    一键安装ROS失败
    安装失败 ros1 一键安装
    3.5k
    • 2957141532
      不忘初心
      root@DeepLearning:~# sudo apt install ros-noetic-desktop-full -y
      Reading package lists... Done
      Building dependency tree
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      ros-noetic-desktop-full : Depends: ros-noetic-desktop but it is not going to be installed
      Depends: ros-noetic-perception but it is not going to be installed
      Depends: ros-noetic-simulators but it is not going to be installed
      Depends: ros-noetic-urdf-sim-tutorial but it is not going to be installed
      E: Unable to correct problems, you have held broken packages.
      root@DeepLearning:~# wget http://fishros.com/install -O fishros && . fishros
      --2022-10-21 19:42:44-- http://fishros.com/install
      Resolving fishros.com (fishros.com)... 139.9.131.171, 39.96.153.39, 39.96.153.59, ...
      --2022-10-21 19:42:45-- http://fishros.com/install/
      Length: 582 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[===================>] 582 --.-KB/s in 0s
      2022-10-21 19:42:45 (205 MB/s) - ‘fishros’ saved [582/582]
      python3-distro is already the newest version (1.4.0-1).
      python3-yaml is already the newest version (5.3.1-1ubuntu0.1).
      0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
      sudo is already the newest version (1.8.31-1ubuntu1.2).
      --2022-10-21 19:42:47-- http://fishros.com/install/install1s/tools/base.py
      Length: 41972 (41K) [application/octet-stream]
      /tmp/fishinstall/tools/base.py 100%[==================================================================================================>] 40.99K --.-KB/s in 0.07s
      2022-10-21 19:42:48 (567 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [41972/41972]
      [-]Result:success
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:1
      --2022-10-21 19:42:54-- http://fishros.com/install/install1s/tools/tool_install_ros.py
      Length: 19050 (19K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_install_ros.py 100%[==================================================================================================>] 18.60K --.-KB/s in 0.06s
      2022-10-21 19:42:54 (313 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [19050/19050]
      --2022-10-21 19:42:54-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      Length: 2457 (2.4K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_config_rosenv.py 100%[==================================================================================================>] 2.40K --.-KB/s in 0s
      2022-10-21 19:42:54 (358 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2457/2457]
      --2022-10-21 19:42:54-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
      Length: 7511 (7.3K) [application/octet-stream]
      /tmp/fishinstall/tools/tool_config_system_sour 100%[==================================================================================================>] 7.33K --.-KB/s in 0.02s
      2022-10-21 19:42:54 (429 KB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7511/7511]
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:success --upgradable' to see them.e
      [-]Result:success kage retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into memory..
      [-]Result:success e and 6 not upgraded.
      [-]Result:success eplacement (dummy transitional package)
      [-]Result:success
      [-]Result:success
      [-]Result:success
      [-]Result:success tends 'ros_core' and includes other basic functionalities like tf2 and urdf..namic reconfigure, nodelets, and pluginlib.l.
      [1]:noetic(ROS1)
      [2]:foxy(ROS2)
      [3]:galactic(ROS2)
      [4]:rolling(ROS2)
      [0]:quit
      请输入[]内的数字以选择:1
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:noetic(ROS1)桌面版
      [2]:noetic(ROS1)基础版(小)
      [0]:quit
      请输入[]内的数字以选择:1
      [-]Result:success end for Debianfor C++ (development files)sion
      [-]Result:code:100 etic-urdf-sim-tutorial but it is not going to be installed
      确认了解情况,请输入回车继续安装n
      Run CMD Task:[sudo aptitude install ros-noetic-desktop-full]
      The following NEW packages will be installed:
      字数太多,删除看不懂的:
      0 packages upgraded, 1006 newly installed, 0 to remove and 6 not upgraded.
