如何在ROS2的环境下使用Pcl_ros以及pcl 功能包
@richard491067290 之前分享过相关文章,你可以试试
原文链接:https://mp.weixin.qq.com/s/_zp8pSJ9f766ZyATiiapVQ
前置安装
sudo apt install ros-你的ROS版本代号-pcl*
CMakeLists配置
cmake_minimum_required(VERSION 3.5) project(ros2pcl_test) # find dependencies find_package(ament_cmake REQUIRED) find_package(sensor_msgs REQUIRED) find_package(rclcpp REQUIRED) find_package(PCL REQUIRED COMPONENTS common io) link_directories(${PCL_LIBRARY_DIRS}) add_definitions(${PCL_DEFINITIONS}) add_executable(ros2pcl_test_sub src/subscription_pcl.cpp ) ament_target_dependencies(ros2pcl_test_sub rclcpp sensor_msgs ) target_link_libraries(ros2pcl_test_sub ${PCL_LIBRARIES}) ament_package()
点云订阅
#include "rclcpp/rclcpp.hpp" #include "sensor_msgs/msg/point_cloud2.hpp" #include <iostream> #include <pcl/point_cloud.h> #include <pcl/point_types.h> #include <pcl/common/common.h> #include <pcl/io/pcd_io.h> #include <pcl_conversions/pcl_conversions.h> class PclSub : public rclcpp::Node { public: PclSub(std::string name) : Node(name) { sub_novel = this->create_subscription<sensor_msgs::msg::PointCloud2>("sexy_girl", 10, std::bind(&PclSub::topic_callback, this, std::placeholders::_1)); } private: rclcpp::Subscription<sensor_msgs::msg::PointCloud2>::SharedPtr sub_novel; void topic_callback(const sensor_msgs::msg::PointCloud2::SharedPtr msg) { RCLCPP_INFO(this->get_logger(), "points_size(%d,%d)",msg->height,msg->width); }; }; int main(int argc, char **argv) { rclcpp::init(argc, argv); auto node = std::make_shared<PclSub>("pclsub"); rclcpp::spin(node); rclcpp::shutdown(); return 0; }
点云转换(ROS2->PCL)
在点云订阅代码中增加下面的代码即可。
void topic_callback(const sensor_msgs::msg::PointCloud2::SharedPtr msg) { pcl::PointCloud<pcl::PointXYZRGB>::Ptr cloud = boost::make_shared<pcl::PointCloud<pcl::PointXYZRGB>>(); pcl::fromROSMsg(*msg, *cloud); RCLCPP_INFO(this->get_logger(), "points_size(%d,%d)",msg->height,msg->width); };
点云保存
void topic_callback(const sensor_msgs::msg::PointCloud2::SharedPtr msg) { pcl::PointCloud<pcl::PointXYZRGB>::Ptr cloud = boost::make_shared<pcl::PointCloud<pcl::PointXYZRGB>>(); pcl::fromROSMsg(*msg, *cloud); pcl::io::savePCDFileASCII ("asd.pcd", *cloud); RCLCPP_INFO(this->get_logger(), "points_size(%d,%d)",msg->height,msg->width); };
点云生成PointCloud2迭代器
使用PointCloud2迭代器赋值sensor_msgs::msg::PointCloud2 。
#include "sensor_msgs/msg/point_cloud2.hpp" #include "sensor_msgs/point_cloud2_iterator.hpp" sensor_msgs::msg::PointCloud2 msg; // Fill in the size of the cloud msg.height = 480; msg.width = 640; // Create the modifier to setup the fields and memory sensor_msgs::PointCloud2Modifier mod(msg); // Set the fields that our cloud will have mod.setPointCloud2FieldsByString(2, "xyz", "rgb"); // Set up memory for our points mod.resize(msg.height * msg.width); // Now create iterators for fields sensor_msgs::PointCloud2Iterator<float> iter_x(cloud_msg, "x"); sensor_msgs::PointCloud2Iterator<float> iter_y(cloud_msg, "y"); sensor_msgs::PointCloud2Iterator<float> iter_z(cloud_msg, "z"); sensor_msgs::PointCloud2Iterator<uint8_t> iter_r(cloud_msg, "r"); sensor_msgs::PointCloud2Iterator<uint8_t> iter_g(cloud_msg, "g"); sensor_msgs::PointCloud2Iterator<uint8_t> iter_b(cloud_msg, "b"); for (; iter_x != iter_x.end(); ++iter_x, ++iter_y, ++iter_z, ++iter_r, ++iter_g, ++iter_b) { *iter_x = 0.0; *iter_y = 0.0; *iter_z = 0.0; *iter_r = 0; *iter_g = 255; *iter_b = 0; }
点云转换(PCL->ROS2)
#include "pcl_conversions/pcl_conversions.h" pcl::PointCloud<pcl::PointXYZRGB>::Ptr cloud; sensor_msgs::msg::PointCloud2 msg; pcl::toROSMsg(*cloud, msg); cloud_publisher->publish(msg);
谢谢回复!我之前也看到这个帖子了,但是```
