    如何将Moveit2官网教程中panda机械臂的命令接口,从'position'正确地为'velocity'?
    机械臂运动规划
    moveit2 movit2官方教程 ros2control
    3.5k
    • 4379854374
      437985437
      我跟随Moveit2官网创建了panda机械臂,并成功运行了 demo.launch.py:
      MoveIt Setup Assistant — MoveIt Documentation: Rolling documentation
      我想将教程熊猫机械臂命令接口从'position'更改为'velocity'。
      我更改了两个文件:
      1. ros2_controllers.yaml
      2. panda.ros2_control.xacro
      更改后,运行以下命令启动程序:
      colcon build
      ros2 launch panda_moveit_config demo.launch.py
      这时RViz 展示了正确的计划轨迹
      但是完成计划后并单击“ Execute”按钮时,rviz中机械臂没有相应的动作(只有之前点击“Plan”后出现的计划轨迹)
      我的更改内容是否有问题?或者说正确的更改是什么?
      以下是控制台输出,以及我更改的两个文件:
      控制台输出:
      [rviz2-4] [INFO] [1713256529.569964067] [move_group_interface]: MoveGroup action client/server ready
      [move_group-3] [INFO] [1713256529.570737967] [moveit_move_group_default_capabilities.move_action_capability]: Received request
      [move_group-3] [INFO] [1713256529.570926767] [moveit_move_group_default_capabilities.move_action_capability]: executing..
      [rviz2-4] [INFO] [1713256529.571154567] [move_group_interface]: Planning request accepted
      [move_group-3] [INFO] [1713256529.579226867] [moveit_move_group_default_capabilities.move_action_capability]: Planning request received for MoveGroup action. Forwarding to planning pipeline.
      [move_group-3] [INFO] [1713256529.579303767] [moveit_move_group_capabilities_base.move_group_capability]: Using planning pipeline 'ompl'
      [move_group-3] [INFO] [1713256529.579782367] [moveit.ompl_planning.model_based_planning_context]: Planner configuration 'robot_arm' will use planner 'geometric::RRTConnect'. Additional configuration parameters will be set when the planner is constructed.
      [move_group-3] [INFO] [1713256529.634432567] [moveit_move_group_default_capabilities.move_action_capability]: Motion plan was computed successfully.
      [rviz2-4] [INFO] [1713256529.635581867] [move_group_interface]: Planning request complete!
      [rviz2-4] [INFO] [1713256529.635675367] [move_group_interface]: time taken to generate plan: 0.0163399 seconds
      [move_group-3] [INFO] [1713256535.657329254] [moveit_move_group_default_capabilities.execute_trajectory_action_capability]: Received goal request
      [move_group-3] [INFO] [1713256535.657736354] [moveit_move_group_default_capabilities.execute_trajectory_action_capability]: Execution request received
      [move_group-3] [INFO] [1713256535.657824254] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
      [move_group-3] [INFO] [1713256535.657872854] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
      [move_group-3] [INFO] [1713256535.658506454] [moveit_ros.trajectory_execution_manager]: Validating trajectory with allowed_start_tolerance 0.01
      [rviz2-4] [INFO] [1713256535.658094154] [move_group_interface]: Execute request accepted
      [move_group-3] [INFO] [1713256535.660050654] [moveit_ros.trajectory_execution_manager]: Starting trajectory execution ...
      [move_group-3] [INFO] [1713256535.660163154] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
      [move_group-3] [INFO] [1713256535.660240354] [moveit.plugins.moveit_simple_controller_manager]: Returned 2 controllers in list
      [move_group-3] [INFO] [1713256535.660452454] [moveit.simple_controller_manager.follow_joint_trajectory_controller_handle]: sending trajectory to robot_arm_controller
      [ros2_control_node-5] [INFO] [1713256535.660962554] [robot_arm_controller]: Received new action goal
      [ros2_control_node-5] [INFO] [1713256535.661051554] [robot_arm_controller]: Accepted new action goal
      [move_group-3] [INFO] [1713256535.661379754] [moveit.simple_controller_manager.follow_joint_trajectory_controller_handle]: robot_arm_controller started execution
      [move_group-3] [INFO] [1713256535.661414754] [moveit.simple_controller_manager.follow_joint_trajectory_controller_handle]: Goal request accepted!
      [ros2_control_node-5] [INFO] [1713256545.758803767] [robot_arm_controller]: Goal reached, success!
      [move_group-3] [INFO] [1713256545.761655467] [moveit.simple_controller_manager.follow_joint_trajectory_controller_handle]: Controller 'robot_arm_controller' successfully finished
      [move_group-3] [INFO] [1713256545.789580068] [moveit_ros.trajectory_execution_manager]: Completed trajectory execution with status SUCCEEDED ...
