    catkin_make失败,无法达到100%
    noetic catkinmake ros
    1.0k
    • 蒲公英的约定蒲
      蒲公英的约定
      hit@hit:~/catkin_ws$ catkin_make
      Base path: /home/hit/catkin_ws
      Source space: /home/hit/catkin_ws/src
      Build space: /home/hit/catkin_ws/build
      Devel space: /home/hit/catkin_ws/devel
      Install space: /home/hit/catkin_ws/install
      Running command: "make cmake_check_build_system" in "/home/hit/catkin_ws/build"
      Running command: "make -j8 -l8" in "/home/hit/catkin_ws/build"
      [ 0%] Built target std_msgs_generate_messages_lisp
      [ 0%] Built target std_msgs_generate_messages_nodejs
      [ 0%] Built target std_msgs_generate_messages_cpp
      [ 0%] Built target std_msgs_generate_messages_py
      [ 0%] Built target std_msgs_generate_messages_eus
      [ 0%] Built target _ur_msgs_generate_messages_check_deps_ToolDataMsg
      [ 0%] Built target _robotiq_3f_gripper_articulated_msgs_generate_messages_check_deps_Robotiq3FGripperRobotOutput
      [ 0%] Built target _robotiq_3f_gripper_articulated_msgs_generate_messages_check_deps_Robotiq3FGripperRobotInput
      [ 0%] Built target _ur_msgs_generate_messages_check_deps_Analog
      [ 0%] Built target _ur_msgs_generate_messages_check_deps_Digital
      [ 0%] Built target _ur_msgs_generate_messages_check_deps_RobotModeDataMsg
      [ 0%] Built target _ur_msgs_generate_messages_check_deps_SetIO
      [ 0%] Built target _ur_msgs_generate_messages_check_deps_SetPayload
      [ 1%] Built target robotiq_ethercat
      [ 1%] Built target _ur_msgs_generate_messages_check_deps_IOStates
      [ 1%] Built target _ur_msgs_generate_messages_check_deps_RobotStateRTMsg
      [ 1%] Built target _ur_msgs_generate_messages_check_deps_MasterboardDataMsg
      [ 1%] Built target roscpp_generate_messages_cpp
      [ 1%] Built target _catkin_empty_exported_target
      [ 1%] Built target _robotiq_2f_gripper_control_generate_messages_check_deps_Robotiq2FGripper_robot_output
      [ 1%] Built target _ur_msgs_generate_messages_check_deps_SetSpeedSliderFraction
      [ 1%] Built target roscpp_generate_messages_eus
      [ 1%] Built target _robotiq_2f_gripper_control_generate_messages_check_deps_Robotiq2FGripper_robot_input
      [ 1%] Built target _robotiq_ft_sensor_generate_messages_check_deps_ft_sensor
      [ 1%] Built target roscpp_generate_messages_nodejs
      [ 1%] Built target rosgraph_msgs_generate_messages_nodejs
      [ 1%] Built target roscpp_generate_messages_py
      [ 1%] Built target rosgraph_msgs_generate_messages_cpp
      [ 1%] Built target _robotiq_ft_sensor_generate_messages_check_deps_sensor_accessor
      [ 1%] Built target rosgraph_msgs_generate_messages_eus
      [ 1%] Built target rosgraph_msgs_generate_messages_lisp
      [ 1%] Built target roscpp_generate_messages_lisp
      [ 1%] Built target rosgraph_msgs_generate_messages_py
      [ 1%] Built target robotiq_3f_gripper_control_gencfg
      [ 1%] Built target dynamic_reconfigure_generate_messages_cpp
      [ 1%] Built target diagnostic_msgs_generate_messages_lisp
      [ 1%] Built target robotiq_2f_gripper_action_server_client_test
      [ 1%] Built target diagnostic_msgs_generate_messages_py
      [ 1%] Built target diagnostic_msgs_generate_messages_nodejs
      [ 1%] Built target std_srvs_generate_messages_cpp
      [ 1%] Built target diagnostic_msgs_generate_messages_cpp
      [ 1%] Built target diagnostic_msgs_generate_messages_eus
      [ 1%] Built target controller_manager_msgs_generate_messages_py
      [ 1%] Built target std_srvs_generate_messages_eus
      [ 1%] Built target controller_manager_msgs_generate_messages_lisp
      [ 1%] Built target controller_manager_msgs_generate_messages_eus
      [ 1%] Built target dynamic_reconfigure_generate_messages_nodejs
      [ 1%] Built target dynamic_reconfigure_generate_messages_lisp
      [ 1%] Built target std_srvs_generate_messages_lisp
      [ 1%] Built target controller_manager_msgs_generate_messages_cpp
      [ 1%] Built target dynamic_reconfigure_generate_messages_py
      [ 1%] Built target dynamic_reconfigure_generate_messages_eus
      [ 1%] Built target dynamic_reconfigure_gencfg
      [ 1%] Built target std_srvs_generate_messages_nodejs
      [ 1%] Built target controller_manager_msgs_generate_messages_nodejs
      [ 1%] Built target std_srvs_generate_messages_py
      [ 1%] Built target tf2_msgs_generate_messages_nodejs
