    第九章机器人仿真入门第三节《 将启动gazebo和生产fishbot写成launch文件》编写了gazebo.launch.py之后,运行gazebo没有显示机器人,也没有出现报错
    ros2机器人 gazebo仿真插件之两轮差速 gazebo不显示
    5
    14
    5.0k
    • 25675246442
      er
      请问一下各位大佬这是什么原因?
      • 4417555354
        头怎么还不秃啊
        同问,请问兄弟你解决了吗?
          小鱼 技术大佬 @441755535
          @441755535 把这个launch拆成两个,先启动gazebo,再启动机器人
          import os
              robot_name_in_model = 'fishbot'
              urdf_name = "fishbot_gazebo.urdf"
              ld = LaunchDescription()
              # Start Gazebo server
                  cmd=['gazebo', '--verbose','-s', 'libgazebo_ros_init.so', '-s', 'libgazebo_ros_factory.so'],
                  output='screen')
              # Launch the robot
              spawn_entity_cmd = Node(
                  package='gazebo_ros',
                  executable='spawn_entity.py',
                  arguments=['-entity', robot_name_in_model,  '-file', urdf_model_path ], output='screen')
             # ld.add_action(spawn_entity_cmd)
              return ld
          import os
                  output='screen')
              # Launch the robot
             # ld.add_action(start_gazebo_cmd)
              return ld
          • 4417555354
            头怎么还不秃啊
            中间会报这些错误,然后在gazebo里就没有显示模型,launch拆成两个或者合成一个都是一样。
            ModuleNotFoundError: No module named 'rclpy._rclpy_pybind11'
            [spawn_entity.py-2] The C extension '/opt/ros/humble/lib/python3.10/site-packages/_rclpy_pybind11.cpython-38-x86_64-linux-gnu.so' isn't present on the system. Please refer to 'https://docs.ros.org/en/humble/Guides/Installation-Troubleshooting.html#import-failing-without-library-present-on-the-system' for possible solutions
            [ERROR] [spawn_entity.py-2]: process has died [pid 11696, exit code 1, cmd '/opt/ros/humble/lib/gazebo_ros/spawn_entity.py -entity fishbot -file /home/hdm/d2lros2/chapt8_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot_gazebo.urdf --ros-args'].
            • 4417555354
              头怎么还不秃啊
              求助求助!!!!
                小鱼 技术大佬 @441755535
                @441755535 在 第九章机器人仿真入门第三节《 将启动gazebo和生产fishbot写成launch文件》编写了gazebo.launch.py之后,运行gazebo没有显示机器人,也没有出现报错 中说:
                conda 退掉
                4417555354 2 条回复 最后回复 回复 引用 0
                • 4417555354
                  头怎么还不秃啊 @小鱼
                  4417555354 1 条回复 最后回复 回复 引用 0
                  • 4417555354
                    头怎么还不秃啊 @441755535
                    • 4417555354
                      头怎么还不秃啊 @小鱼
                      @小鱼 退掉conda后gazebo可以加载模型了,但是会报下面的错误
                      [gazebo-1] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros_imu_sensor.so: libgazebo_ros_imu_sensor.so: cannot open shared object file: No such file or directory
                      [gazebo-1] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros_ray_sensor.so: libgazebo_ros_ray_sensor.so: cannot open shared object file: No such file or directory
                      [gazebo-1] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros_diff_drive.so: libgazebo_ros_diff_drive.so: cannot open shared object file: No such file or directory
                      [spawn_entity.py-2] [INFO] [1681979467.799171068] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [fishbot]
                      [gazebo-1] [Err] [Plugin.hh:212] Failed to load plugin libgazebo_ros_joint_state_publisher.so: libgazebo_ros_joint_state_publisher.so: cannot open shared object file: No such file or directory
                      [INFO] [spawn_entity.py-2]: process has finished cleanly [pid 37915]
                      [gazebo-1] context mismatch in svga_surface_destroy
                      • 4417555354
                        头怎么还不秃啊 @441755535
                        @441755535
                        urdf代码如下
                        <?xml version="1.0"?>
                        <robot name="fishbot">
                        <!-- Robot Footprint -->
                        <link name="base_footprint"/>
                        <child link="base_link"/>
                        <origin xyz="0.0 0.0 0.076" rpy="0 0 0"/>
                        </joint>
                        <!-- base link -->
                        <link name="base_link">
                        <visual>
                        <geometry>
                        <cylinder length="0.12" radius="0.10"/>
                        </geometry>
                        <material name="blue">
                        </material>
                        </visual>
                        <collision>
                        <geometry>
                        </geometry>
                        </material>
                        </collision>
                        <inertial>
                        <mass value="0.2"/>
                        <inertia ixx="0.0122666" ixy="0" ixz="0" iyy="0.0122666" iyz="0" izz="0.02"/>
                        </inertial>
                        </link>
                        <!-- laser link -->
                        <link name="laser_link">
                        <visual>
                        <geometry>
                        </geometry>
