    ros2小车自主导航到达目标点后一直转圈问题
    Nav2
    nav2导航 ros2 humble
    5
    18
    4.5k
    • 仟
      仟仟在努力
      标题:[ros2小车自主导航成功到达目标点后仍一直转圈是为什么?]
      背景(可选):
      [要实现小车的自主导航]
      [在实现ros2小车的自主导航过程中,小车可以到达指定目标点,但到达后会进行旋转、直行或圆周运动等动作,其到达目标点后无法停止]
      尝试过的解决方法:
      • [我尝试过修改 xy_goal_tolerance、yaw_goal_tolerance、以及DWB的线速度、角速度、加速度等参数仍不起作用。]
      • [我还尝试检查过我的mpu6050传感器的数据,传递的数据没有什么问题。]
      • [还尝试过直接在行为树中添加停止动作。]
      这是我yaml文件的参数配置
      amcl:
       ros__parameters:
         use_sim_time: False
         alpha1: 0.9
         alpha2: 0.1
         alpha3: 0.05
         alpha4: 0.01
         alpha5: 0.04
         beam_skip_distance: 0.5
         beam_skip_threshold: 0.3
         do_beamskip: false
         global_frame_id: "map"
         lambda_short: 0.1
         laser_max_range: 100.0
         laser_min_range: -1.0
         max_beams: 60
         max_particles: 2000
         min_particles: 500
         odom_frame_id: "odom_combined"
         pf_err: 0.02
         pf_z: 0.85
         recovery_alpha_fast: 0.0
         recovery_alpha_slow: 0.0
         resample_interval: 2
         robot_model_type: "nav2_amcl::DifferentialMotionModel"
         save_pose_rate: 0.5
         sigma_hit: 0.02
         tf_broadcast: true
         transform_tolerance: 0.3
         update_min_a: 0.06
         update_min_d: 0.025
         z_hit: 0.7
         z_max: 0.001
         z_rand: 0.059
         z_short: 0.24
         scan_topic: scan
         # Initial Pose
         set_initial_pose: True
         initial_pose.x: 0.0
         initial_pose.y: 0.0
         initial_pose.z: 0.0
         initial_pose.yaw: 0.0
      amcl_map_client:
       ros__parameters:
         use_sim_time: False
      amcl_rclcpp_node:
       ros__parameters:
         use_sim_time: False
      bt_navigator:
       ros__parameters:
         use_sim_time: False
         global_frame: map
         robot_base_frame: base_footprint
         odom_topic: /odom_combined
         bt_loop_duration: 10
         default_server_timeout: 20
         plugin_lib_names:
         - nav2_smooth_path_action_bt_node
         - nav2_spin_action_bt_node
         - nav2_wait_action_bt_node
         - nav2_back_up_action_bt_node
         - nav2_drive_on_heading_bt_node
         - nav2_globally_updated_goal_condition_bt_node
         - nav2_is_path_valid_condition_bt_node
         - nav2_truncate_path_local_action_bt_node
         - nav2_recovery_node_bt_node
         - nav2_path_expiring_timer_condition
         - nav2_single_trigger_bt_node
         # - nav2_goal_updated_controller_bt_node
         - nav2_controller_cancel_bt_node
         - nav2_path_longer_on_approach_bt_node
         - nav2_wait_cancel_bt_node
         - nav2_spin_cancel_bt_node
         - nav2_back_up_cancel_bt_node
         - nav2_drive_on_heading_cancel_bt_node
      bt_navigator_rclcpp_node:
       ros__parameters:
         use_sim_time: False
      controller_server:
       ros__parameters:
         use_sim_time: False
         controller_frequency: 5.0
         min_x_velocity_threshold: 0.001
         min_y_velocity_threshold: 0.5
         min_theta_velocity_threshold: 0.001
         failure_tolerance: 0.3
         progress_checker_plugin: "progress_checker"
