    Group 'aubo_i5' was not found.被困扰好几天了
    rosrun melodic
    1.8k
    • 26553372722
      一戴小饼干
      dayna@dayna-virtual-machine:~/aubo_ws$ rosrun aubo_obstacle test_obstacle.py
      [ INFO] [1683337620.579221388]: Loading robot model 'aubo_i5'...
      [FATAL] [1683337620.831447450]: Group 'aubo_i5' was not found.
      File "/home/dayna/aubo_ws/src/aubo_examples/aubo_obstacle/script/test_obstacle.py", line 101, in <module>
      MoveAttachedObjectDemo()
      File "/home/dayna/aubo_ws/src/aubo_examples/aubo_obstacle/script/test_obstacle.py", line 25, in init
      arm = MoveGroupCommander('aubo_i5')
      File "/opt/ros/melodic/lib/python2.7/dist-packages/moveit_commander/move_group.py", line 66, in init
      name, robot_description, ns, wait_for_servers
      RuntimeError: Group 'aubo_i5' was not found.
        小鱼 技术大佬 @2655337272
        @2655337272 提示很明显了,没有这个movegroup
        26553372722 1 条回复 最后回复 回复 引用 0
        • 26553372722
          一戴小饼干 @小鱼
          @小鱼 这个从哪改或者从哪找呢
            小鱼 技术大佬 @2655337272
            @2655337272 应该是没有launch成功,你应该
            • 万青万
              万青
              您好,请问您解决了吗
