    Gazebo与RViz联合仿真时odom消失
    17.7k
    • 9
      924453613
      irobot.urdf(sw2urdf导出urdf+differ_controller+laser)
      odom_gazebo.launch
      odom_rviz.launch
      联合仿真时出现问题:
      RViz单独仿真无问题:
      • 9
        924453613
        最后由 924453613 编辑
        irobot.urdf
        <?xml version="1.0" encoding="utf-8"?>
        <robot
          name="irobot">
          <link
            name="base_footprint">
            <visual>
              <geometry>
                <sphere
                  radius="0.001" />
              </geometry>
              <material
                name="">
                <color
                  rgba="0 0 0 0" />
              </material>
            </visual>
          </link>
          <link
            name="base_link">
            <inertial>
              <origin
                xyz="0.0353 6.2375E-05 0.0378"
                rpy="0 0 0" />
              <mass
                value="4.4466" />
              <inertia
                ixx="0.037776"
                ixy="0"
                ixz="0"
                iyy="0.026331"
                iyz="0"
                izz="0.060251" />
            </inertial>
            <visual>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
                  filename="package://irobot/meshes/base_link.STL" />
              </geometry>
              <material
                name="">
                <color
                  rgba="0 0 0 1" />
              </material>
            </visual>
            <collision>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
              </geometry>
            </collision>
          </link>
          <joint
            name="base_link2base_footprint"
            type="fixed">
                <parent
                  link="base_footprint" />
                <child
                  link="base_link" />
                <origin
                  xyz="0 0 0.011" />
                <!--irobot_height/2-->
          </joint>
          <link
            name="top_link">
            <inertial>
              <origin
                xyz="-0.005083 -0.000153 0.000877"
                rpy="0 0 0" />
              <mass
                value="0.11187" />
              <inertia
                ixx="0.0008137"
                ixy="0"
                ixz="0"
                iyy="0.00071"
                iyz="0"
                izz="0.001524" />
            </inertial>
            <visual>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
                  filename="package://irobot/meshes/top_link.STL" />
              </geometry>
              <material
                name="">
                <color
                  rgba="0 1 0 1" />
              </material>
            </visual>
            <collision>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
              </geometry>
            </collision>
          </link>
          <joint
            name="top_joint"
            type="fixed">
            <origin
              xyz="0 0 0.0699"
              rpy="0 0 0" />
            <parent
              link="base_link" />
            <child
              link="top_link" />
            <axis
              xyz="0 0 0" />
            <limit
              lower="0"
              upper="0"
              effort="0"
              velocity="0" />
          </joint>
          <link
            name="laser_link">
            <inertial>
              <origin
                xyz="-4.0578E-09 2.09E-09 0.00303"
                rpy="0 0 0" />
              <mass
                value="0.001737" />
              <inertia
                ixx="4.1116E-08"
                ixy="0"
                ixz="0"
                iyy="4.1116E-08"
                iyz="0"
                izz="7.8771E-08" />
            </inertial>
            <visual>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
                  filename="package://irobot/meshes/laser_link.STL" />
              </geometry>
              <material
                name="">
                <color
                  rgba="1 0 0 1" />
              </material>
            </visual>
            <collision>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
              </geometry>
            </collision>
          </link>
          <joint
            name="laser_joint"
            type="fixed">
            <origin
              xyz="0.155 0 0.07433"
              rpy="0 0 0" />
            <parent
              link="base_link" />
            <child
              link="laser_link" />
            <axis
              xyz="0 0 0" />
            <limit
              lower="0"
              upper="0"
              effort="0"
              velocity="0" />
          </joint>
          <link
            name="driven_link">
            <inertial>
              <origin
                xyz="0 -4.6809E-19 4.3368E-19"