         goal_checker_plugins: ["general_goal_checker"] # "precise_goal_checker"
         controller_plugins: ["FollowPath"]
         # Progress checker parameters
         progress_checker:
           plugin: "nav2_controller::SimpleProgressChecker"
           required_movement_radius: 0.5
           movement_time_allowance: 10.0
         # Goal checker parameters
         #precise_goal_checker:
         #  plugin: "nav2_controller::SimpleGoalChecker"
         #  xy_goal_tolerance: 0.25
         #  yaw_goal_tolerance: 0.25
         #  stateful: True
         general_goal_checker:
           stateful: True
           xy_goal_tolerance: 0.20
           yaw_goal_tolerance: 0.20
         # DWB parameters
         FollowPath:
           plugin: "dwb_core::DWBLocalPlanner"
           debug_trajectory_details: True
           min_vel_x: -0.5
           min_vel_y: 0.0
           max_vel_x: 0.5
           max_vel_y: 0.0
           max_vel_theta: 1.0
           min_speed_xy: -0.1
           max_speed_xy: 0.5
           min_speed_theta: 0.0
           acc_lim_x: 0.5
           acc_lim_y: 0.0
           acc_lim_theta: 0.5
           decel_lim_x: -0.3
           decel_lim_y: 0.0
           decel_lim_theta: -0.3
           # 逆时针为正,顺时针为负,--这为顺时针的加速度
           vx_samples: 20
           vy_samples: 0
           vtheta_samples: 60
           sim_time: 1.0
           linear_granularity: 0.05
           angular_granularity: 0.025
           transform_tolerance: 0.2
           trans_stopped_velocity: 0.25
           short_circuit_trajectory_evaluation: True
           stateful: True
           critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
           BaseObstacle.scale: 0.04
           PathAlign.scale: 50.0
           PathAlign.forward_point_distance: 0.1
           GoalAlign.scale: 10.0
           GoalAlign.forward_point_distance: 0.1
           PathDist.scale: 50.0
           GoalDist.scale: 10.0
           RotateToGoal.scale: 32.0
           RotateToGoal.slowing_factor: 5.0
           RotateToGoal.lookahead_time: -1.0
      controller_server_rclcpp_node:
       ros__parameters:
         use_sim_time: False
      local_costmap:
       local_costmap:
         ros__parameters:
           update_frequency: 5.0
           publish_frequency: 1.0
           global_frame: odom_combined
           use_sim_time: False
           rolling_window: true
           width: 4
           height: 4
           resolution: 0.05
           footprint: "[ [-0.58, -0.26], [-0.58, 0.26], [0.17, 0.26], [0.17, -0.26] ]"
           plugins: ["voxel_layer", "inflation_layer"]
           inflation_layer:
             cost_scaling_factor: 3.0    #成本缩放因子
             inflation_radius: 0.45
           voxel_layer:
             plugin: "nav2_costmap_2d::VoxelLayer"
             enabled: True
             publish_voxel_map: True
             origin_z: 0.0
             z_resolution: 0.05
             z_voxels: 16
             max_obstacle_height: 2.0
             mark_threshold: 0
             observation_sources: scan
             scan:
               topic: /scan
               clearing: True
               marking: True
               data_type: "LaserScan"
               raytrace_max_range: 10.0
               raytrace_min_range: 0.0
               obstacle_max_range: 2.5