                        <material name="black">
                        </material>
                        </visual>
                        <collision>
                        <geometry>
                        </geometry>
                        </material>
                        </collision>
                        <inertial>
                        <mass value="0.1"/>
                        <inertia ixx="0.000190416666667" ixy="0" ixz="0" iyy="0.0001904" iyz="0" izz="0.00036"/>
                        </inertial>
                        </link>
                        <!-- laser joint -->
                        <parent link="base_link" />
                        <child link="laser_link" />
                        <origin xyz="0 0 0.075" />
                        </joint>
                        <link name="imu_link">
                        <visual>
                        <geometry>
                        <box size="0.02 0.02 0.02"/>
                        </geometry>
                        </visual>
                        <collision>
                        <geometry>
                        </geometry>
                        </collision>
                        <inertial>
                        <mass value="0.1"/>
                        </inertial>
                        </link>
                        <!-- imu joint -->
                        <child link="imu_link" />
                        <origin xyz="0 0 0.02" />
                        </joint>
                        <link name="left_wheel_link">
                        <visual>
                        <geometry>
                        <cylinder length="0.04" radius="0.032"/>
                        </geometry>
                        </material>
                        </visual>
                        <collision>
                        <geometry>
                        </geometry>
                        </material>
                        </collision>
                        <inertial>
                        <mass value="0.2"/>
                        </inertial>
                        </link>
                        <visual>
                        <geometry>
                        </geometry>
                        </material>
                        </visual>
                        <collision>
                        <geometry>
                        </geometry>
                        </material>
                        </collision>
                        <inertial>
                        <mass value="0.2"/>
                        </inertial>
                        </link>
                        <origin xyz="-0.02 0.10 -0.06" />
                        <axis xyz="0 1 0" />
                        </joint>
                        <origin xyz="-0.02 -0.10 -0.06" />
                        </joint>
                        <link name="caster_link">
                        <visual>
                        <geometry>
                        <sphere radius="0.016"/>
                        </geometry>
                        </material>
                        </visual>
                        <collision>
                        <geometry>
                        </geometry>
                        </material>
                        </collision>
                        <inertial>
                        <mass value="0.02"/>
                        </inertial>
                        </link>
                        <child link="caster_link" />
                        <origin xyz="0.06 0.0 -0.076" />
                        </joint>
                        <gazebo reference="caster_link">
                        </gazebo>
                        <mu1 value="0.0"/>
                        <mu2 value="0.0"/>
                        <kp value="1000000.0" />
                        <kd value="10.0" />
                        <!-- <fdir1 value="0 0 1"/> -->
                        </gazebo>
                        <gazebo>
                        <ros>
                        <namespace>/</namespace>
                        </ros>
                        <update_rate>30</update_rate>
                        <!-- wheels -->
                        <!-- <left_joint>left_wheel_joint</left_joint> -->
                        <!-- <right_joint>right_wheel_joint</right_joint> -->
                        <!-- kinematics -->
                        <wheel_diameter>0.065</wheel_diameter>
                        <!-- limits -->
                        <!-- output -->
                        <publish_wheel_tf>false</publish_wheel_tf>
                        </plugin>
                          <plugin name="fishbot_joint_state" filename="libgazebo_ros_joint_state_publisher.so">
                            <ros>
                              <remapping>~/out:=joint_states</remapping>
                            </ros>
                            <joint_name>right_wheel_joint</joint_name>
                            <joint_name>left_wheel_joint</joint_name>
                          </plugin>
                          </gazebo>