                rpy="0 0 0" />
              <mass
                value="0.014137" />
              <inertia
                ixx="1.2723E-06"
                ixy="0"
                ixz="0"
                iyy="1.2723E-06"
                iyz="0"
                izz="1.2723E-06" />
            </inertial>
            <visual>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
                  filename="package://irobot/meshes/driven_link.STL" />
              </geometry>
              <material
                name="">
                <color
                  rgba="1 1 1 1" />
              </material>
            </visual>
            <collision>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
              </geometry>
            </collision>
          </link>
          <joint
            name="driven_joint"
            type="continuous">
            <origin
              xyz="0.13 0 0.00438"
              rpy="0 0 0" />
            <parent
              link="base_link" />
            <child
              link="driven_link" />
            <axis
              xyz="0 0 1" />
            <limit
              lower="-3.14"
              upper="3.14"
              effort="0"
              velocity="0" />
          </joint>
          <link
            name="left_wheel_link">
            <inertial>
              <origin
                xyz="5.9165E-31 -1.3878E-17 3.4694E-18"
                rpy="0 0 0" />
              <mass
                value="0.066366" />
              <inertia
                ixx="2.2972E-05"
                ixy="0"
                ixz="0"
                iyy="2.2972E-05"
                iyz="0"
                izz="4.3005E-05" />
            </inertial>
            <visual>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
                  filename="package://irobot/meshes/left_wheel_link.STL" />
              </geometry>
              <material
                name="">
                <color
                  rgba="1 1 1 1" />
              </material>
            </visual>
            <collision>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
              </geometry>
            </collision>
          </link>
          <joint
            name="left_wheel_joint"
            type="continuous">
            <origin
              xyz="0 -0.10045 0.02538"
              rpy="0 0 0" />
            <parent
              link="base_link" />
            <child
              link="left_wheel_link" />
            <axis
              xyz="0 -1 0" />
            <limit
              lower="-3.14"
              upper="3.14"
              effort="0"
              velocity="0" />
          </joint>
          <link
            name="right_wheel_link">
            <inertial>
              <origin
                xyz="-1.5766E-18 1.3878E-17 3.4694E-18"
                rpy="0 0 0" />
              <mass
                value="0.066366" />
              <inertia
                ixx="2.2972E-05"
                ixy="0"
                ixz="0"
                iyy="2.2972E-05"
                iyz="0"
                izz="4.3005E-05" />
            </inertial>
            <visual>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
                  filename="package://irobot/meshes/right_wheel_link.STL" />
              </geometry>
              <material
                name="">
                <color
                  rgba="1 1 1 1" />
              </material>
            </visual>
            <collision>
              <origin
                xyz="0 0 0"
                rpy="0 0 0" />
              <geometry>
                <mesh
              </geometry>
            </collision>
          </link>
          <joint
            name="right_wheel_joint"
            type="continuous">
            <origin
              xyz="0 0.10045 0.02538"
              rpy="0 0 0" />
            <parent
              link="base_link" />
            <child
              link="right_wheel_link" />
            <axis
              xyz="0 -1 0" />
            <limit
              lower="-3.14"
              upper="3.14"
              effort="0"
              velocity="0" />
          </joint>
        <!--color-->
          <gazebo reference="base_link">
          </gazebo>
          <gazebo reference="top_link">
            <material>Gazebo/Green</material>
          </gazebo>
          <gazebo reference="laser_link">
            <material>Gazebo/Red</material>
          </gazebo>
          <gazebo reference="camera_link">
          </gazebo>
          <gazebo reference="driven_link">
            <material>Gazebo/White</material>
          </gazebo>
          <gazebo reference="left_wheel_link">
          </gazebo>
          <gazebo reference="right_wheel_link">
          </gazebo>
          <!-- controller -->
          <transmission name="left_wheel_joint_trans">