               obstacle_min_range: 0.0
       local_costmap_client:
         ros__parameters:
           use_sim_time: False
       local_costmap_rclcpp_node:
         ros__parameters:
           use_sim_time: False
      global_costmap:
       global_costmap:
         ros__parameters:
           update_frequency: 1.0
           global_frame: map
           use_sim_time: False
           # robot_radius: 0.20
           resolution: 0.05
           track_unknown_space: true
           obstacle_layer:
             enabled: True
             scan:
               topic: /scan
               clearing: True
               marking: True
           static_layer:
           inflation_layer:
             inflation_radius: 0.65
       global_costmap_client:
         ros__parameters:
           use_sim_time: False
       global_costmap_rclcpp_node:
         ros__parameters:
           use_sim_time: False
      map_server:
       ros__parameters:
         use_sim_time: False
         yaml_filename: "turtlebot3_world.yaml"
      map_saver:
       ros__parameters:
         use_sim_time: False
         save_map_timeout: 5.0
         free_thresh_default: 0.25
         occupied_thresh_default: 0.65
      # planner_server:
      #   ros__parameters:
      #     use_sim_time: False
      #     planner_plugins: ["GridBased"]
      #     GridBased:
      #       plugin: "nav2_navfn_planner/NavfnPlanner"
      #       tolerance: 0.5
      #       use_astar: true
      #       allow_unknown: true
      planner_server:
       ros__parameters:
         expected_planner_frequency: 20.0
         use_sim_time: False
         GridBased:
           plugin: "nav2_smac_planner/SmacPlanner2D"
           tolerance: 0.5  # 规划容差,如果无法精确到达目标位置,允许的最大误差,单位为米
           downsample_costmap: false
           downsampling_factor: 1
           allow_unknown: true
           max_iterations: 1000000
           max_on_approach_iterations: 1000
           max_planning_time: 2.0
           cost_travel_multiplier: 2.0
           use_final_approach_orientation: false
           smoother:
             w_smooth: 0.3
             w_data: 0.2
             tolerance: 1.0e-10
      planner_server_rclcpp_node:
       ros__parameters:
         use_sim_time: False
      # smoother_server:
      #   ros__parameters:
      #     use_sim_time: True
      #     smoother_plugins: ["simple_smoother"]
      #     simple_smoother:
      #       plugin: "nav2_smoother::SimpleSmoother"
      #       tolerance: 1.0e-10
      #       max_its: 1000
      #       do_refinement: True
      behavior_server:
       ros__parameters:
         costmap_topic: local_costmap/costmap_raw
         footprint_topic: local_costmap/published_footprint
         cycle_frequency: 10.0
         behavior_plugins: ["spin", "backup", "drive_on_heading", "wait"]
         spin:
           plugin: "nav2_behaviors/Spin"
         backup:
           plugin: "nav2_behaviors/BackUp"
         drive_on_heading:
           plugin: "nav2_behaviors/DriveOnHeading"
         wait:
           plugin: "nav2_behaviors/Wait"
         transform_tolerance: 0.1
         use_sim_time: False
         simulate_ahead_time: 2.0
         max_rotational_vel: 0.3
         min_rotational_vel: 0.05
