    ros2 foxy moveit2 编译错误
    moveit2 机械臂
    2.8k
    • 5728716925
      L
      系统: ubontu20.04 ros2 foxy版本
      根据帖子:动手学moveit2 探索篇1
      一步一步运行:
      在运行到
      colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release
      发生一下错误:
      --- stderr: moveit_core
      CMake Warning (dev) at /usr/local/share/cmake-3.26/Modules/FindPackageHandleStandardArgs.cmake:438 (message):
      The package name passed to find_package_handle_standard_args (libdw) does
      not match the name of the calling package (backward_ros). This can lead to
      problems in calling code that expects find_package result variables
      (e.g., _FOUND) to follow a certain pattern.
      /opt/ros/foxy/share/backward_ros/cmake/BackwardConfig.cmake:55 (find_package_handle_standard_args)
      /opt/ros/foxy/share/backward_ros/cmake/backward_rosConfig.cmake:41 (include)
      /home/z/moveit2/install/moveit_common/share/moveit_common/cmake/moveit_package.cmake:36 (find_package)
      CMakeLists.txt:6 (moveit_package)
      This warning is for project developers. Use -Wno-dev to suppress it.
      The package name passed to find_package_handle_standard_args (libbfd)
      does not match the name of the calling package (backward_ros). This can
      lead to problems in calling code that expects find_package result
      variables (e.g., _FOUND) to follow a certain pattern.
      /opt/ros/foxy/share/backward_ros/cmake/BackwardConfig.cmake:66 (find_package_handle_standard_args)
      The package name passed to find_package_handle_standard_args (Backward)
      /opt/ros/foxy/share/backward_ros/cmake/BackwardConfig.cmake:128 (find_package_handle_standard_args)
      CMake Error at CMakeLists.txt:25 (find_package):
      By not providing "Findgenerate_parameter_library.cmake" in
      CMAKE_MODULE_PATH this project has asked CMake to find a package
      configuration file provided by "generate_parameter_library", but CMake did
      not find one.
      "generate_parameter_library" with any of the following names:
      generate_parameter_libraryConfig.cmake
      generate_parameter_library-config.cmake
      Add the installation prefix of "generate_parameter_library" to
      CMAKE_PREFIX_PATH or set "generate_parameter_library_DIR" to a directory
      containing one of the above files. If "generate_parameter_library"
      installed.
      Failed <<< moveit_core [0.88s, exited with code 1]
      Aborted <<< moveit_resources [0.86s]
      Aborted <<< rosparam_shortcuts [2.56s]
      Aborted <<< rviz_visual_tools [4.85s]
      Aborted <<< moveit_task_constructor_msgs [5.16s]
      Aborted <<< rviz_marker_tools [7.44s]
      Summary: 10 packages finished [8.92s]
      1 package failed: moveit_core
      5 packages aborted: moveit_resources moveit_task_constructor_msgs rosparam_shortcuts rviz_marker_tools rviz_visual_tools
      2 packages had stderr output: moveit_core rviz_marker_tools
      41 packages not processed
      小鱼小 28915512182 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @572871692
        @572871692 看这篇 https://fishros.org.cn/forum/topic/395/动手学moveit2-3-安装moveit2测试
        • 28915512182
          one piece @572871692
          @572871692 请问这个问题解决了吗😊 😊
