    docker安装ros后怎么apt-get install ros-包
    docker apt存在问题
    2.3k
    • SpeikeS
      Speike
      speike@ss-ub22:~$ noetic1
      请输入指令控制noetic1: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
      e
      root@17cffc92086f:/home/speike# sudo apt-get install ros-noetic-teleop-twist-keyboard
      Reading package lists... Done
      Building dependency tree
      E: Unable to locate package ros-noetic-teleop-twist-keyboard
      ubuntu22.04使用docker安装noetic后,容器内外都无法安装ros包
        小鱼 技术大佬 @Speike
        @Speike 需要先dudo apt update 下,就像新电脑一样
        SpeikeS 1 条回复 最后回复 回复 引用 0
        • SpeikeS
          Speike @小鱼
          sudo apt update后这样:
          e
          root@17cffc92086f:/home/speike# sudo apt update
          Ign:1 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal InRelease
          Hit:2 https://mirrors.ustc.edu.cn/ubuntu focal InRelease
          Get:3 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu focal InRelease [4679 B]
          Hit:4 https://mirrors.ustc.edu.cn/ubuntu focal-updates InRelease
          Get:5 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal Release [3794 B]
          Hit:6 https://mirrors.ustc.edu.cn/ubuntu focal-backports InRelease
          Get:7 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal Release.gpg [833 B]
          Hit:8 https://mirrors.ustc.edu.cn/ubuntu focal-security InRelease
          Get:9 http://192.168.111.241:8081/IXC6ce55d137e7d52efd957279f09784e94_218.197.192.224/ros2/ubuntu focal/main amd64 Packages [1093 kB]
          Err:9 http://192.168.111.241:8081/IXC6ce55d137e7d52efd957279f09784e94_218.197.192.224/ros2/ubuntu focal/main amd64 Packages
            File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP: 192.168.111.241 8081]
            Hashes of expected file:
             - Filesize:1092928 [weak]
             - SHA256:399489b1137d48ad19917f0f55c395a01cf8b2a9653c573ada099bccaffcdf2e
             - SHA1:e4c6e9e39176f3385ef4bd56ebe78e4e60fee11a [weak]
             - MD5Sum:e3c5c5b8bc863ab11413cc4d22d697bf [weak]
            Release file created at: Sat, 16 Jul 2022 00:56:46 +0000
          Get:10 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal/main amd64 Packages [698 kB]
          Get:11 http://packages.ros.org/ros2/ubuntu focal InRelease [4679 B]
          Get:12 http://192.168.111.241:8081/IXCab54c6e78e30452664e287da766c009c_218.197.192.224/ros2/ubuntu focal/main amd64 Packages [1093 kB]
          Err:12 http://192.168.111.241:8081/IXCab54c6e78e30452664e287da766c009c_218.197.192.224/ros2/ubuntu focal/main amd64 Packages
            File has unexpected size (1042131 != 1092936). Mirror sync in progress? [IP: 192.168.111.241 8081]
             - Filesize:1092936 [weak]
             - SHA256:7f861c69c71d187c7f62875b2823fc3088d4404386bd369accb39e64d3b1f648
             - SHA1:0944df3f929630d6ba741d5763b52087b39f8df8 [weak]
             - MD5Sum:e3d9c7646c74f262afc286fcc4556bb0 [weak]
            Release file created at: Mon, 18 Jul 2022 22:09:28 +0000
          Fetched 704 kB in 3s (202 kB/s)
          E: Failed to fetch http://192.168.111.241:8081/IXC6ce55d137e7d52efd957279f09784e94_218.197.192.224/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz  File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP: 192.168.111.241 8081]
          E: Failed to fetch http://192.168.111.241:8081/IXCab54c6e78e30452664e287da766c009c_218.197.192.224/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz  File has unexpected size (1042131 != 1092936). Mirror sync in progress? [IP: 192.168.111.241 8081]
          E: Some index files failed to download. They have been ignored, or old ones used instead.
            小鱼 技术大佬 @Speike
            @Speike 你可以继续install,应该没影响,不放心可以运行一下一键安装的一键换源。
            卜上人间卜 1 条回复 最后回复 回复 引用 1
            • SpeikeS Speike 将这个主题标记为已解决,在
            • 卜上人间卜
              Dob @小鱼
              @小鱼 借个帖子,一键安装后,进到docker里边运行
              ros2 run turtlesim turtlesim_node
              错误打印:
              qt.qpa.xcb: could not connect to display
              qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
              This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
              Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
                小鱼 技术大佬 @卜上人间
                @卜上人间 在主机端运行 xhost + 应该就可以了