         rotational_acc_lim: 0.3
      robot_state_publisher:
       ros__parameters:
         use_sim_time: False
      waypoint_follower:
       ros__parameters:
         loop_rate: 20
         stop_on_failure: false
         waypoint_task_executor_plugin: "wait_at_waypoint"
         wait_at_waypoint:
           plugin: "nav2_waypoint_follower::WaitAtWaypoint"
           enabled: True
           waypoint_pause_duration: 200
      • 如果有知道或了解的朋友,麻烦您指点一二。在此先谢过大家了😆
      • 我不知道还会是什么问题,也不知道提供的资料全面不,如果不够全面,希望你们告知我,谢谢大家。😀
        针对您描述的ROS2小车自主导航到达目标点后继续转圈的问题,这里有几个可能的原因和相应的解决策略:
        1. 目标点判断不准确
        • 检查 yaw_goal_tolerance 和 xy_goal_tolerance:您已经尝试过调整这些参数,但可能需要更细致地调整。确保这些参数适合您的小车和环境。如果小车到达目标位置附近但旋转角度稍有偏差,它可能会继续尝试调整方向。
        • 检查地图和定位精度:确保地图的精度足够,并且小车的定位(如AMCL)准确。定位误差可能导致小车认为它还没有到达目标点。
        2. 行为树配置
        • 检查行为树逻辑:行为树可能配置了在达到目标点后继续执行的动作(如旋转或等待)。确保在目标达成后有一个明确的“停止”或“退出”节点。
        • 添加“停止”行为:如果行为树中没有“停止”行为,您应该添加一个,并确保它在达到目标点后执行。
        3. 局部规划器(如DWB)配置
        • 检查DWB的“RotateToGoal”评分器:DWB的“RotateToGoal”评分器可能在目标点附近仍然给予较高的评分,导致小车继续旋转。检查其参数,如scale、slowing_factor和lookahead_time,确保它们适合您的场景。
        • 检查其他评分器:确保没有其他评分器(如Oscillation)阻止小车停止。
        4. 控制器和传感器数据
        • 检查传感器数据:虽然您提到MPU6050数据没有问题,但请确保所有相关的传感器(如里程计、陀螺仪等)都在正常工作,并且数据准确。
        • 控制器反馈:检查控制器的反馈机制,确保它正确响应来自行为树和规划器的指令。
        5. 日志和调试
        • 查看ROS日志:检查ROS的日志输出,看是否有任何错误或警告信息可能与这个问题相关。
        • 使用调试工具:使用如rviz等工具来可视化小车的状态、路径和目标点,以帮助诊断问题。
        6. 硬件问题
        • 检查机械结构:确保小车的机械结构没有问题,如轮子没有卡住或打滑。
        • 电机和驱动器:确保电机和驱动器正常工作,没有过热或损坏的迹象。
        7. 软件和环境
        • 更新和兼容性:确保ROS2和所有相关包的版本都是最新的,并且彼此兼容。
        • 环境问题:如果可能,尝试在不同的环境或模拟中运行相同的配置,以排除特定环境问题。
        通过上述步骤,您应该能够更接近问题的根源,并找到解决方案。如果问题仍然存在,您可能需要更详细地检查您的系统配置或寻求来自ROS2社区的帮助。
        仟 3 条回复 最后回复 回复 引用 0
        • 仟
          仟仟在努力 @小伊
          还有这个日志输出
            要准确地诊断和解决 RViz2 中的报错,我需要具体的错误消息和日志输出。不过,我可以提供一些一般性的建议和步骤,这些步骤可以帮助你调查和解决 RViz2 中可能遇到的问题。
            1. 检查 ROS 2 环境
            确保你的 ROS 2 环境已经正确设置,并且所有必要的包都已安装。你可以通过运行以下命令来检查 ROS 2 是否正确安装:
            ros2 --version
            2. 查看 RViz2 日志
            通常,RViz2 的错误会输出到控制台或日志文件中。如果你在使用 RViz2 时没有看到明显的错误消息,可以尝试在命令行中启动 RViz2 并查看输出。
            例如,使用以下命令启动 RViz2 并查看输出:
            rviz2
            或者,如果你从另一个 ROS 2 节点或脚本中启动 RViz2,确保检查该节点或脚本的输出。
            3. 检查 RViz2 配置文件
            如果你在使用 RViz2 的配置文件(.rviz 文件),请确保该文件没有损坏,并且与你的 ROS 2 环境兼容。尝试创建一个新的 RViz2 配置文件并检查问题是否仍然存在。
            4. 检查传感器和话题数据
            确保 RViz2 订阅的话题正在被正确发布。你可以使用 ros2 topic list 命令来查看当前发布的话题列表,并使用 ros2 topic echo <topic_name> 来查看话题的内容。
            5. 检查依赖项和插件
            RViz2 使用插件来显示不同类型的数据。确保所有必要的插件都已正确安装,并且 RViz2 的配置文件已正确配置以使用这些插件。
            6. 更新和重新安装
            如果问题仍然存在,尝试更新你的 ROS 2 和 RViz2 到最新版本。有时,软件更新可以解决已知的 bug 或兼容性问题。
            sudo apt update
            sudo apt upgrade
            sudo apt install --only-upgrade ros-<distro>-rviz2
            替换 <distro> 为你的 ROS 2 发行版名称,如 foxy、galactic 等。
            7. 查看社区和文档
            如果上述步骤都不能解决问题,建议查看 ROS 2 社区论坛、GitHub 问题跟踪器或官方文档,看看是否有其他人遇到了类似的问题,并找到了解决方案。
            8. 提交错误报告
            如果你认为你遇到的问题是一个 bug,并且没有在社区中找到解决方案,考虑在 ROS 2 的 GitHub 仓库中提交一个错误报告。
            希望这些步骤能帮助你解决 RViz2 中的问题!如果你能提供具体的错误消息或日志输出,我可以提供更具体的帮助。
            • 仟
              仟仟在努力 @小伊
              @小伊 应如何修改RotateToGoal参数?
