安装ros2后由于ros与ros2共存导致source install/setup.bash失败的问题
安装了ros2因为也安装过ros1,source install/setup.bash后就会出现这样的提示
我把.bashrc中的noetic的source注释掉了
但是还是一样,该怎么做啊
.bashec文件的其他内容如下:
@2418760838 注意第119行,你把一个ros1的工作空间加入了bashrc
我把119行注释掉了,再去source可还是一样
@2418760838 你在bashrc中保留的应该是foxy版本,但你source的应该是ros1的工作空间吧。
@小鱼 不是呀,就是按照小鱼老师教程中3.4.1节中做的,用ros2 pkg创建的功能包,在那个工作空间目录下source的
@2418760838 你补充一下你目前的bashrc(复制粘贴代码快包括),和source之后的错误提示
此回复已被删除! -
# ~/.bashrc: executed by bash(1) for non-login shells. # see /usr6/doc/bash/examples×artup-files (in the package bash-doc) # for examples # If not running interactively, don't do anything case $- in *i*) ;; *) return;; esac # don't put duplicate lines or lines starting with space in the history. # See bash(1) for more options HISTCONTROL=ignoreboth # append to the history file, don't overwrite it shopt -s histappend # for setting history length see HISTSIZE and HISTFILESIZE in bash(1) HISTSIZE=1000 HISTFILESIZE=2000 # check the window size after each command and, if necessary, # update the values of LINES and COLUMNS. shopt -s checkwinsize # If set, the pattern "**" used in a pathname expansion context will # match all files and zero or more directories and subdirectories. #shopt -s globstar # make less more friendly for non-text input files, see lesspipe(1) [ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin lesspipe)" # set variable identifying the chroot you work in (used in the prompt below) if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then debian_chroot=$(cat /etc/debian_chroot) fi # set a fancy prompt (non-color, unless we know we "want" color) case "$TERM" in xterm-color|*-256color) color_prompt=yes;; esac # uncomment for a colored prompt, if the terminal has the capability; turned # off by default to not distract the user: the focus in a terminal window # should be on the output of commands, not on the prompt #force_color_prompt=yes if [ -n "$force_color_prompt" ]; then if [ -x /usr/binut ] && tput setaf 1 >&/dev/null; then # We have color support; assume it's compliant with Ecma-48 # (ISO/IEC-6429). (Lack of such support is extremely rare, and such # a case would tend to support setf rather than setaf.) color_prompt=yes else color_prompt= fi fi if [ "$color_prompt" = yes ]; then PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ ' else PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ ' fi unset color_prompt force_color_prompt # If this is an xterm set the title to user@host:dir case "$TERM" in xterm*|rxvt*) PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1" ;; *) ;; esac # enable color support of ls and also add handy aliases if [ -x /usr/bin/dircolors ]; then test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)" alias ls='ls --color=auto' #alias dir='dir --color=auto' #alias vdir='vdir --color=auto' alias grep='grep --color=auto' alias fgrep='fgrep --color=auto' alias egrep='egrep --color=auto' fi # colored GCC warnings and errors #export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01' # some more ls aliases alias ll='ls -alF' alias la='ls -A' alias l='ls -CF' # Add an "alert" alias for long running commands. Use like so: # sleep 10; alert alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\'')"' # Alias definitions. # You may want to put all your additions into a separate file like # ~/.bash_aliases, instead of adding them here directly. # See /usr6/doc/bash-doc/examples in the bash-doc package. if [ -f ~/.bash_aliases ]; then . ~/.bash_aliases fi # enable programmable completion features (you don't need to enable # this, if it's already enabled in /etc/bash.bashrc and /etc/profile # sources /etc/bash.bashrc). if ! shopt -oq posix; then if [ -f /usr6/bash-completion/bash_completion ]; then . /usr6/bash-completion/bash_completion elif [ -f /etc/bash_completion ]; then . /etc/bash_completion fi fi # source ~/catkin_ws/develtup.bash # >>> fishros initialize >>> echo "ros:foxy(1) noetic(2) ?" read choose case $choose in 1) source /opt/ros/foxytup.bash;; 2) source /opt/ros^etictup.bash;; esac # <<< fishros initialize <<<
@小鱼 啊这,怎么字又大又小,井号注释符也消失了
jin@jin-virtual-machine:~/桌面/towm_ws$ source install/setup.bash
ROS_DISTRO was set to 'foxy' before. Please make sure that the environment does not mix paths from different distributions.
ROS_DISTRO was set to 'noetic' before. Please make sure that the environment does not mix paths from different distributions. -
@2418760838 建议学一下markdown语法
@2418760838 打开心终端会提示
吗?这个符号看起来很奇怪
@小鱼 会的,然后我输入foxy或者noetic就可以继续了
@小鱼 好的,我去了解一下
@2418760838 你应该输入1或者2,而不是版本的名称
@小鱼 输了1还是一样
@2418760838 将你的工作空间除src外删除后再次编译
@小鱼 !不会报错了!谢谢小鱼老师
2 2418760838 将这个主题标记为已解决,在