      [ 1%] Built target actionlib_msgs_generate_messages_lisp
      [ 1%] Built target actionlib_msgs_generate_messages_eus
      [ 1%] Built target actionlib_generate_messages_nodejs
      [ 1%] Built target geometry_msgs_generate_messages_nodejs
      [ 1%] Built target actionlib_generate_messages_lisp
      [ 1%] Built target actionlib_msgs_generate_messages_cpp
      [ 1%] Built target actionlib_generate_messages_eus
      [ 1%] Built target actionlib_msgs_generate_messages_py
      [ 1%] Built target geometry_msgs_generate_messages_cpp
      [ 1%] Built target geometry_msgs_generate_messages_eus
      [ 1%] Built target actionlib_generate_messages_cpp
      [ 1%] Built target geometry_msgs_generate_messages_lisp
      [ 1%] Built target actionlib_generate_messages_py
      [ 1%] Built target geometry_msgs_generate_messages_py
      [ 1%] Built target actionlib_msgs_generate_messages_nodejs
      [ 1%] Built target sensor_msgs_generate_messages_nodejs
      [ 1%] Built target sensor_msgs_generate_messages_py
      [ 1%] Built target sensor_msgs_generate_messages_eus
      [ 1%] Built target sensor_msgs_generate_messages_lisp
      [ 1%] Built target sensor_msgs_generate_messages_cpp
      [ 1%] Built target tf_generate_messages_cpp
      [ 1%] Built target tf_generate_messages_nodejs
      [ 1%] Built target tf_generate_messages_eus
      [ 1%] Built target tf_generate_messages_py
      [ 1%] Built target tf2_msgs_generate_messages_cpp
      [ 1%] Built target tf_generate_messages_lisp
      [ 1%] Built target tf2_msgs_generate_messages_py
      [ 1%] Built target tf2_msgs_generate_messages_eus
      [ 1%] Built target tf2_msgs_generate_messages_lisp
      [ 2%] Built target ur_driver_gencfg
      [ 3%] Built target ur10_kin
      [ 4%] Built target ur5_kin
      [ 4%] Built target ur3_kin
      [ 6%] Built target visp_bridge
      [ 6%] Built target image_proc_gencfg
      [ 6%] Built target _visp_camera_calibration_generate_messages_check_deps_calibrate
      [ 6%] Built target _visp_camera_calibration_generate_messages_check_deps_CalibPoint
      [ 6%] Built target _visp_camera_calibration_generate_messages_check_deps_ImageAndPoints
      [ 6%] Built target _visp_camera_calibration_generate_messages_check_deps_CalibPointArray
      [ 6%] Built target _visp_camera_calibration_generate_messages_check_deps_ImagePoint
      [ 6%] Built target _visp_hand2eye_calibration_generate_messages_check_deps_reset
      [ 6%] Built target _visp_hand2eye_calibration_generate_messages_check_deps_compute_effector_camera
      [ 6%] Built target _visp_hand2eye_calibration_generate_messages_check_deps_TransformArray
      [ 6%] Built target _visp_hand2eye_calibration_generate_messages_check_deps_compute_effector_camera_quick
      [ 6%] Built target _visp_tracker_generate_messages_check_deps_KltPoints
      [ 6%] Built target _visp_tracker_generate_messages_check_deps_Init
      [ 6%] Built target _visp_tracker_generate_messages_check_deps_MovingEdgeSite
      [ 7%] Built target visp_tracker_gencfg
      [ 7%] Built target _visp_tracker_generate_messages_check_deps_MovingEdgeSites
      [ 7%] Built target _visp_tracker_generate_messages_check_deps_KltSettings
      [ 7%] Built target _visp_tracker_generate_messages_check_deps_MovingEdgeSettings
      [ 7%] Built target visp_tracker_generate_messages_check_deps_TrackerSettings
      [ 8%] Built target visp_tracker_viewer
      [ 8%] Built target irobot_description_xacro_generated_to_devel_space
      [ 9%] Built target robotiq_3f_gripper_articulated_msgs_generate_messages_cpp
      [ 9%] Built target _visp_tracker_generate_messages_check_deps_KltPoint
      [ 10%] Built target robotiq_3f_gripper_articulated_msgs_generate_messages_lisp
      [ 10%] Built target robotiq_3f_gripper_articulated_msgs_generate_messages_nodejs
      [ 11%] Built target robotiq_3f_gripper_articulated_msgs_generate_messages_py
      [ 12%] Built target robotiq_3f_gripper_articulated_msgs_generate_messages_eus
      Checking md5sum on /home/hit/catkin_ws/devel/share/visp_tracker/bag/tutorial-static-box.bag
      WARNING: md5sum mismatch (b51bf6127c446ec8680b8abb0e910430 != 1578dedd48d3f9f5515a8737845ae882); re-downloading file /home/hit/catkin_ws/devel/share/visp_tracker/bag/tutorial-static-box.bag
      Downloading https://github.com/lagadic/vision_visp/releases/download/vision_visp-0.5.0/tutorial-static-box.bag to /home/hit/catkin_ws/devel/share/visp_tracker/bag/tutorial-static-box.bag...[ 15%] Built target ur_msgs_generate_messages_lisp
