuZ8TucIxiZHPt
      /transform_listener_impl_556de7c8e660
      /transform_listener_impl_557007e5afc0
      /transform_listener_impl_558e16141920
      /transform_listener_impl_56407f189a40
      /transform_listener_impl_7f071401e460
      /transform_listener_impl_7f54040125f0
      /waypoint_follower
      shouyu@shouyu-Nitro
      我已经确认我的路径是指向对应的 yaml 文件。
      以下是我的yaml文件
      bt_navigator:
        ros__parameters:
          use_sim_time: True
          global_frame: map
          robot_base_frame: base_link
          odom_topic: /odom
          bt_loop_duration: 10
          default_server_timeout: 20
          enable_groot_monitoring: True
          groot_zmq_publisher_port: 1666
          groot_zmq_server_port: 1667
          plugin_lib_names:
          - nav2_back_up_action_bt_node
          - nav2_spin_action_bt_node
          - nav2_wait_action_bt_node
          - nav2_recovery_node_bt_node
          - nav2_single_trigger_bt_node
      bt_navigator_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      controller_server:
        ros__parameters:
          use_sim_time: True
          controller_frequency: 20.0
          min_x_velocity_threshold: 0.001
          min_y_velocity_threshold: 0.5
          min_theta_velocity_threshold: 0.001
          failure_tolerance: 0.3
          progress_checker_plugin: "progress_checker"
          goal_checker_plugins: ["general_goal_checker"] # "precise_goal_checker"
          controller_plugins: ["FollowPath"]
          # Progress checker parameters
          progress_checker:
            plugin: "nav2_controller::SimpleProgressChecker"
            required_movement_radius: 0.5
            movement_time_allowance: 10.0
          # Goal checker parameters
          #precise_goal_checker:
          #  plugin: "nav2_controller::SimpleGoalChecker"
          #  xy_goal_tolerance: 0.25
          #  yaw_goal_tolerance: 0.25
          #  stateful: True
          general_goal_checker:
            stateful: True
          # DWB parameters
          FollowPath:
            plugin: "dwb_core::DWBLocalPlanner"
            debug_trajectory_details: True
            min_vel_x: 0.0
            min_vel_y: 0.0
            max_vel_x: 0.26
            max_vel_y: 0.0
            max_vel_theta: 1.0
            min_speed_xy: 0.0
            max_speed_xy: 0.26
            min_speed_theta: 0.0
            # Add high threshold velocity for turtlebot 3 issue.
            # https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
            acc_lim_x: 2.5
            acc_lim_y: 0.0
            acc_lim_theta: 3.2
            decel_lim_x: -2.5
            decel_lim_y: 0.0
            decel_lim_theta: -3.2
            vx_samples: 20
            vy_samples: 5
            vtheta_samples: 20
            sim_time: 1.7
            linear_granularity: 0.05
            angular_granularity: 0.025
            transform_tolerance: 0.2
            trans_stopped_velocity: 0.25
            short_circuit_trajectory_evaluation: True
            stateful: True
            critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
            BaseObstacle.scale: 0.02
            PathAlign.scale: 32.0
            PathAlign.forward_point_distance: 0.1
            GoalAlign.scale: 24.0
            GoalAlign.forward_point_distance: 0.1
            PathDist.scale: 32.0
            GoalDist.scale: 24.0
            RotateToGoal.scale: 32.0
            RotateToGoal.slowing_factor: 5.0
            RotateToGoal.lookahead_time: -1.0
      controller_server_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      local_costmap:
        local_costmap:
          ros__parameters:
            update_frequency: 10.0
            publish_frequency: 10.0
            global_frame: odom
            use_sim_time: True
            rolling_window: true
            width: 3
            height: 3
            resolution: 0.05
            footprint: "[ [0.21, 0.195], [0.21, -0.195], [-0.21, -0.195], [-0.21, 0.195] ]"
            plugins: ["obstacle_layer", "inflation_layer"]
            inflation_layer:
              cost_scaling_factor: 3.0
              inflation_radius: 0.55
            obstacle_layer:
              enabled: True
              observation_sources: scan
              scan:
                topic: /scan
                max_obstacle_height: 2.0
                clearing: True
                marking: True
                data_type: "LaserScan"
                raytrace_max_range: 3.0
                raytrace_min_range: 0.0
                obstacle_max_range: 2.5
                obstacle_min_range: 0.0
            static_layer:
        local_costmap_client:
          ros__parameters:
            use_sim_time: True
        local_costmap_rclcpp_node:
          ros__parameters:
            use_sim_time: True
      global_costmap:
        global_costmap:
          ros__parameters:
            update_frequency: 1.0
            publish_frequency: 1.0
            global_frame: map
            use_sim_time: True
            robot_radius: 0.3
            resolution: 0.05
            track_unknown_space: false
            static_map: false
            rolling_window: false
            width: 10
            height: 10
            origin_x: -5.0
            origin_y: -5.0
            track_unknown_space: true
            obstacle_layer:
              enabled: True
              scan:
                topic: /scan
                clearing: True
                marking: True
            static_layer:
            inflation_layer:
        global_costmap_client:
          ros__parameters:
            use_sim_time: True
        global_costmap_rclcpp_node:
          ros__parameters:
            use_sim_time: True
      map_server:
        ros__parameters:
          use_sim_time: True
          yaml_filename: "/home/shouyu/nav2_ws/src/fishbot/src/fishbot_navigation2/maps/fishbot_map.yaml"
      # map_saver:
      #   ros__parameters:
      #     use_sim_time: True
      #     save_map_timeout: 5.0
      #     free_thresh_default: 0.25
      #     occupied_thresh_default: 0.65
      #     map_subscribe_transient_local: True
      planner_server:
        ros__parameters:
          expected_planner_frequency: 20.0
          use_sim_time: True
          planner_plugins: ["GridBased"]
          GridBased:
            plugin: "nav2_navfn_planner/NavfnPlanner"
            tolerance: 0.5
            use_astar: false
            allow_unknown: true
      planner_server_rclcpp_node:
        ros__parameters:
          use_sim_time: True
      recoveries_server:
        ros__parameters:
          costmap_topic: local_costmap/costmap_raw
          footprint_topic: local_costmap/published_footprint
          cycle_frequency: 10.0
          recovery_plugins: ["spin", "backup", "wait"]
          spin:
            plugin: "nav2_recoveries/Spin"
          backup:
            plugin: "nav2_recoveries/BackUp"
          wait:
            plugin: "nav2_recoveries/Wait"
          global_frame: odom
          transform_timeout: 0.1
          use_sim_time: true
          simulate_ahead_time: 2.0
          max_rotational_vel: 1.0
          min_rotational_vel: 0.4
          rotational_acc_lim: 3.2
      robot_state_publisher:
        ros__parameters:
          use_sim_time: True
      waypoint_follower:
        ros__parameters:
          loop_rate: 20
          stop_on_failure: false
          waypoint_task_executor_plugin: "wait_at_waypoint"
          wait_at_waypoint:
            plugin: "nav2_waypoint_follower::WaitAtWaypoint"
            enabled: True
            waypoint_pause_duration: 200
      LorryL 1 条回复 最后回复 回复 引用 0
      • 杜守钰杜 杜守钰 将这个主题转为问答主题,在
      • LorryL
        Lorry @杜守钰
        @杜守钰 amcl是在launch文件中(nav2_bringup那个启动文件)启动的,不需要的话可以直接修改那个启动文件
        杜守钰杜 1 条回复 最后回复 回复 引用 0
        • 杜守钰杜
          杜守钰 @Lorry
          @Lorry 那如果我要自己一个一个的customize, 是不是要去看对应的源码?
          • LorryL
            Lorry @杜守钰
            @杜守钰 那个文件里有一个变量slam,如果设置为false就会自动启动一个launch文件来启动amcl和map_server,你可以进那个launch文件里把amcl注释掉就行
            • 杜守钰杜
              杜守钰 @Lorry
              @Lorry 好的,我试试看。
              • 杜守钰杜 杜守钰 将这个主题标记为已解决,在