            <type>transmission_interface/SimpleTransmission</type>
            <joint name="left_wheel_joint">
              <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface>
            </joint>
            <actuator name="left_wheel_joint_motor">
              <mechanicalReduction>1</mechanicalReduction>
            </actuator>
          </transmission>
          <transmission name="right_wheel_joint_trans">
            <joint name="right_wheel_joint">
            </joint>
            <actuator name="right_wheel_joint_motor">
            </actuator>
          </transmission>
          <gazebo>
            <plugin filename="libgazebo_ros_diff_drive.so" name="differential_drive_controller">
              <rosDebugLevel>Debug</rosDebugLevel>
              <publishWheelTF>true</publishWheelTF>
              <robotNamespace>/</robotNamespace>
              <publishTf>1</publishTf>
              <publishWheelJointState>true</publishWheelJointState>
              <alwaysOn>true</alwaysOn>
              <updateRate>100.0</updateRate>
              <legacyMode>true</legacyMode>
              <leftJoint>left_wheel_joint</leftJoint>
              <rightJoint>right_wheel_joint</rightJoint>
              <wheelSeparation>0.277</wheelSeparation>
              <wheelDiameter>0.073</wheelDiameter>
              <broadcastTF>1</broadcastTF>
              <wheelTorque>30</wheelTorque>
              <wheelAcceleration>1.8</wheelAcceleration>
              <commandTopic>cmd_vel</commandTopic>
              <odometryFrame>odom</odometryFrame>
              <odometryTopic>odom</odometryTopic>
              <robotBaseFrame>base_footprint</robotBaseFrame>
            </plugin>
          </gazebo>
          <!--laser-->
            <sensor name="rplidar" type="ray">
              <pose>0 0 0 0 0 0</pose>
              <visualize>true</visualize>
              <update_rate>5.5</update_rate>
              <ray>
                <scan>
                  <horizontal>
                    <samples>360</samples>
                    <resolution>1</resolution>
                    <min_angle>-3</min_angle>
                    <max_angle>3</max_angle>
                  </horizontal>
                </scan>
                <range>
                  <min>0.10</min>
                  <max>30.0</max>
                  <resolution>0.01</resolution>
                </range>
                <noise>
                  <type>gaussian</type>
                  <mean>0.0</mean>
                  <stddev>0.01</stddev>
                </noise>
              </ray>
              <plugin filename="libgazebo_ros_laser.so" name="gazebo_rplidar">
                <topicName>/scan</topicName>
                <frameName>laser_link</frameName>
              </plugin>
            </sensor>
          </gazebo>
        </robot>
        odom_gazebo.launch
        <launch>
          <param
            name="robot_description"
            textfile="$(find irobot)/urdf/irobot.urdf" />
          <include
            file="$(find gazebo_ros)/launch/empty_world.launch"/>
          <node
            name="tf_footprint_base"
            pkg="tf"
            type="static_transform_publisher"
            args="0 0 0 0 0 0 base_link base_footprint 40" />
          <node
            pkg="gazebo_ros"
            type="spawn_model"
            name="model"
            args="-urdf -model irobot -param robot_description"  />
          <node
            name="fake_joint_calibration"
            pkg="rostopic"
            type="rostopic"
            args="pub /calibrated std_msgs/Bool true" />
        </launch>
        odom_rviz.launch
        <launch>
            <param
          <node
            name="rviz"
            pkg="rviz"
            type="rviz"
            args="-d $(find irobot)/config/irobot.rviz" />
          <node
            name="joint_state_publisher_gui"
            pkg="joint_state_publisher_gui"
            type="joint_state_publisher_gui" />
          <node
            name="robot_state_publisher"
            pkg="robot_state_publisher"
            type="robot_state_publisher" />
          <node name="arbotix" pkg="arbotix_python" type="arbotix_driver" output="screen">
            <rosparam file="$(find irobot)/config/diff_controller.yaml" command="load" />
            <param name="sim" value="true" />
          </node>
        </launch>
          初步估计是TF问题,晚点我看一下,代码可以改成用代码块包裹一下,太长了,不好看。
          • 9
            924453613
            小伊小 1 条回复 最后回复 回复 引用 0
              机器人小伊 @924453613
              @924453613 每个帖子都可以再次编辑和删除的,不用再发一个哈哈,菜单在右下角。
                小鱼 技术大佬 @924453613
                @924453613
                需要补充一些内容
                • 补充一下rqt_tf_tree的截图
                • 补充一下gazebo版本系统版本和ros版本
                • 补充config/diff_controller.yaml文件内容
                同时做如下的尝试:
                • 从odom_rviz.launch删除arbotix节点后运行
                • 9
                  924453613
                  rqt_tf_tree
                  ubuntu18.04-melodic-gazebo11
                  # 该文件是控制器配置,一个机器人模型可能有多个控制器,比如: 底盘、机械臂、夹持器(机械手)....
                  # 因此,根 name 是 controller
                  controllers: {
                     # 单控制器设置
                     base_controller: {
                            #类型: 差速控制器
                         type: diff_controller,
                         #参考坐标
                         base_frame_id: base_footprint,
                         #两个轮子之间的间距
                         base_width: 0.277,
                         #控制频率
                         ticks_meter: 2000,
                         #PID控制参数,使机器人车轮快速达到预期速度
                         Kp: 12,
                         Kd: 12,
                         Ki: 0,
                         Ko: 50,
                         #加速限制
                         accel_limit: 1.0
                  删除arbotix结果
                    小鱼 技术大佬 @924453613
                    @924453613 看一下rqt_grapher,有几个joint_states的发布者。
                    9 1 条回复 最后回复 回复 引用 0
                    • 9
                      924453613 @小鱼
                      @小鱼 只有一个
                        小鱼 技术大佬 @924453613
                        @924453613 这个rqt_graph看起来非常不对劲。因为两轮差速这边也会发布机器人的joint_states,所以不需要再启动joint_state_publisher。
                        修改odom_rviz.py
                        <launch>
                            <param
                          <node
                            name="rviz"
                            pkg="rviz"
                            type="rviz"
                          <node
                          </node>
                        </launch>
                        • 9
                          924453613 @小鱼
                          @小鱼 有rqt_graph了 RViz中tf还是断开的
                            小鱼 技术大佬 @924453613
                            @924453613 你看这里,一个话题有两个发布者,robot_state_publisher都不知道听谁的,所以导致TF错误,按照我上一条回复把joint_state_publisher干掉试试。
                            • 9
                              924453613 @小鱼
                              最后由 924453613 编辑
                              干掉之后是这样的 RViz中tf还是断开的
                                小鱼 技术大佬 @924453613
                                @924453613 现在还是有两个发布者在发布joint_states,只需要一个gazebo即可,请按照之前帖子里的提示删掉arbotix控制器程序。
                                另外需要注意的是,arbotix的功能和urdf中配置的differential_drive_controller功能是相同(从两者的配置可以看出,都有轮子名称,轮子间距等配置),但differential_drive_controller才是用于gazebo仿真使用的。
                                • 9
                                  924453613 @小鱼
                                  @小鱼 感谢鱼总这么晚还在解答我的问题 我删除arbotix后 我重新查看tf树发现以下问题
                                  1.odom到base_link断开
                                  2.tf树与最初发布帖子时不同
                                  134c18e1-4b0f-444f-b50e-7eb83f18b6f8-图片.png 6a5ec88e-d9c5-4a38-845e-653cfe0cb7cb-图片.png
                                  rqt_graph如下
                                    小鱼 技术大佬 @924453613
                                    @924453613 首先恭喜你,离成功越来越近了,注意两轮差速模型的配置项robotBaseFrame,该项为其发布的joint_states参考的frame名称。
                                        </plugin>
                                    尝试进一步修改:
                                    1. 将 <robotBaseFrame>的base_footprint->base_link,这样gazebo发布数据时应该会将base_link->left/right_joint
                                    2. 尝试删除静态发布footprint->base_link,因为在我看来,它也是多余的,两者之间的关系在URDF中已经给出。
                                      <node
                                        pkg="tf"
                                    • 9
                                      924453613 @小鱼
                                      @小鱼 感谢鱼总,目前tf树仍有问题,夜已深鱼总早点休息,明早我会继续尝试,非常感谢。
                                        小鱼 技术大佬 @924453613
                                        @924453613 ok,目前看到对应的tf还是没有链接起来,需要注意的地方就是上文中提到的,可以多次修改尝试,祝早日成功,早点休息。
                                        • 9
                                          924453613 @小鱼
                                          @小鱼 非常感谢鱼总的解答目前已经解决,问题大概率是出现在odom_rviz.launch中重复出现了/arbotix,导致tf树出错了,谢谢👍
                                            小鱼 技术大佬 @924453613
                                            @924453613 很高兴能够看到该问题被解决掉,如果方便可以贴一下解决后的代码在本帖子中,方便其他小伙伴在遇到相同问题提供帮助。