      [ 18%] Built target ur_msgs_generate_messages_nodejs
      [ 22%] Built target ur_msgs_generate_messages_py
      [ 25%] Built target ur_msgs_generate_messages_cpp
      [ 29%] Built target ur_msgs_generate_messages_eus
      [ 30%] Built target robotiq_2f_gripper_control_generate_messages_eus
      [ 31%] Built target robotiq_2f_gripper_control_generate_messages_py
      [ 32%] Built target robotiq_2f_gripper_control_generate_messages_cpp
      [ 34%] Built target robotiq_2f_gripper_control_generate_messages_lisp
      [ 34%] Built target robotiq_2f_gripper_control_generate_messages_nodejs
      [ 35%] Built target robotiq_ft_sensor_generate_messages_cpp
      [ 36%] Built target robotiq_ft_sensor_generate_messages_eus
      [ 36%] Built target robotiq_ft_sensor_generate_messages_lisp
      [ 37%] Built target robotiq_ft_sensor_generate_messages_py
      [ 38%] Built target robotiq_ft_sensor_generate_messages_nodejs
      [ 40%] Built target robotiq_3f_gripper_control
      [ 40%] Built target robotiq_3f_gripper_articulated_msgs_gencpp
      [ 41%] Built target irobot_teleop_node
      [ 42%] Built target ur10_moveit_plugin
      [ 42%] Built target ur5_moveit_plugin
      [ 44%] Built target ur3_moveit_plugin
      [ 45%] Built target visp_camera_calibration_generate_messages_cpp
      [ 46%] Built target visp_bridge_convert_camera_parameters
      [ 46%] Built target visp_camera_calibration_common
      [ 50%] Built target visp_camera_calibration_generate_messages_lisp
      [ 50%] Built target visp_camera_calibration_generate_messages_eus
      [ 51%] Built target visp_camera_calibration_generate_messages_nodejs
      [ 54%] Built target visp_camera_calibration_generate_messages_py
      Checking md5sum on /home/hit/catkin_ws/devel/share/visp_auto_tracker/bag/tutorial-qrcode.bag
      [ 56%] Built target visp_hand2eye_calibration_generate_messages_cpp
      [ 56%] Built target visp_hand2eye_calibration_common
      [ 59%] Built target visp_hand2eye_calibration_generate_messages_eus
      [ 59%] Built target visp_hand2eye_calibration_generate_messages_lisp
      [ 61%] Built target visp_hand2eye_calibration_generate_messages_py
      [ 62%] Built target visp_hand2eye_calibration_generate_messages_nodejs
      [ 62%] Built target visp_auto_tracker_bag
      [ 65%] Built target visp_tracker_generate_messages_lisp
      [ 69%] Built target visp_tracker_generate_messages_cpp
      [ 73%] Built target visp_tracker_generate_messages_eus
      [ 74%] Built target visp_tracker_generate_messages_nodejs
      [ 78%] Built target visp_tracker_generate_messages_py
      [ 78%] Built target robotiq_3f_gripper_articulated_msgs_generate_messages
      [ 78%] Built target ur_msgs_generate_messages
      [ 78%] Built target robotiq_2f_gripper_control_generate_messages
      [ 78%] Built target robotiq_ft_sensor_gencpp
      [ 78%] Built target robotiq_ft_sensor_generate_messages
      [ 80%] Built target robotiq_2f_gripper_action_server_node
      [ 80%] Built target robotiq_2f_gripper_ethercat_node
      [ 81%] Built target robotiq_3f_gripper_ethercat_node
      [ 82%] Built target robotiq_3f_gripper_can_node
      [ 83%] Automatic MOC and UIC for target robotiq_3f_rviz
      [ 83%] Built target robotiq_3f_gripper_joint_states
      [ 83%] Built target visp_camera_calibration_gencpp
      [ 83%] Built target visp_camera_calibration_generate_messages
      [ 83%] Built target visp_hand2eye_calibration_gencpp
      [ 83%] Built target visp_hand2eye_calibration_generate_messages
      [ 83%] Built target visp_tracker_gencpp
      [ 83%] Built target RobotiqHandPlugin
      [ 83%] Built target robotiq_3f_rviz_autogen
      [ 83%] Built target visp_tracker_generate_messages
      [ 83%] Built target visp_tracker_client
      [ 84%] Built target tracker
      [ 84%] Built target rq_test_sensor
      [ 86%] Built target rq_sensor
      [ 87%] Built target visp_camera_calibration_camera
      [ 88%] Built target visp_camera_calibration_calibrator
      [ 89%] Built target visp_camera_calibration_image_processing
      [ 90%] Built target visp_hand2eye_calibration_client
      [ 91%] Built target visp_hand2eye_calibration_calibrator
      [ 92%] Built target robotiq_3f_rviz
        小鱼 技术大佬 @蒲公英的约定
        @蒲公英的约定 兄弟给的内容里都看不到错误的,失败在哪里了
