    moveit2的编译源码colcon build这里error要怎么办
    机械臂运动规划
    ros2 humble 安装失败 moveit2 colcon
    2.8k
    • 10127960511
      Haha
      --- stderr: moveit_ros_planning
      In file included from /home/wadd/moveit2_ws/src/moveit2/moveit_ros/planning/kinematics_plugin_loader/include/moveit/kinematics_plugin_loader/kinematics_plugin_loader.h:42,
      from /home/wadd/moveit2_ws/src/moveit2/moveit_ros/planning/kinematics_plugin_loader/src/kinematics_plugin_loader.cpp:37:
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp: In member function ‘rcl_interfaces::msg::SetParametersResult kinematics::ParamListener::update(const std::vectorrclcpp::Parameter&)’:
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp💯59: error: ‘gt_eq’ is not a member of ‘parameter_traits’
      100 | if(auto validation_result = parameter_traits::gt_eq<double>(param, 0.0);
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp💯65: error: expected primary-expression before ‘double’
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:107:59: error: ‘gt’ is not a member of ‘parameter_traits’
      107 | if(auto validation_result = parameter_traits::gt<double>(param, 0.0);
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:107:62: error: expected primary-expression before ‘double’
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp: In member function ‘void kinematics::ParamListener::declare_params()’:
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:153:53: error: ‘gt_eq’ is not a member of ‘parameter_traits’
      153 | if(auto validation_result = parameter_traits::gt_eq<double>(param, 0.0);
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:153:59: error: expected primary-expression before ‘double’
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:159:53: error: ‘gt’ is not a member of ‘parameter_traits’
      159 | if(auto validation_result = parameter_traits::gt<double>(param, 0.0);
      /home/wadd/moveit2_ws/build/moveit_ros_planning/kinematics_plugin_loader/kinematics_parameters/include/kinematics_parameters.hpp:159:56: error: expected primary-expression before ‘double’
      gmake[2]: *** [kinematics_plugin_loader/CMakeFiles/moveit_kinematics_plugin_loader.dir/build.make:76:kinematics_plugin_loader/CMakeFiles/moveit_kinematics_plugin_loader.dir/src/kinematics_plugin_loader.cpp.o] 错误 1
      gmake[1]: *** [CMakeFiles/Makefile2:460:kinematics_plugin_loader/CMakeFiles/moveit_kinematics_plugin_loader.dir/all] 错误 2
      gmake[1]: *** 正在等待未完成的任务....
      Failed <<< moveit_ros_planning [2min 3s, exited with code 2]
      Summary: 13 packages finished [11min 29s]
      1 package failed: moveit_ros_planning
      2 packages had stderr output: moveit_configs_utils moveit_ros_planning
      24 packages not processed
        小鱼 技术大佬 @1012796051
        @1012796051 已经测试后更新了
        @小鱼 在 《动手学Moveit2》3.安装Moveit2 中说:
        Summary: 55 packages finished [1h 13min 56s]
        3 packages had stderr output: launch_param_builder moveit_configs_utils moveit_setup_srdf_plugins
        10127960511 1 条回复 最后回复 回复 引用 0
        • 小鱼小 小鱼 将这个主题标记为已解决,在
        • 10127960511
          Haha @小鱼
          @小鱼 搞定了!!!谢谢鱼哥,为鱼哥举大旗!!!
          • 笨笨洋笨
            笨笨洋
            同样的报错,请教一下怎么解决
              小鱼 技术大佬 @笨笨洋
              @笨笨洋 重新看一下教程,已经更新了