      Need to get 529 MB of archives. After unpacking 2773 MB will be used.
      libmysqlclient-dev : Depends: libmysqlclient21 (= 8.0.30-0ubuntu0.20.04.2) but 8.0.30-0ubuntu0.20.04.3 is installed
      libcurl4-gnutls-dev : Conflicts: libcurl4-openssl-dev but 7.68.0-1ubuntu2.13 is to be installed
      libcurl4-openssl-dev : Conflicts: libcurl4-gnutls-dev but 7.68.0-1ubuntu2.13 is to be installed
      libx11-dev : Depends: libx11-6 (= 2:1.6.9-2ubuntu1.2) but 2:1.6.9-2ubuntu1.3 is installed
      The following actions will resolve these dependencies:
         Keep the following packages at their current version:
      1.   default-libmysqlclient-dev [Not Installed]
      2.   freeglut3-dev [Not Installed]
      3.   libcairo2-dev [Not Installed]
      4.   libcurl4-gnutls-dev [Not Installed]
      5.   libegl-dev [Not Installed]
      6.   libfltk1.3-dev [Not Installed]
      7.   libgazebo11-dev [Not Installed]
      8.   libgdal-dev [Not Installed]
      9.   libgdk-pixbuf2.0-dev [Not Installed]
      10.  libgl-dev [Not Installed]
      11.  libgl1-mesa-dev [Not Installed]
      12.  libgles-dev [Not Installed]
      13.  libglew-dev [Not Installed]
      14.  libglu1-mesa-dev [Not Installed]
      15.  libglvnd-dev [Not Installed]
      16.  libglx-dev [Not Installed]
      17.  libgtk2.0-dev [Not Installed]
      18.  libmysqlclient-dev [Not Installed]
      19.  libpango1.0-dev [Not Installed]
      20.  libpcl-dev [Not Installed]
      21.  libpoco-dev [Not Installed]
      22.  libqt5opengl5-dev [Not Installed]
      23.  libqt5webkit5-dev [Not Installed]
      24.  libsimbody-dev [Not Installed]
      25.  libvtk7-dev [Not Installed]
      26.  libvtk7-qt-dev [Not Installed]
      27.  libx11-dev [Not Installed]
      28.  libxcomposite-dev [Not Installed]
      29.  libxcursor-dev [Not Installed]
      30.  libxdamage-dev [Not Installed]
      31.  libxext-dev [Not Installed]
      32.  libxfixes-dev [Not Installed]
      33.  libxft-dev [Not Installed]
      34.  libxi-dev [Not Installed]
      35.  libxinerama-dev [Not Installed]
      36.  libxmu-dev [Not Installed]
      37.  libxmu-headers [Not Installed]
      38.  libxrandr-dev [Not Installed]
      39.  libxrender-dev [Not Installed]
      40.  libxss-dev [Not Installed]
      41.  libxt-dev [Not Installed]
      42.  qtbase5-dev [Not Installed]
      43.  qtdeclarative5-dev [Not Installed]
      44.  qttools5-dev [Not Installed]
      45.  qttools5-private-dev [Not Installed]
      46.  ros-noetic-camera-info-manager [Not Installed]
      47.  ros-noetic-class-loader [Not Installed]
      48.  ros-noetic-common-tutorials [Not Installed]
      49.  ros-noetic-compressed-depth-image-transport [Not Installed]
      50.  ros-noetic-compressed-image-transport [Not Installed]
      51.  ros-noetic-control-toolbox [Not Installed]
      52.  ros-noetic-controller-manager [Not Installed]
      53.  ros-noetic-controller-manager-msgs [Not Installed]
      54.  ros-noetic-depth-image-proc [Not Installed]
      55.  ros-noetic-desktop [Not Installed]
      56.  ros-noetic-desktop-full [Not Installed]
      57.  ros-noetic-diagnostic-aggregator [Not Installed]
      58.  ros-noetic-diagnostic-analysis [Not Installed]
      59.  ros-noetic-diagnostic-common-diagnostics [Not Installed]
      60.  ros-noetic-diagnostics [Not Installed]
      61.  ros-noetic-diff-drive-controller [Not Installed]
      62.  ros-noetic-dynamic-reconfigure [Not Installed]
      63.  ros-noetic-executive-smach [Not Installed]