code_text#include <iostream> #include <vector> #include <Eigen/Core> #include <ros/ros.h> #include <sensor_msgs/PointCloud2.h> #include <geometry_msgs/Point.h> #include <geometry_msgs/Pose.h> #include <geometry_msgs/PoseArray.h> #include <geometry_msgs/TransformStamped.h> #include <pcl_ros/impl/transforms.hpp> #include <pcl_ros/point_cloud.h> #include <pcl/common/common.h> #include <pcl/common/transforms.h> #include <pcl/point_types.h> #include <pcl/filters/crop_hull.h> #include <pcl/filters/statistical_outlier_removal.h> #include <pcl/visualization/cloud_viewer.h> #include <pcl/surface/concave_hull.h> #include <pcl/filters/passthrough.h> #include <tf/transform_listener.h> #include <tf/transform_broadcaster.h> #include "tf2_ros/static_transform_broadcaster.h" class PCHandler { protected: ros::NodeHandle m_nh; sensor_msgs::PointCloud2 m_cloud; sensor_msgs::PointCloud2 m_cropped_cloud; geometry_msgs::PointStamped m_bottle_center; Eigen::Vector4f m_centroid; public: ros::Subscriber m_pointcloud_sub, m_center_sub; ros::Publisher m_croppedcloud_pub, m_goalpose_pub; tf::TransformListener* m_tf_listener = NULL; tf2_ros::StaticTransformBroadcaster m_br; PCHandler(void) { m_pointcloud_sub = m_nh.subscribe("/camera/depth/color/points", 1, &PCHandler::getPC, this); m_center_sub = m_nh.subscribe("/point_in_3d", 1, &PCHandler::getCenter, this); m_goalpose_pub = m_nh.advertise<geometry_msgs::PoseStamped>("/bottle_detection/goalpose", 1); //Initialize tf_listener for pointcloud transformation m_tf_listener = new(tf::TransformListener); m_tf_listener->waitForTransform("/base_link", "/camera_depth_optical_frame", ros::Time::now(), ros::Duration(5.0)); ROS_INFO("Transform to camera found."); } ~PCHandler(void) { } void getPC(const sensor_msgs::PointCloud2::ConstPtr& msg) { m_cloud = *msg; ROS_INFO("successfully get PointCloud"); m_tf_listener->waitForTransform("/base_link", m_cloud.header.frame_id, m_cloud.header.stamp, ros::Duration(3.0)); pcl_ros::transformPointCloud("base_link", m_cloud, m_cloud, *m_tf_listener); } void getCenter(const geometry_msgs::PointStamped::ConstPtr& msg) { m_bottle_center = *msg; pcl::PointCloud<pcl::PointXYZ>::Ptr pointcloud_ptr (new pcl::PointCloud<pcl::PointXYZ>); pcl::fromROSMsg(m_cloud, *pointcloud_ptr); ROS_INFO("size of original PointCloud: %lu", pointcloud_ptr->size()); ////define a 3d volume around bottle float d = 0.1; pcl::PointCloud<pcl::PointXYZ>::Ptr boundingbox_ptr (new pcl::PointCloud<pcl::PointXYZ>); boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x-d, m_bottle_center.point.y-d, m_bottle_center.point.z+0.3)); boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x+d, m_bottle_center.point.y-d, m_bottle_center.point.z+0.3)); boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x-d, m_bottle_center.point.y+d, m_bottle_center.point.z+0.3)); boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x+d, m_bottle_center.point.y+d, m_bottle_center.point.z+0.3)); boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x-d, m_bottle_center.point.y-d, m_bottle_center.point.z-0.1)); boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x+d, m_bottle_center.point.y-d, m_bottle_center.point.z-0.1)); boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x-d, m_bottle_center.point.y+d, m_bottle_center.point.z-0.1)); boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x+d, m_bottle_center.point.y+d, m_bottle_center.point.z-0.1)); pcl::ConvexHull<pcl::PointXYZ> hull; hull.setInputCloud(boundingbox_ptr); hull.setDimension(3); std::vector<pcl::Vertices> polygons; pcl::PointCloud<pcl::PointXYZ>::Ptr surface_hull (new pcl::PointCloud<pcl::PointXYZ>); hull.reconstruct(*surface_hull, polygons); pcl::PointCloud<pcl::PointXYZ>::Ptr objects (new pcl::PointCloud<pcl::PointXYZ>); pcl::CropHull<pcl::PointXYZ> bb_filter; bb_filter.setDim(3); bb_filter.setInputCloud(pointcloud_ptr); bb_filter.setHullIndices(polygons); bb_filter.setHullCloud(surface_hull); bb_filter.filter(*objects); //test, get the maximun and minimun of a pointcloud pcl::PointXYZ minPt, maxPt; pcl::getMinMax3D(*objects, minPt, maxPt); //filter out points which belongs to the bottle cap