一键安装脚本适配 Ubuntu 24.04
希望一键安装脚本能支持 Ubuntu 24.04
@jalenchuh 收到,最近会更新
@jalenchuh 已经支持,目前仅有rolling版本
![24.04,MAC Parallels](
@2412936782 我抽空再测试一下
@小鱼 我的也一样
@531701079 现在测试也这样吗,你装的哪个版本
@小鱼 是阿!现在也是这样子
@小鱼 ubuntu24.02
@531701079 更换24.04试一试
@小鱼 是24.04版本,
@531701079 提供下全部的日志信息
@小鱼 rolling 版本
@531701079 请提供下 全部的日志信息
@小鱼 欢迎使用一键安装ROS和ROS2,支持树莓派Jetson,本工具由作者小鱼提供
小鱼:检测当前系统ubuntu24.04:noble 支持一键安装ROS
[1]:更换系统源再继续安装
[2]:不更换继续安装
请输入[]内的数字以选择:2
[-]Result:success -upgradable’ 来查看它们。eleaseeRun CMD Task:[sudo apt search curl ]
[/]libcurl3t64-gnutls/noble-updates,noble-security,now 8.5.0-2ubuntu10.1 arm64 [[/]libcurl4t64/noble-updates,noble-security,now 8.5.0-2ubuntu10.1 arm64 [已安装[/] Rust bindings to libcurl for making HTTP requests - feature "force-system-l[/] Rust bindings to libcurl for making HTTP requests - feature "ssl" and 1 mor[] Backend for an HTTP transport in libgit2 powered by libcurl - Rust source c[|] Wrapper around libcurl, it provides a fixed CMake module and an ExternalPro[] This package retrieves data from url-format files such as http://, ftp://, [-]Result:success 3 arm64dock app44Run CMD Task:[sudo apt install curl -y]
[]升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 5 个软件包未被[-]Result:successRun CMD Task:[sudo apt search gnupg2 ]
[-]Result:success ent (dummy transitional package)Run CMD Task:[sudo apt install gnupg2 -y]
[]升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 5 个软件包未被[-]Result:successRun CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo apt-key add -]
[-]Result:successRun CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/ros.gpg --import]
[-]Result:successRun CMD Task:[sudo chmod 644 /etc/apt/trusted.gpg.d/ros.gpg]
[-]Result:success根据您的系统,为您推荐安装源为['http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/']
[-]Result:success创建文件:/etc/apt/sources.list.d/ros-fish.list
[-]Result:code:100 /ros2/ubuntu noble Releaseeaseeapt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu noble Release” 没有 Release 文件。\n']
[-]Result:success sd3 arm64rm64换源后更新失败,第二次开始切换源,尝试更换ROS2源为华为源!
[-]Result:code:100 buntu noble Releasey InReleaseeapt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “https://repo.huaweicloud.com/ros2/ubuntu noble Release” 没有 Release 文件。\n']
[-]Result:success sd3 arm64rm64换源后更新失败,第三次开始切换源,尝试使用https-ROS官方源~!
[] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in th[-]Result:success -upgradable’ 来查看它们。Run CMD Task:[sudo apt search ros-base ]
[|] Node that enables connected ROS-based devices or robots to exchange ROS mes[] A package which extends 'ros_core' and includes other basic functionalities[-]Result:success换源后更新失败,第四次开始切换源,尝试更换ROS源为http-ROS官方源!
[-]Result:success -upgradable’ 来查看它们。eleaseeRun CMD Task:[sudo apt search ros-base ]
[|] Node that enables connected ROS-based devices or robots to exchange ROS mes[] A package which extends 'ros_core' and includes other basic functionalities[-]Result:successRun CMD Task:[sudo apt update]
[|] Node that enables connected ROS-based devices or robots to exchange ROS mes[] A package which extends 'ros_core' and includes other basic functionalities[-]Result:success -
@小鱼 请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
[1]:rolling(ROS2)桌面版
[2]:rolling(ROS2)基础版(小)
请输入[]内的数字以选择:1
[-]Result:success r Debian/Ubuntument files)onRun CMD Task:[sudo apt install aptitude -y]
[-]Result:success 卸载 0 个软件包,有 5 个软件包未被升级。Run CMD Task:[sudo apt search aptitude ]
[-]Result:success 卸载 0 个软件包,有 5 个软件包未被升级。Run CMD Task:[sudo apt install ros-rolling-desktop -y]
正在分析软件包的依赖关系树... 完成
下列信息可能会对解决问题有所帮助:下列软件包有未满足的依赖关系:
libgbm-dev : 依赖: libgbm1 (= 24.0.5-1ubuntu1) 但是 1:23.0.5-0ubuntu1~panfork~git221210.120202c6757~noble6 正要被安装
[|] libgbm-dev : 依赖: libgbm1 (= 24.0.5-1ubuntu1) 但是 1:23.0.5-0ubuntu1~panfork~git221210.120202[-]Result:code:100============================================================
确认了解情况,请输入回车继续安装 -
@小鱼 需要获取 266 MB 的存档。解包后将要使用 1324 MB。
下列软件包存在未满足的依赖关系:
下列动作将解决这些依赖关系:保持 下列软件包于其当前版本:
ros-rolling-desktop [未安装的]
是否接受该解决方案?[Y/n/q/?]
[-]Result:code:2欢迎加入机器人学习交流QQ群:438144612(入群口令:一键安装)
如在使用过程中遇到问题,请打开:https://fishros.org.cn/forum 进行反馈 -
确认了解情况,请输入回车继续安装注意这个提示
