    动手4.3.2报错
    cmake ros2
    6.3k
    • 5051060355
      looking。
      完全按照教程操作,但是编译就是不通过
      报错如下:
      (pytorch) l@l-GF63-Thin-9SC:~/桌面/town_ws/village_interfaces$ colcon build --packages-select village_interfaces
      Starting >>> village_interfaces
      --- stderr: village_interfaces
      CMake Error at /opt/ros/eloquent/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:240 (list):
        list index: 1 out of range (-1, 0)
        CMakeLists.txt:40 (rosidl_generate_interfaces)
      CMake Error at /opt/ros/eloquent/share/rosidl_generator_cpp/cmake/rosidl_generator_cpp_generate_interfaces.cmake:57 (message):
        Target dependency
        '/town_ws/village_interfaces/build/village_interfaces/rosidl_adapter/village_interfaces/msg/Novel.idl'
        does not exist
        /opt/ros/eloquent/share/ament_cmake_core/cmake/core/ament_execute_extensions.cmake:48 (include)
        /opt/ros/eloquent/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:286 (ament_execute_extensions)
      Failed   <<< village_interfaces [0.53s, exited with code 1]
      Summary: 0 packages finished [0.67s]
        1 package failed: village_interfaces
        1 package had stderr output: village_interfaces
      • 5051060355
        looking。 @小鱼
        @小鱼 我用win电脑装了个vm配置了u20。装的ros2-rolling就好使。醉了
          小鱼 技术大佬 @505106035
          @505106035 看一下你的
          • 消息定义文件
          • CMakeLists.txt
          • 目录结构
          5051060355 1 条回复 最后回复 回复 引用 0
          • 5051060355
            looking。 @小鱼
            最后由 505106035 编辑
            消息定义文件如下:
            # 直接使用ROS2原始的数据类型
            string content
            # 图像消息,调用sensor_msgs下的Image类型
            sensor_msgs/Image image
            cmake.txt如下:
            project(village_interfaces)
            # Default to C99
            if(NOT CMAKE_C_STANDARD)
              set(CMAKE_C_STANDARD 99)
            endif()
            # Default to C++14
            if(NOT CMAKE_CXX_STANDARD)
              set(CMAKE_CXX_STANDARD 14)
            endif()
            endif()
            # find dependencies
            #添加对sensor_msgs的
            find_package(sensor_msgs REQUIRED)
            #添加消息文件和依赖
              #---msg---
              "msg/Novel.msg"
              DEPENDENCIES sensor_msgs
            if(BUILD_TESTING)
              # uncomment the line when a copyright and license is not present in all source files
              #set(ament_cmake_copyright_FOUND TRUE)
              # uncomment the line when this package is not in a git repo
              #set(ament_cmake_cpplint_FOUND TRUE)
            endif()
            ament_package()
            目录结构如下:
            (pytorch) l@l-GF63-Thin-9SC:~/桌面/town_ws/village_interfaces$ tree
            ├── CMakeLists.txt
            ├── include
            │   └── village_interfaces
            ├── msg
            │   └── Novel.msg
            ├── package.xml
            └── src
            4 directories, 3 files
            • 5051060355
              looking。
                小鱼 技术大佬 @505106035
                @505106035 复制粘贴你的代码我做了一下测试,编译没问题,除了packages.xml需要增加一个
                增加完后
                <?xml version="1.0"?>
                <package format="3">
                  <name>village_interfaces</name>
                  <version>0.0.0</version>
                  <maintainer email="fishros@foxmail.com">pear</maintainer>
                  <license>TODO: License declaration</license>
                  <export>
                  </export>
                </package>
                你可以试试
                  小鱼 技术大佬 @小鱼
                  @小鱼 确认上下文有ros2环境,试试colcon build指令(不加packages-select)
                  5051060355 2 条回复 最后回复 回复 引用 0
                  • 5051060355
                    looking。 @小鱼
                    @小鱼 不行。还是同样的报错。难道是我用的ubuntu18.04配置的ros2-eloquent这个版本和教程不一样?我看那个一键安装的ros2的脚本就只有到eloquent这个版本
                    小鱼小 2 条回复 最后回复 回复 引用 0
                    • 5051060355
                      looking。 @小鱼
                      如下:
                      (pytorch) l@l-GF63-Thin-9SC:~/桌面/town_ws$ ros2
                      usage: ros2 [-h] Call `ros2 <command> -h` for more detailed usage. ...
                      ros2 is an extensible command-line tool for ROS 2.