pcl::PassThrough<pcl::PointXYZ> pass; pass.setInputCloud(objects); pass.setFilterFieldName("z"); pass.setFilterLimits(maxPt.z-0.005, maxPt.z); pass.filter(*objects); ROS_INFO("size of cap cloud: %lu", objects->size()); //calculate centroid of bottle cap if(objects->size()>300){ pcl::compute3DCentroid(*objects, m_centroid); ROS_INFO("center of the point cloud: %f, %f, %f", m_centroid(0), m_centroid(1), m_centroid(2)); } //broadcast frame of goalpose // static tf::TransformBroadcaster br; // br.sendTransform( // tf::StampedTransform( // tf::Transform(tf::Quaternion(0,0,0,1), tf::Vector3(m_centroid[0], m_centroid[1], m_centroid[2])), // ros::Time::now(), "base_link", "cap_frame")); //publish goalpose tf2::Quaternion q; q.setRPY(-3.1415926/2, 0, 0); if(m_centroid(2)>=0.20 && m_centroid(2)<=0.40){ geometry_msgs::PoseStamped goalpose; goalpose.pose.orientation.x = q.x(); goalpose.pose.orientation.y = q.y(); goalpose.pose.orientation.z = q.z(); goalpose.pose.orientation.w = q.w(); goalpose.pose.position.x = m_centroid[0]; goalpose.pose.position.y = m_centroid[1]; goalpose.pose.position.z = 0.4; goalpose.header.frame_id = "base_link"; goalpose.header.stamp = ros::Time::now(); m_goalpose_pub.publish(goalpose); ROS_INFO("goal pose is published!"); //Publish transform geometry_msgs::TransformStamped transform; transform.header.stamp = ros::Time::now(); transform.header.frame_id = "base_link"; transform.child_frame_id = "goal_position_0"; transform.transform.translation.x = goalpose.pose.position.x; transform.transform.translation.y = goalpose.pose.position.y; transform.transform.translation.z = goalpose.pose.position.z; transform.transform.rotation.x = goalpose.pose.orientation.x; transform.transform.rotation.y = goalpose.pose.orientation.y; transform.transform.rotation.z = goalpose.pose.orientation.z; transform.transform.rotation.w = goalpose.pose.orientation.w; m_br.sendTransform(transform); } //visualize the result // pcl::PointCloud<pcl::PointXYZ>::Ptr centroid_ptr (new pcl::PointCloud<pcl::PointXYZ>); // centroid_ptr->push_back(pcl::PointXYZ(m_centroid(0), m_centroid(1), m_centroid(2))); // pcl::visualization::PCLVisualizer viewer("Centroid example"); // pcl::visualization::PointCloudColorHandlerCustom<pcl::PointXYZ> source_cloud_color_handler(objects,255, 255, 255); // viewer.addPointCloud(objects, source_cloud_color_handler, "original_cloud"); // pcl::visualization::PointCloudColorHandlerCustom<pcl::PointXYZ> centroid_cloud_color_handler(centroid_ptr,230, 20, 20); // viewer.addPointCloud(centroid_ptr, centroid_cloud_color_handler, "cap_centroid"); // //viewer.addCoordinateSystem(1.0, "cloud", 0); // viewer.setBackgroundColor(0.05, 0.05, 0.05, 0); // viewer.setPointCloudRenderingProperties (pcl::visualization::PCL_VISUALIZER_POINT_SIZE, 2, "original_cloud"); // viewer.setPointCloudRenderingProperties (pcl::visualization::PCL_VISUALIZER_POINT_SIZE, 2, "cap_centroid"); // while (!viewer.wasStopped ()) { // Display the visualiser until 'q' key is pressed // viewer.spinOnce (); // } } }; int main(int argc, char **argv) { ros::init(argc, argv, "pc_handle_node"); ros::NodeHandle nh("~"); PCHandler pc_handler; ros::spin(); return 0; }
但是在我ROS1的版本中我运用了例如PCl_ros包和PCl包中的一些功能,我不知道该如何改写这些功能?是否能请您给我一个相关的改写例子或者其他的指导呢?万分感谢!!
pcl_ros::transformPointCloud("base_link", m_cloud, m_cloud, *m_tf_listener); pcl::ConvexHull<pcl::PointXYZ> hull;
@richard491067290 不知道是否解决了哈,ros2中方法类似
https://github.com/ros-perception/perception_pcl/blob/ros2/pcl_ros/src/transforms.cpp
template void pcl_ros::transformPointCloud<pcl::PointXYZ>( const pcl::PointCloud<pcl::PointXYZ> &, pcl::PointCloud<pcl::PointXYZ> &, const geometry_msgs::msg::TransformStamped &);
@小鱼 大佬请问一下有完整的工作空间可以提供学习一下吗,按照您这个流程编写功能包无法正常编译,会报几个类似下面的warning
** WARNING ** io features related to openni2 will be disabled
然后无法通过正常编译
我的ros2版本是foxy,非常感谢!!! -
@1400276587 同样的问题,请问解决了吗?
此回复已被删除! -