      [move_group-3] [INFO] [1713256545.789703768] [moveit_move_group_default_capabilities.execute_trajectory_action_capability]: Execution completed: SUCCEEDED
      [rviz2-4] [INFO] [1713256545.790211768] [move_group_interface]: Execute request success!
      更改的文件:
      1. ros2_controllers.yaml:
      # This config file is used by ros2_control
      controller_manager:
        ros__parameters:
          update_rate: 100  # Hz
          robot_arm_controller:
            type: joint_trajectory_controller/JointTrajectoryController
          robot_hand_controller:
            type: position_controllers/GripperActionController
          joint_state_broadcaster:
            type: joint_state_broadcaster/JointStateBroadcaster
        ros__parameters:
          joints:
            - panda_joint1
            - panda_joint2
            - panda_joint3
            - panda_joint4
            - panda_joint5
            - panda_joint6
            - panda_joint7
          command_interfaces:
            # - position
            # changed:
            - velocity
          state_interfaces:
            - position
            - velocity
        ros__parameters:
          joint: panda_finger_joint1
      1. panda.ros2_control.xacro
      <?xml version="1.0"?>
        <xacro:macro name="panda_ros2_control" params="name initial_positions_file">
          <xacro:property name="initial_positions" value="${load_yaml(initial_positions_file)['initial_positions']}"/>
      <ros2_control name="${name}" type="system">
            <hardware>
              <!-- By default, set up controllers for simulation. This won't work on real hardware -->
              <plugin>mock_components/GenericSystem</plugin>
            </hardware>
            <joint name="panda_joint1">
              <!-- changed -->
              <command_interface name="velocity"/> <!-- position -->
              <state_interface name="position">
                <param name="initial_value">${initial_positions['panda_joint1']}</param>
          </state_interface>
          <state_interface name="velocity"/>
        </joint>
        <joint name="panda_joint2">
          <!-- changed -->
            <param name="initial_value">${initial_positions['panda_joint2']}</param>
              </state_interface>
            </joint>
            <joint name="panda_joint3">
              <!-- changed -->
                <param name="initial_value">${initial_positions['panda_joint3']}</param>
          </state_interface>
        </joint>
        <joint name="panda_joint4">
          <!-- changed -->
            <param name="initial_value">${initial_positions['panda_joint4']}</param>
              </state_interface>
            </joint>
            <joint name="panda_joint5">
              <!-- changed -->
                <param name="initial_value">${initial_positions['panda_joint5']}</param>
          </state_interface>
        </joint>
        <joint name="panda_joint6">
          <!-- changed -->
            <param name="initial_value">${initial_positions['panda_joint6']}</param>
              </state_interface>
            </joint>
            <joint name="panda_joint7">
              <!-- changed -->
                <param name="initial_value">${initial_positions['panda_joint7']}</param>
          </state_interface>
        </joint>
        <joint name="panda_finger_joint1">
          <command_interface name="position"/>
            <param name="initial_value">${initial_positions['panda_finger_joint1']}</param>
              </state_interface>
            </joint>
          </ros2_control>
        </xacro:macro>
      </robot>
        小鱼 技术大佬 @437985437
        @437985437 1.感觉是执行部分问题 2.查看下action的客户端和服务端,看看是否连接在一起
        4379854374 1 条回复 最后回复 回复 引用 0
        • 4379854374
          437985437 @小鱼
          补充:
          rqt_graph的结果如下:
          action的情况:
          命令:
          ros2 action info /robot_arm_controller/follow_joint_trajectory
          响应:
          Action: /robot_arm_controller/follow_joint_trajectory
          Action clients: 1
              /moveit_simple_controller_manager
          Action servers: 1
          • 4379854374
            437985437 @437985437
            @437985437
            图片有些模糊,再补充一下:
            • 4379854374
              437985437
              问题解决了,是ros2 control官方提供的硬件组件“mock_components/GenericSystem”的问题。
              我实现了一个新的硬件组件,仅将速度命令接口的值写入到速度状态接口,将位置命令接口的值写入为:position += velocity * period。
              然后可以正常通过 速度命令接口 来接入到 Moveit2 中,并规划机械臂位姿。
              还有疑惑的地方是,这个组件真的不支持速度命令接口吗?我没有在官网找到相关的内容。鱼大佬@小鱼 对这个有研究吗?
              官网文档:
              Mock Components — ROS2_Control: Humble Apr 2024 documentation
                小鱼 技术大佬 @437985437
                @437985437 暂时没有研究哈,蹲下一位大佬