                      optional arguments:
                        -h, --help            show this help message and exit
                      Commands:
                        action     Various action related sub-commands
                        component  Various component related sub-commands
                        daemon     Various daemon related sub-commands
                        doctor     Check ROS setup and other potential issues
                        interface  Show information about ROS interfaces
                        launch     Run a launch file
                        lifecycle  Various lifecycle related sub-commands
                        msg        Various msg related sub-commands
                        multicast  Various multicast related sub-commands
                        node       Various node related sub-commands
                        param      Various param related sub-commands
                        pkg        Various package related sub-commands
                        run        Run a package specific executable
                        security   Various security related sub-commands
                        service    Various service related sub-commands
                        srv        Various srv related sub-commands
                        topic      Various topic related sub-commands
                        wtf        Use `wtf` as alias to `doctor`
                      运行colcon build:
                      (pytorch) l@l-GF63-Thin-9SC:~/桌面/town_ws$ colcon build
                      Starting >>> village_li
                      Starting >>> village_wang
                      Finished <<< village_wang [0.47s]
                        CMakeLists.txt:24 (rosidl_generate_interfaces)
                        Target dependency
                        '/town_ws/build/village_interfaces/rosidl_adapter/village_interfaces/msg/Novel.idl'
                        does not exist
                      Failed   <<< village_interfaces [0.60s, exited with code 1]
                      Aborted  <<< village_li [0.82s]
                      Summary: 1 package finished [0.97s]
                        1 package aborted: village_li
                      还是一样的报错,就说cmake的错,
                      简直头疼,不知道什么毛病。
                        小鱼 技术大佬 @505106035
                        @505106035 版本问题有很大可能,你用的版本已经停止维护有一段时间了。
                          小鱼 技术大佬 @505106035
                          @505106035 ubuntu18上没有foxy版本,只有ubuntu20才支持
                          • 5051060355
                            looking。 @小鱼
                              小鱼 技术大佬 @505106035
                              @505106035 ROS2前几个版本更新的很快,所以差异比较大
                              • 小鱼小 小鱼 将这个主题标记为已解决,在
                              • 7513651667
                                吉
                                • 7513651667
                                  吉
                                  最后由 751365166 编辑
                                  @小鱼 鱼哥,我的系统版本是22.04.3,ROS版本是humble,和上面的问题有点类似,但感觉不太一样,应该怎么解决??
                                  列表回复: 动手4.3.2报错
                                  liu@liu-virtual-machine:~/桌面$ git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                                  fatal: destination path 'fishbot' already exists and is not an empty directory.
                                  liu@liu-virtual-machine:~/桌面$ cd fishbot
                                  liu@liu-virtual-machine:~/桌面/fishbot$ rosdep install --from-paths src --ignore-src -y  -r # 安装依赖
                                  #All required rosdeps installed successfully
                                  liu@liu-virtual-machine:~/桌面/fishbot$ colcon build
                                  Starting >>> fishbot_bringup
                                  Starting >>> fishbot_cartographer
                                  Finished <<< fishbot_cartographer [0.19s]
                                  Finished <<< fishbot_bringup [0.28s]
                                  Starting >>> fishbot_interfaces
                                  --- stderr: fishbot_interfaces
                                  CMake Error at /opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:240 (list):
                                    CMakeLists.txt:29 (rosidl_generate_interfaces)
                                  CMake Error at /opt/ros/humble/share/rosidl_generator_c/cmake/rosidl_generator_c_generate_interfaces.cmake:69 (message):
                                    Target dependency
                                    '/fishbot/build/fishbot_interfaces/rosidl_adapter/fishbot_interfaces/srv/FishBotConfig.idl'
                                    does not exist
                                  Failed   <<< fishbot_interfaces [0.44s, exited with code 1]
                                  Aborted  <<< fishbot_description [0.56s]
                                  Summary: 2 packages finished [1.20s]
                                    1 package failed: fishbot_interfaces
                                    1 package aborted: fishbot_description
                                    2 packages had stderr output: fishbot_description fishbot_interfaces
                                    1 package not processed
                                  • ganyuanzhenG
                                    Elysia 技术大佬 @751365166
                                    @751365166 尽量避免路径中出现中文,这会产生很多未定义行为。(ROS开发者可不会想到你会输入除英文以外的路径哈哈
                                    7513651667 1 条回复 最后回复 回复 引用 1
                                    • 7513651667
                                      吉 @ganyuanzhen
                                      @ganyuanzhen 我懂了!!!感谢,问题出在,我应该新建一个英文名称的文件夹,然后在新建文件中运行终端命令!而不应该直接在桌面运行终端。
                                      liu@liu-virtual-machine:~/ROS$ git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                                      Cloning into 'fishbot'...
                                      remote: Enumerating objects: 84, done.
                                      remote: Counting objects: 100% (84/84), done.
                                      remote: Compressing objects: 100% (69/69), done.
                                      remote: Total 84 (delta 21), reused 46 (delta 7), pack-reused 0
                                      Receiving objects: 100% (84/84), 332.98 KiB | 422.00 KiB/s, done.
                                      Resolving deltas: 100% (21/21), done.
                                      liu@liu-virtual-machine:~/ROS$ cd fishbot
                                      liu@liu-virtual-machine:~/ROS/fishbot$ rosdep install --from-paths src --ignore-src -y  -r # 安装依赖
                                      liu@liu-virtual-machine:~/ROS/fishbot$ colcon build
                                      Finished <<< fishbot_cartographer [0.53s]
                                      Finished <<< fishbot_description [0.57s]
                                      Finished <<< fishbot_interfaces [7.94s]
                                      Starting >>> fishbot_navigation2
                                      Finished <<< fishbot_navigation2 [0.63s]
                                      Finished <<< fishbot_bringup [13.5s]
                                      Summary: 5 packages finished [13.9s]
