    求助,源码安装cartographer出错
    ros2 cartographer 源码安装
    883
    • 35684851433
      一二一三八
      在源码下载cartographer时出现错误
      35684851433 1 条回复 最后回复 回复 引用 0
      • 35684851433
        一二一三八 @3568485143
        @小鱼 鱼哥鱼哥求助
          小鱼 技术大佬 @3568485143
          @3568485143 ros2装了吗,先用下rosdepc装下依赖
          • 35684851433
            一二一三八 @小鱼
            @小鱼 ros2安装了,rosdepc也装了,然后在cartographer安装环节执行
            rosdepc install -r --from-paths src --ignore-src --rosdistro $ROS_DISTRO -y
            时出现以下错误:
            欢迎使用国内版rosdep之rosdepc,我是作者小鱼!
            欢迎关注公众号《鱼香ROS》加入交流群
            小鱼rosdepc正式为您服务
            to system dependencies:
            cartographer: [libabsl-dev] defined as "not available" for OS version [bionic]
            cartographer_ros: Cannot locate rosdep definition for [rosbag2_storage]
            cartographer_rviz: [libabsl-dev] defined as "not available" for OS version [bionic]
            Continuing to install resolvable dependencies...
            #All required rosdeps installed successfully
            如果在使用过程中遇到任何问题,欢迎通过fishros.org.cn反馈,最后加入QQ交流群 686914208(入群口令:一键安装)
            最后在执行colcon build --packages-up-to cartographer_ros环节时出现以下错误:
            outerman1@ubuntu:~/fishbot_ws$ colcon build --packages-up-to cartographer_ros
            Starting >>> cartographer
            Starting >>> cartographer_ros_msgs
            Finished <<< cartographer_ros_msgs [2.34s]
            Finished <<< cartographer [4.44s]
            --- stderr: cartographer_ros
            CMake Error at CMakeLists.txt:41 (find_package):
            By not providing "Findrosbag2_cpp.cmake" in CMAKE_MODULE_PATH this project
            has asked CMake to find a package configuration file provided by
            "rosbag2_cpp", but CMake did not find one.
            Could not find a package configuration file provided by "rosbag2_cpp" with
            any of the following names:
            rosbag2_cppConfig.cmake
            rosbag2_cpp-config.cmake
            Add the installation prefix of "rosbag2_cpp" to CMAKE_PREFIX_PATH or set
            "rosbag2_cpp_DIR" to a directory containing one of the above files. If
            "rosbag2_cpp" provides a separate development package or SDK, be sure it
            has been installed.
            Failed <<< cartographer_ros [0.46s, exited with code 1]
            Summary: 2 packages finished [5.13s]
            1 package failed: cartographer_ros
            1 package had stderr output: cartographer_ros
            请问怎么解决,感谢!
              小鱼 技术大佬 @3568485143
              @3568485143
              提问时一定要提供尽可能多的信息(系统版本,ROS版本,前后操作,终端日志
              系统版本
              • 35684851433
                一二一三八 @小鱼
                @小鱼 ros2版本是eloquent,ubuntu版本是18.04。ros2安装了,rosdepc也装了。根据《动手学ros2》中进行cartographer的源码安装,报错如下:
                1.使用rosdepc安装所需依赖:
                时出现以下错误:
                欢迎关注公众号《鱼香ROS》加入交流群
                小鱼rosdepc正式为您服务
                2.跳过1中的错误,直接在执行编译环节
                时出现以下错误:
                has been installed.
                请问怎么解决,感谢!
                  小鱼 技术大佬 @3568485143
                  @3568485143 版本太老了