                要修改RotateToGoal参数的具体方法,首先需要明确RotateToGoal是一个什么样的函数或方法,以及它通常用于什么场景(比如机器人导航、游戏编程、图形界面编程等)。不过,基于这个名字的通用性,我们可以假设它用于让某个对象(如机器人、游戏角色或界面元素)旋转以面向一个目标位置或方向。
                在没有具体编程语言或框架的上下文中,我可以提供一些一般性的指导来修改这样的参数:
                1. 确定参数
                首先,需要了解RotateToGoal函数或方法接受哪些参数。这些参数可能包括:
                • 目标位置(比如一个坐标点或方向向量)
                • 旋转速度(每秒旋转多少度或弧度)
                • 旋转模式(是否连续旋转直到面向目标,还是只旋转一次)
                • 回调函数(旋转完成后执行的函数)
                2. 修改参数
                修改目标位置
                如果RotateToGoal依赖于一个目标位置参数,你可以直接修改这个参数来改变旋转的终点。例如,在Python中,如果函数定义如下:
                def RotateToGoal(target_position):
                    # 实现旋转逻辑
                    pass
                # 修改前
                old_target = (100, 200)
                RotateToGoal(old_target)
                # 修改后
                new_target = (300, 400)
                RotateToGoal(new_target)
                修改旋转速度
                如果RotateToGoal接受旋转速度作为参数,你可以通过修改这个参数来加速或减速旋转。例如:
                def RotateToGoal(target_position, speed):
                    # 实现旋转逻辑,使用speed参数
                    pass
                # 修改前
                RotateToGoal((100, 200), 10)  # 假设10表示每秒10度的旋转速度
                # 修改后
                RotateToGoal((100, 200), 20)  # 现在每秒旋转20度
                修改旋转模式或添加回调函数
                对于更复杂的参数,如旋转模式或回调函数,你需要根据RotateToGoal的具体实现来修改。如果函数支持这些参数,你可以直接传递不同的值或函数来改变行为。
                3. 注意事项
                • 在修改参数之前,确保理解每个参数的作用和RotateToGoal函数的实现细节。
                • 考虑到性能影响,特别是当旋转速度非常快或非常慢时。
                • 如果RotateToGoal是在多线程或异步环境中运行,确保参数修改是线程安全的。
                最后,由于具体的实现细节会根据你使用的编程语言、框架或库而有所不同,因此建议查阅相关的文档或源代码以获得最准确的指导。
                • 仟
                  仟仟在努力 @小伊
                  @小伊 在 ros2小车自主导航到达目标点后一直转圈问题 中说:
                  1. 目标点判断不准确
                  2. 行为树配置
                  3. 局部规划器(如DWB)配置
                  4. 控制器和传感器数据
                  5. 日志和调试
                  6. 硬件问题
                  7. 软件和环境
                  修改完“RotateToGoal”评分器**中的参数,小车到达目标点仍未停止
                    如果修改完 RotateToGoal 评分器中的参数后,小车到达目标点仍未停止,这可能表明问题不仅仅局限于该评分器本身,或者修改的参数可能不够细致或者不适合当前的环境和硬件配置。以下是一些进一步的排查和解决步骤:
                    1. 重新审视评分器参数:
                      • scale:这个参数决定了旋转到目标点的评分在总体评分中的权重。如果设置得太高,即使小车已经很接近目标点,它也可能继续旋转以优化这个评分。
                      • slowing_factor:此参数影响小车接近目标时旋转速度的减缓程度。确保这个值设置得足够大,以便小车在接近目标时能够平稳减速。
                      • lookahead_time:这个参数定义了小车在预测未来路径时考虑的时间范围。如果设置得太长,小车可能会基于未来可能的路径调整而继续旋转,即使它当前已经接近目标点。
                    2. 检查其他评分器:
                      • 确保没有其他评分器(如 PathDistanceScore、GoalDistanceScore、OscillationScore 等)的权重或行为导致小车持续旋转。特别是 OscillationScore,它可能检测到小车的轻微震荡并尝试通过旋转来纠正。
                    3. 行为树和状态机:
                      • 仔细检查行为树中的逻辑,确保在达到目标点后有一个明确的停止或退出状态。
                      • 使用行为树的可视化工具(如果可用)来跟踪小车的行为状态,确保它按照预期的方式运行。
                    4. 动态窗口方法(DWB)的整体配置:
                      • 检查 DWB 的其他配置参数,如速度限制、加速度限制等,以确保它们适合小车的物理特性和当前的环境。
                    5. 环境和障碍物:
                      • 考虑小车周围的环境和障碍物。如果目标点附近存在复杂的障碍物或动态物体,它们可能影响到小车的决策过程。
                      • 尝试在更简单的环境中测试小车,以排除环境因素的干扰。
                    6. 传感器和定位:
                      • 再次检查所有传感器的数据质量和准确性,特别是与定位相关的传感器(如激光雷达、里程计等)。
                      • 验证小车的定位算法(如 AMCL)是否准确,并尝试使用不同的定位方法进行比较。
                    7. 记录和回放:
                      • 使用 ROS 的记录包(如 rosbag)来记录小车的行为,并在之后进行回放和分析。这有助于更详细地了解小车在到达目标点时的行为。
                    8. 社区和文档:
                      • 查阅 ROS2 社区和相关的论坛、文档,看看是否有其他用户遇到并解决了类似的问题。
                      • 考虑在 ROS2 的官方问题跟踪系统(如 GitHub Issues)中提交问题,并附上详细的描述、日志和配置信息。
                    9. 硬件检查:
                      • 最后,确保小车的硬件(如电机、驱动器、电池等)都在正常工作状态,并且没有过热或损坏的迹象。
                    通过综合以上方法,您应该能够更全面地诊断和解决小车到达目标点后继续旋转的问题。
                    仟 1 条回复 最后回复 回复 引用 0
                    • 仟
                      仟仟在努力 @小伊
                      @小伊 d99f39f2-686d-46d9-9a3e-26bdd6bd78b1-image.png 这个tf坐标树是正常的吗?