                          <gazebo reference="laser_link">
                          </gazebo>
                        <gazebo reference="imu_link">
                          <sensor name="imu_sensor" type="imu">
                          <plugin filename="libgazebo_ros_imu_sensor.so" name="imu_plugin">
                              <ros>
                                <remapping>~/out:=imu</remapping>
                              </ros>
                              <initial_orientation_as_reference>false</initial_orientation_as_reference>
                            </plugin>
                            <always_on>true</always_on>
                            <update_rate>100</update_rate>
                            <visualize>true</visualize>
                            <imu>
                              <angular_velocity>
                                <x>
                                  <noise type="gaussian">
                                    <mean>0.0</mean>
                                    <stddev>2e-4</stddev>
                                    <bias_mean>0.0000075</bias_mean>
                                    <bias_stddev>0.0000008</bias_stddev>
                                  </noise>
                                </x>
                                <y>
                                    <mean>0.0</mean>
                                  </noise>
                                </y>
                                <z>
                                    <mean>0.0</mean>
                                  </noise>
                                </z>
                              </angular_velocity>
                              <linear_acceleration>
                                <x>
                                    <mean>0.0</mean>
                                    <stddev>1.7e-2</stddev>
                                    <bias_mean>0.1</bias_mean>
                                    <bias_stddev>0.001</bias_stddev>
                                  </noise>
                                </x>
                                <y>
                                    <mean>0.0</mean>
                                  </noise>
                                </y>
                                <z>
                                    <mean>0.0</mean>
                                  </noise>
                                </z>
                              </linear_acceleration>
                            </imu>
                          </sensor>
                        </gazebo>
                          <sensor name="laser_sensor" type="ray">
                          <update_rate>5</update_rate>
                          <pose>0 0 0.075 0 0 0</pose>
                          <ray>
                              <scan>
                                <horizontal>
                                  <samples>360</samples>
                                  <resolution>1.000000</resolution>
                                  <min_angle>0.000000</min_angle>
                                  <max_angle>6.280000</max_angle>
                                </horizontal>
                              </scan>
                              <range>
                                <min>0.120000</min>
                                <max>3.5</max>
                                <resolution>0.015000</resolution>
                              </range>
                              <noise>
                                <type>gaussian</type>
                                <mean>0.0</mean>
                                <stddev>0.01</stddev>
                              </noise>
                          </ray>
                          <plugin name="laserscan" filename="libgazebo_ros_ray_sensor.so">
                            <ros>
                              <!-- <namespace>/tb3</namespace> -->
                              <remapping>~/out:=scan</remapping>
                            </ros>
                            <output_type>sensor_msgs/LaserScan</output_type>
                            <frame_name>laser_link</frame_name>
                          </plugin>
                          </sensor>
                        </gazebo>
                        </robot>
                        • 10949672961
                          丘洪键
                          最后由 1094967296 编辑
                          解决:把launch中的urdf_name = "fishbot_gazebo.urdf" 改为:urdf_name = "fishbot_base.urdf"
                          原因:(自己摸索的,不知道对不对,我自己按上面改了之后就能显示了)
                          应该是urdf的文件名搞错了,第8章跟着教程建立urdf的文件名是_base结尾的,如下图:
                          然后现在的launch文件里是_gazebo结尾的:
                          运行就加载不了urdf文件了,报错:
                          看看这个路径下的urdf文件,并没有fishbot_gazebo.urdf
                          10949672961 1 3 条回复 最后回复 回复 引用 0
                          • 10949672961
                            丘洪键 @1094967296
                            @1094967296 首先确保用rqt显示是没问题的,确保urdf里的内容是对的
                              18730832756 @1094967296
                                @1094967296 牛皮,哥,我找了半天的错没想到是名错了
