    ROS2 humble cartographer建图tf延迟问题
    Nav2
    cartographer ros2 humble小车 tf2
    5
    8
    3.9k
    • 15611557321
      wo冰淇淋
      在把fishbot的仿真参数移植到真车的过程中遇到了这个TF延迟的问题,延迟时间大概是0.2秒左右;use_sim_time已经改为false,TF树是连起来的;
      呈现的现象,在fiex frame为map时,接受不到激光的数据
      17302128491 1 条回复 最后回复 回复 引用 0
      • vico1999V
        vico1999
          如果你安装的是源码版本,你可以尝试以下步骤来解决问题:
          1.检查编译器版本是否与源码版本兼容;
          2.检查系统是否满足源码版本的要求;
          3.检查源码是否有错误;
          4.检查是否有编译依赖库没有安装;
          5.检查是否有编译参数没有正确设置;
          6.尝试重新编译。
          • vico1999V
            vico1999
            (base) vico@wp:~/carto_ws$ colcon build --packages-up-to cartographer_ros
            Starting >>> cartographer
            Starting >>> cartographer_ros_msgs
            --- stderr: cartographer_ros_msgs
            CMake Error at /opt/ros/humble/share/rosidl_adapter/cmake/rosidl_adapt_interfaces.cmake:59 (message):
            execute_process(/home/vico/miniconda3/bin/python3.10 -m rosidl_adapter
            --package-name cartographer_ros_msgs --arguments-file
            /home/vico/carto_ws/build/cartographer_ros_msgs/rosidl_adapter__arguments__cartographer_ros_msgs.json
            --output-dir
            /home/vico/carto_ws/build/cartographer_ros_msgs/rosidl_adapter/cartographer_ros_msgs
            --output-file
            /home/vico/carto_ws/build/cartographer_ros_msgs/rosidl_adapter/cartographer_ros_msgs.idls)
            returned error code 1:
            File "/home/vico/miniconda3/lib/python3.10/runpy.py", line 196, in _run_module_as_main
              return _run_code(code, main_globals, None,
            File "/home/vico/miniconda3/lib/python3.10/runpy.py", line 86, in _run_code
              exec(code, run_globals)
            File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__main__.py", line 19, in <module>
              sys.exit(main())
            File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/main.py", line 53, in main
              abs_idl_file = convert_to_idl(
            File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__init__.py", line 18, in convert_to_idl
              from rosidl_adapter.msg import convert_msg_to_idl
            File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/msg/__init__.py", line 16, in <module>
              from rosidl_adapter.resource import expand_template
            File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 19, in <module>
              import em
            ModuleNotFoundError: No module named 'em'
              /opt/ros/humble/share/rosidl_adapter/cmake/rosidl_adapt_interfaces.cmake:77 (rosidl_adapt_interfaces)
              CMakeLists.txt:15 (rosidl_generate_interfaces)
              -- Configuring incomplete, errors occurred!
              See also "/home/vico/carto_ws/build/cartographer_ros_msgs/CMakeFiles/CMakeOutput.log".
              See also "/home/vico/carto_ws/build/cartographer_ros_msgs/CMakeFiles/CMakeError.log".
              <<< Failed <<< cartographer_ros_msgs: 1.0 sec
              Summary: 1 package finished [1 failed]
              vico@wp:~/carto_ws$
              </code>
              I already tried to install <code>em</code> module with <code>pip3 install em</code> but it didn't work.
              I am using Ubuntu 20.04, ROS2 Humble and Python 3.10
              Any ideas?
              • 15611557321
                wo冰淇淋
                我是二进制安装的
                  小鱼 技术大佬 @vico1999
                  @vico1999 conda退出来
                  • 17302128491
                    吉新宇 @1561155732
                    @1561155732 我也遇到了同样的问题,请问您解决了吗