      64.  ros-noetic-filters [Not Installed]
      65.  ros-noetic-gazebo-dev [Not Installed]
      66.  ros-noetic-gazebo-plugins [Not Installed]
      67.  ros-noetic-gazebo-ros [Not Installed]
      68.  ros-noetic-gazebo-ros-control [Not Installed]
      69.  ros-noetic-gazebo-ros-pkgs [Not Installed]
      70.  ros-noetic-geometry [Not Installed]
      71.  ros-noetic-geometry-tutorials [Not Installed]
      72.  ros-noetic-image-common [Not Installed]
      73.  ros-noetic-image-pipeline [Not Installed]
      74.  ros-noetic-image-proc [Not Installed]
      75.  ros-noetic-image-publisher [Not Installed]
      76.  ros-noetic-image-rotate [Not Installed]
      77.  ros-noetic-image-transport [Not Installed]
      78.  ros-noetic-image-transport-plugins [Not Installed]
      79.  ros-noetic-image-view [Not Installed]
      80.  ros-noetic-interactive-marker-tutorials [Not Installed]
      81.  ros-noetic-joint-limits-interface [Not Installed]
      82.  ros-noetic-kdl-parser [Not Installed]
      83.  ros-noetic-laser-assembler [Not Installed]
      84.  ros-noetic-laser-filters [Not Installed]
      85.  ros-noetic-laser-geometry [Not Installed]
      86.  ros-noetic-laser-pipeline [Not Installed]
      87.  ros-noetic-librviz-tutorial [Not Installed]
      88.  ros-noetic-nodelet [Not Installed]
      89.  ros-noetic-nodelet-core [Not Installed]
      90.  ros-noetic-nodelet-topic-tools [Not Installed]
      91.  ros-noetic-nodelet-tutorial-math [Not Installed]
      92.  ros-noetic-pcl-conversions [Not Installed]
      93.  ros-noetic-pcl-ros [Not Installed]
      94.  ros-noetic-perception [Not Installed]
      95.  ros-noetic-perception-pcl [Not Installed]
      96.  ros-noetic-pluginlib [Not Installed]
      97.  ros-noetic-pluginlib-tutorials [Not Installed]
      98.  ros-noetic-polled-camera [Not Installed]
      99.  ros-noetic-qt-gui-cpp [Not Installed]
      100. ros-noetic-robot [Not Installed]
      101. ros-noetic-robot-state-publisher [Not Installed]
      102. ros-noetic-ros-base [Not Installed]
      103. ros-noetic-ros-comm [Not Installed]
      104. ros-noetic-ros-core [Not Installed]
      105. ros-noetic-rosbag [Not Installed]
      106. ros-noetic-rosbag-storage [Not Installed]
      107. ros-noetic-rosmsg [Not Installed]
      108. ros-noetic-rosnode [Not Installed]
      109. ros-noetic-rosservice [Not Installed]
      110. ros-noetic-rostopic [Not Installed]
      111. ros-noetic-roswtf [Not Installed]
      112. ros-noetic-rqt-action [Not Installed]
      113. ros-noetic-rqt-bag [Not Installed]
      114. ros-noetic-rqt-bag-plugins [Not Installed]
      115. ros-noetic-rqt-common-plugins [Not Installed]
      116. ros-noetic-rqt-console [Not Installed]
      117. ros-noetic-rqt-dep [Not Installed]
      118. ros-noetic-rqt-graph [Not Installed]
      119. ros-noetic-rqt-gui-cpp [Not Installed]
      120. ros-noetic-rqt-image-view [Not Installed]
      121. ros-noetic-rqt-launch [Not Installed]
      122. ros-noetic-rqt-logger-level [Not Installed]
      123. ros-noetic-rqt-moveit [Not Installed]
      124. ros-noetic-rqt-msg [Not Installed]
      125. ros-noetic-rqt-nav-view [Not Installed]
      126. ros-noetic-rqt-plot [Not Installed]
      127. ros-noetic-rqt-pose-view [Not Installed]
      128. ros-noetic-rqt-publisher [Not Installed]
      129. ros-noetic-rqt-py-common [Not Installed]
      130. ros-noetic-rqt-reconfigure [Not Installed]
      131. ros-noetic-rqt-robot-dashboard [Not Installed]
