    gazebo_ros_pkgs无法在基于arm架构的ubuntu安装
    arm64 gazebo11
    2.8k
    • 27616077292
      赤诚
      将一个基于amd的ubuntu22.04版本的ros2-humble系统上的功能包(小鱼跟着动手学ros的文档完成的)移植到基于arm的ubuntu22.04版本的ros2-humble系统上,编译报错如下:
      CMake Error at CMakeLists.txt:17 (find_package):
        By not providing "Findgazebo_ros_pkgs.cmake" in CMAKE_MODULE_PATH this
        project has asked CMake to find a package configuration file provided by
        "gazebo_ros_pkgs", but CMake did not find one.
        Could not find a package configuration file provided by "gazebo_ros_pkgs"
        with any of the following names:
          gazebo_ros_pkgsConfig.cmake
          gazebo_ros_pkgs-config.cmake
        Add the installation prefix of "gazebo_ros_pkgs" to CMAKE_PREFIX_PATH or
        set "gazebo_ros_pkgs_DIR" to a directory containing one of the above files.
        If "gazebo_ros_pkgs" provides a separate development package or SDK, be
        sure it has been installed.
      具体细节和上下文:
      我看了一下终端的报错信息是在github下载的navigation2中的nav2_system_tests中有依赖gazebo_ros_pkgs,但是我运行这个sudo apt install ros-humble-gazebo-*指令,
      注意,根据Glob 'ros-humble-gazebo-*' 选中了 'ros-humble-gazebo-model-attachment-plugin-msgs-dbgsym'
      注意,根据Glob 'ros-humble-gazebo-*' 选中了 'ros-humble-gazebo-video-monitor-interfaces'
      注意,根据Glob 'ros-humble-gazebo-*' 选中了 'ros-humble-gazebo-model-attachment-plugin-msgs'
      注意,根据Glob 'ros-humble-gazebo-*' 选中了 'ros-humble-gazebo-msgs-dbgsym'
      注意,根据Glob 'ros-humble-gazebo-*' 选中了 'ros-humble-gazebo-dev'
      注意,根据Glob 'ros-humble-gazebo-*' 选中了 'ros-humble-gazebo-video-monitor-utils'
      注意,根据Glob 'ros-humble-gazebo-*' 选中了 'ros-humble-gazebo-video-monitor-interfaces-dbgsym'
      注意,根据Glob 'ros-humble-gazebo-*' 选中了 'ros-humble-gazebo-msgs'
      仅下载了这些包,并没有gazebo_ros_pkgs这个包,是不是这个不支持在arm下载。
      这个该怎么解决。或者如果我不使用gazebo而是ignition来替代,那这个navigiton2中的nav2_system_tests依赖的gazebo_ros-pkgs又该怎么处理。
      小鱼小 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @2761607729
        @2761607729 代码要用代码块包裹,编辑问题的时候选这个就可以
        我先给你修改一下,下一次一定要注意
          小鱼 技术大佬 @2761607729
          @2761607729 1. Gazebo经典版本没有发布在Arm平台,所以一些包没办法安装
          2. 该包 https://github.com/ros-planning/navigation2/tree/main/nav2_system_tests 是用于快速测试使用,采用了仿真形式,一般情况下应该是用不到的
          解决建议:
          1. 直接删除掉该功能包nav2_system_tests,进行构建
            2.尝试直接使用二进制安装Nav2,sudo apt install ros-humble-nav2-bringup
          27616077292 1 条回复 最后回复 回复 引用 0
          • 27616077292
            赤诚 @小鱼
            @小鱼 但是在前面使用机器人建模的时候还是使用到了gazebo来加载urdf,还得用到gazebo_ros_pkgs,所以这个有平替的方案嘛。比如用ignition。
              小鱼 技术大佬 @2761607729
              @2761607729 你可以去找一下Gazbeo是否有arm源可以用,昨天这个帖子:(https://fishros.org.cn/forum/topic/2398/cartographer仿真出现建筑与rviz显示地图方位不一致 )的兄弟就在arm平台上跑了仿真了,你可以问问看怎么实现的。另外在arm上跑Gazebo应该会比较卡吧,加载URDF是用不到Gazebo的,Gazebo支持的是SDF。
