    只用激光雷达建图
    Nav2
    nav2 cartographer
    4.7k
    • LorryL
      Lorry
      最后由 Lorry 编辑
      最近搞了一个激光雷达,想尝试一下只用激光雷达建图,使用fishbot的foxy版本,参考Cartographer手持雷达SLAM建图配置指南修改了fishbot_laser_2d.lua配置文件。主要修改了
        tracking_frame = "laser_link",
        published_frame = "laser_link",
      其他内容并没有改变。运行cartographer_pure_laser.launch.py,出现以下错误
      [cartographer_node-1] F1124 16:19:54.841533 47738 lua_parameter_dictionary.cc:410] Check failed: 1 == reference_counts_.count(key) (1 vs. 0) Key 'use_pose_extrapolator' was used the wrong number of times.
      [cartographer_node-1] [FATAL] [1669277994.841823999] [cartographer_ros]: F1124 16:19:54.000000 47738 lua_parameter_dictionary.cc:410] Check failed: 1 == reference_counts_.count(key) (1 vs. 0) Key 'use_pose_extrapolator' was used the wrong number of times.
      [rviz2-3] [INFO] [1669277995.278164232] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-3] [INFO] [1669277995.278315296] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
      [rviz2-3] [INFO] [1669277995.317479061] [rviz2]: Stereo is NOT SUPPORTED
      [cartographer_node-1] *** Check failure stack trace: ***
      [cartographer_node-1]     @     0x7f94f09811c3  google::LogMessage::Fail()
      [cartographer_node-1]     @     0x7f94f098625b  google::LogMessage::SendToLog()
      [cartographer_node-1]     @     0x7f94f0980ebf  google::LogMessage::Flush()
      [occupancy_grid_node-2] [WARN] [1669277995.846680169] [occupancy_grid_node]: submap_slices and last_frame_id is empty
      [cartographer_node-1]     @     0x7f94f09816ef  google::LogMessageFatal::~LogMessageFatal()
      [cartographer_node-1]     @     0x557f8ac7f354  cartographer::common::LuaParameterDictionary::CheckAllKeysWereUsedExactlyOnceAndReset()
      [cartographer_node-1]     @     0x557f8ac7f5e5  cartographer::common::LuaParameterDictionary::~LuaParameterDictionary()
      [cartographer_node-1]     @     0x557f8ac62bff  cartographer_ros::LoadOptions()
      [cartographer_node-1]     @     0x557f8abd8244  main
      [cartographer_node-1]     @     0x7f94efedd083  __libc_start_main
      [cartographer_node-1]     @     0x557f8abdab6e  _start
      [ERROR] [cartographer_node-1]: process has died [pid 47738, exit code -6, cmd '/home/lorry/Code/Ros2/workspace/LearningProject/fishbot/install/cartographer_ros/lib/cartographer_ros/cartographer_node -configuration_directory /home/lorry/Code/Ros2/workspace/LearningProject/fishbot/install/fishbot_cartographer/share/fishbot_cartographer/config -configuration_basename revo_lds.lua --ros-args -r __node:=cartographer_node --params-file /tmp/launch_params_fze1abjy'].
      [occupancy_grid_node-2] [WARN] [1669277996.846672111] [occupancy_grid_node]: submap_slices and last_frame_id is empty
      [occupancy_grid_node-2] [WARN] [1669277997.846730475] [occupancy_grid_node]: submap_slices and last_frame_id is empty
      [occupancy_grid_node-2] [WARN] [1669277998.846736523] [occupancy_grid_node]: submap_slices and last_frame_id is empty
      rviz界面什么也没显示
        小鱼 技术大佬 @Lorry
        @Lorry 在 只用激光雷达建图 中说:
        看起来是cartographer参数配置错误,仔细检查下
        LorryL 1 条回复 最后回复 回复 引用 0
        • LorryL
          Lorry @小鱼
          @小鱼 我看这个帖子,上面还能看到map和base_laser的tf关系。但是这个tf关系是怎么发布出去的?我参考Cartographer手持雷达SLAM建图配置指南,其中的launch文件并不会发布tf的信息
            小鱼 技术大佬 @Lorry
            @Lorry map->laser的信息是carto发布的,carto根据雷达信息计算出来雷达在地图中的姿态,所以前置是不需要发布这个关系的
            • LorryL
              Lorry @小鱼
              @小鱼 我还有个疑惑,配置文件中指定了雷达的frameID,但是并没有指定雷达的话题名称,这样的话建图节点怎么去使用雷达数据?