      132. ros-noetic-rqt-robot-monitor [Not Installed]
      133. ros-noetic-rqt-robot-plugins [Not Installed]
      134. ros-noetic-rqt-robot-steering [Not Installed]
      135. ros-noetic-rqt-rviz [Not Installed]
      136. ros-noetic-rqt-service-caller [Not Installed]
      137. ros-noetic-rqt-srv [Not Installed]
      138. ros-noetic-rqt-tf-tree [Not Installed]
      139. ros-noetic-rqt-topic [Not Installed]
      140. ros-noetic-rviz [Not Installed]
      141. ros-noetic-rviz-plugin-tutorials [Not Installed]
      142. ros-noetic-rviz-python-tutorial [Not Installed]
      143. ros-noetic-simulators [Not Installed]
      144. ros-noetic-smach-ros [Not Installed]
      145. ros-noetic-stage [Not Installed]
      146. ros-noetic-stage-ros [Not Installed]
      147. ros-noetic-stereo-image-proc [Not Installed]
      148. ros-noetic-tf [Not Installed]
      149. ros-noetic-tf-conversions [Not Installed]
      150. ros-noetic-theora-image-transport [Not Installed]
      151. ros-noetic-transmission-interface [Not Installed]
      152. ros-noetic-turtle-tf [Not Installed]
      153. ros-noetic-urdf [Not Installed]
      154. ros-noetic-urdf-sim-tutorial [Not Installed]
      155. ros-noetic-urdf-tutorial [Not Installed]
      156. ros-noetic-visualization-tutorials [Not Installed]
      157. ros-noetic-viz [Not Installed]
      158. tk-dev [Not Installed]
      159. tk8.6-dev [Not Installed]
        Leave the following dependencies unresolved:
      160. fluid recommends libfltk1.3-dev
      Accept this solution? [Y/n/q/?] y
      No packages will be installed, upgraded, or removed.
      0 packages upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
      Need to get 0 B of archives. After unpacking 0 B will be used.
      Run CMD Task:[sudo aptitude install ros-noetic-desktop-full -y]
      • 字数太多,删除一部分看不懂的:~~**
        [] cmake{a} cmake-data{a} comerr-dev{a} cython3{a} default-libmysqlclient-dev{a} fltk1.3-doc{a} fluid{a} fonts-lato{a} fonts-lyx{a} freeglut3{a} freeglut3-dev{a} gazebo11{a} gazebo11-common{a} gazebo11-plugin-base{a} gdal-data{a} gir1.2-gtk-2.0{a} gir1.2-harfbuzz-0.0{a} google-mock{a} googletest{a} graphviz{a} integration{a} sbcl{a} sdformat9-sdf{a} shiboken2{a} sip-dev{a} tcl{a} tcl-dev{a} tcl-vtk7{a} tcl8.6-dev{a} tk{a} tk-dev{a} tk8.6-dev{a} ttf-dejavu-core{a} unixodbc-dev{a} uuid-dev{a} va-driver-all{a} vdpau-driver-all{a} vtk7{a} x11proto-core-dev{a} x11p[-]Result:success ing 0 B will be used.upgraded.ntu1.3 is installedtalled20.04.3 is installeda-dev{a} xorg-sgml-doctools{a} xtrans-dev{a} zlib1g-dev{a}
      [-]Result:code:2
      [-]Result:code:2
      小鱼小 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @295714153
        @295714153 在 一键安装ROS失败 中说:
        确认了解情况,请输入回车继续安装n
        看提示你并没有按照提示先n后y.
        2957141532 2 条回复 最后回复 回复 引用 0
        • 2957141532
          不忘初心 @小鱼
          确认了解情况,请输入回车继续安装
          先按回车
          1. fluid recommends libfltk1.3-dev
          Accept this solution? [Y/n/q/?] n
          再输入n
          161) fluid recommends libfltk1.3-dev
          再输入y
          没错 啊
          • 2957141532
            不忘初心 @小鱼
            我的电脑,安装时要输入两次n,两次y才能正常安装
            这个会提示两次
            安装到90%左右网速很慢还经常掉线
              小鱼 技术大佬 @295714153
              [1]:更换系统源再继续安装
              [2]:不更换继续安装
              [0]:quit
              请输入[]内的数字以选择:2
              速度慢一定要选国内源,这里提示要换,你没有换哦
                小鱼 技术大佬 @295714153
                @295714153 代码一定要用代码块包裹,不太好看
                不要截图,要复制粘贴,一定要代码块包裹
                用代码块包裹是为了更加美观,不会一个代码很长一段,不易阅读
