    Failed to load entry point 'launch': No module named 'launch.launch_description_sources'
    ros2 launch ros2 launch文件 humble launch 失败
    1.9k
    • 18489854211
      风
      各位好,我初学ROS2,现在碰到了一个问题,向大家请教一下:
      • 按照ros2官网的创建launch文件教程,在终端输入:
      cd ~ws/src
      mkdir launch
      touch simple.launch.py
      • 编辑好launch文件:
          return LaunchDescription([
              Node(
                  package='learning_topic',
                  executable='helloworld_topicpub_node',
              Node(
                  executable='helloword_topicsub_node',
      • 使用launch文件启动节点(以上两个节点我单独启动过,均没有问题):
      cd ~/ws/src/launch
      ros2 launch simple.launch.py
      会提示报错:
        File "/opt/ros/humble/bin/ros2", line 33, in <module>
          sys.exit(load_entry_point('ros2cli==0.18.7', 'console_scripts', 'ros2')())
        File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/cli.py", line 50, in main
          add_subparsers_on_demand(
        File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/command/__init__.py", line 237, in add_subparsers_on_demand
          extension = command_extensions[name]
      KeyError: 'launch'
      我更换了工作空间也不行,但是之前下载的一个课程文件(也是一个单独的工作空间)中的launch文件却能正常启动,一直找不到原因,请各位赐教。😭 😭 😭
      附上我话题的setup文件:
      from setuptools import find_packages, setup
      package_name = 'learning_topic'
      setup(
          name=package_name,
          version='0.0.0',
          packages=find_packages(exclude=['test']),
          data_files=[
              ('share/ament_index/resource_index/packages',
                  ['resource/' + package_name]),
              ('share/' + package_name, ['package.xml']),
          install_requires=['setuptools'],
          zip_safe=True,
          maintainer='huang',
          maintainer_email='huang@todo.todo',
          description='TODO: Package description',
          license='TODO: License declaration',
          tests_require=['pytest'],
          entry_points={
              'console_scripts': [
                  'helloworld_topicpub_node   =   learning_topic.topic_publish:main',
                  'helloworld_topicsub_node   =   learning_topic.topic_subscribe:main',
      32295237503 1 条回复 最后回复 回复 引用 0
      • 32295237503
        边川 @1848985421
        @1848985421 请问您解决这个问题了没