                小鱼 技术大佬 @Lorry
                @Lorry 订阅的默认话题'scan'具体可以见cartograpgher_ros代码cartographer_ros/include/cartographer_ros/node_constants.h文件26行,如果想改可以用ros2的话题重映射即可
                 * Copyright 2016 The Cartographer Authors
                 * Licensed under the Apache License, Version 2.0 (the "License");
                 * you may not use this file except in compliance with the License.
                 * You may obtain a copy of the License at
                 *      http://www.apache.org/licenses/LICENSE-2.0
                 * Unless required by applicable law or agreed to in writing, software
                 * distributed under the License is distributed on an "AS IS" BASIS,
                 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
                 * See the License for the specific language governing permissions and
                 * limitations under the License.
                #ifndef CARTOGRAPHER_ROS_CARTOGRAPHER_ROS_NODE_CONSTANTS_H
                #define CARTOGRAPHER_ROS_CARTOGRAPHER_ROS_NODE_CONSTANTS_H
                #include <string>
                #include <vector>
                namespace cartographer_ros {
                // Default topic names; expected to be remapped as needed.
                constexpr char kLaserScanTopic[] = "scan";
                constexpr char kMultiEchoLaserScanTopic[] = "echoes";
                constexpr char kPointCloud2Topic[] = "points2";
                constexpr char kImuTopic[] = "imu";
                constexpr char kOdometryTopic[] = "odom";
                constexpr char kNavSatFixTopic[] = "fix";
                constexpr char kLandmarkTopic[] = "landmark";
                constexpr char kFinishTrajectoryServiceName[] = "finish_trajectory";
                constexpr char kOccupancyGridTopic[] = "map";
                constexpr char kScanMatchedPointCloudTopic[] = "scan_matched_points2";
                constexpr char kSubmapListTopic[] = "submap_list";
                constexpr char kTrackedPoseTopic[] = "tracked_pose";
                constexpr char kSubmapQueryServiceName[] = "submap_query";
                constexpr char kTrajectoryQueryServiceName[] = "trajectory_query";
                constexpr char kStartTrajectoryServiceName[] = "start_trajectory";
                constexpr char kWriteStateServiceName[] = "write_state";
                constexpr char kGetTrajectoryStatesServiceName[] = "get_trajectory_states";
                constexpr char kReadMetricsServiceName[] = "read_metrics";
                constexpr char kTrajectoryNodeListTopic[] = "trajectory_node_list";
                constexpr char kLandmarkPosesListTopic[] = "landmark_poses_list";
                constexpr char kConstraintListTopic[] = "constraint_list";
                constexpr double kConstraintPublishPeriodSec = 0.5;
                constexpr double kTopicMismatchCheckDelaySec = 3.0;
                constexpr int kInfiniteSubscriberQueueSize = 0;
                constexpr int kLatestOnlyPublisherQueueSize = 1;
                // For multiple topics adds numbers to the topic name and returns the list.
                std::vector<std::string> ComputeRepeatedTopicNames(const std::string& topic,
        int num_topics);
                }  // namespace cartographer_ros
                #endif  // CARTOGRAPHER_ROS_CARTOGRAPHER_ROS_NODE_CONSTANTS_H
                • LorryL
                  Lorry @小鱼
                  @小鱼 对nav2太不了解了。
                  现在定位到的问题是carto并没有发布map->laser_frame的tf变换关系。具体报错是:
                  [occupancy_grid_node-3] [WARN] [1669281762.444819311] [occupancy_grid_node]: submap_slices and last_frame_id is empty
                  [rviz2-4] [INFO] [1669281762.513897803] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1669281762.011 for reason 'Unknown'
                  我再查查解决办法,不行的话就先停下来把nav2看完
                    小鱼 技术大佬 @Lorry
                    @Lorry 注意下use_sim_time,仿真时间和实际时间的区别
                    • LorryL
                      Lorry @小鱼
                      @小鱼 仿真时间设置的是false,应该不会是它引起的