                        在机器人学、计算机视觉或任何需要坐标变换的领域中,tf(Transform)坐标树(或称为坐标框架树)是一种常用的工具,用于表示不同坐标系之间的相对位置和姿态。要判断一个tf坐标树是否“正常”,我们需要考虑几个关键方面:
                        1. 完整性:tf坐标树应该包含所有必要的坐标系,这些坐标系对于执行所需的任务是必需的。例如,在机器人导航中,你可能需要基坐标系(通常是机器人的中心点或某个固定点)、相机坐标系、机械臂末端执行器坐标系等。
                        2. 一致性:坐标树中的每个坐标系都应该有明确的父坐标系,并且这种父子关系应该是逻辑上一致的。例如,相机坐标系通常是固定在某个机械臂或机器人身体上的,因此它应该是该机械臂或机器人身体坐标系的子坐标系。
                        3. 无循环:tf坐标树中不应存在循环依赖,即没有一个坐标系直接或间接地成为自己的祖先。这会导致逻辑上的混乱和计算上的错误。
                        4. 正确的变换:每个坐标系到其父坐标系的变换(包括平移和旋转)应该是准确和恰当的。这通常通过精确的标定和校准过程来确保。
                        5. 实时性:在动态环境中,tf坐标树的更新应该足够快,以反映系统的当前状态。过时的变换可能会导致控制错误或导航失败。
                        6. 错误处理:tf系统应该有机制来处理变换不存在或不一致的情况,例如通过提供默认变换或发出警告/错误消息。
                        如果你有一个具体的tf坐标树实例,并且想要检查它是否“正常”,你可以根据上述标准进行检查。然而,没有具体的tf坐标树描述或图形,我只能给出一般性的指导。如果你能提供更多的上下文或具体的tf坐标树描述,我可以给出更具体的建议。
                        此外,许多机器人和计算机视觉库(如ROS的tf库)提供了工具和功能来可视化tf坐标树,这可以帮助你直观地检查其结构和状态。
                        • D
                          dr_engine
                          我也有这个问题,到达目标点之后不会径直转向目标方向,会绕一圈或者左右左右扭扭,中间有机会转到目标方向后才有可能停
                          我怀疑和nav2_bringup下默认的行为树有关系
                          • 仟
                            仟仟在努力 @dr_engine
                            @yyl573683368 我是在小车到达目标点后添加了个等待,就是在行为树中添加的,然后小车可以停在目标点了,但是小车到达目标点的方向误差挺大的而且容易跑甭,所以我觉得在行为树中添加等待是不对的,你的找到问题了吗?
                            D 1 条回复 最后回复 回复 引用 0
                            • D
                              dr_engine @仟仟在努力
                              @仟仟在努力 我用的是default那个行为树,到达目标点但是角度不对时会进入recovery,会spin旋转一个角度然后backup倒退一段距离,不知道你有没有这个现象
                              • 仟
                                仟仟在努力 @dr_engine
                                @dr_engine 那可能是yaw_goal_tolerance 、xy_goal_tolerance设置的太小了,你改大点试试呢
                                • 传
                                  传说鲈鱼狸
                                  请问这个问题解决了吗?
                                  • 仟
                                    仟仟在努力 @传说鲈鱼狸
                                    @传说鲈鱼狸 算解决了吧,就在小车到达目标点后添加了个等待就停了。
                                    3 1 条回复 最后回复 回复 引用 0
                                      3104827606 @仟仟在努力
                                      @仟仟在努力 您好,请问等待的节点直接用源码中有的节点就可以吧,具体改哪个文件可以说一下吗
                                      • 仟
                                        仟仟在努力 @3104827606
                                        @3104827606 就改了一下行为树中的等待
