    一键安装脚本适配 Ubuntu 24.04
    一键安装 ros2 ubuntu24.04
    5
    31
    6.1k
    • 5
      Wise @小鱼
      @小鱼 ubuntu24.02
        小鱼 技术大佬 @531701079
        @531701079 更换24.04试一试
        5 2 条回复 最后回复 回复 引用 0
        • 5
          Wise @小鱼
          @小鱼 是24.04版本,
            小鱼 技术大佬 @531701079
            @531701079 提供下全部的日志信息
            5 1 条回复 最后回复 回复 引用 0
            • 5
              Wise @小鱼
              @小鱼 rolling 版本
                小鱼 技术大佬 @531701079
                @531701079 请提供下 全部的日志信息
                5 3 条回复 最后回复 回复 引用 0
                • 5
                  Wise @小鱼
                  @小鱼 欢迎使用一键安装ROS和ROS2,支持树莓派Jetson,本工具由作者小鱼提供
                  小鱼:检测当前系统ubuntu24.04:noble 支持一键安装ROS
                  [1]:更换系统源再继续安装
                  [2]:不更换继续安装
                  请输入[]内的数字以选择:2
                  [-]Result:success -upgradable’ 来查看它们。eleasee
                  [/]libcurl3t64-gnutls/noble-updates,noble-security,now 8.5.0-2ubuntu10.1 arm64 [[/]libcurl4t64/noble-updates,noble-security,now 8.5.0-2ubuntu10.1 arm64 [已安装[/] Rust bindings to libcurl for making HTTP requests - feature "force-system-l[/] Rust bindings to libcurl for making HTTP requests - feature "ssl" and 1 mor[] Backend for an HTTP transport in libgit2 powered by libcurl - Rust source c[|] Wrapper around libcurl, it provides a fixed CMake module and an ExternalPro[] This package retrieves data from url-format files such as http://, ftp://, [-]Result:success 3 arm64dock app44
                  []升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 5 个软件包未被[-]Result:success
                  [-]Result:success ent (dummy transitional package)
                  [-]Result:success
                  Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/ros.gpg --import]
                  [-]Result:success
                  [-]Result:success
                  [-]Result:success
                  [-]Result:success
                  [-]Result:code:100 /ros2/ubuntu noble Releaseeasee
                  apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu noble Release” 没有 Release 文件。\n']
                  [-]Result:success sd3 arm64rm64
                  [-]Result:success
                  [-]Result:code:100 buntu noble Releasey InReleasee
                  apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “https://repo.huaweicloud.com/ros2/ubuntu noble Release” 没有 Release 文件。\n']
                  [-]Result:success
                  [] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in th[-]Result:success -upgradable’ 来查看它们。
                  [|] Node that enables connected ROS-based devices or robots to exchange ROS mes[] A package which extends 'ros_core' and includes other basic functionalities[-]Result:success
                  [-]Result:success
                  • 5
                    Wise @小鱼
                    @小鱼 请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
                    [1]:rolling(ROS2)桌面版
                    [2]:rolling(ROS2)基础版(小)
                    请输入[]内的数字以选择:1
                    [-]Result:success r Debian/Ubuntument files)on
                    [-]Result:success 卸载 0 个软件包,有 5 个软件包未被升级。
                    Run CMD Task:[sudo apt install ros-rolling-desktop -y]
                    正在分析软件包的依赖关系树... 完成
                    下列信息可能会对解决问题有所帮助:
                    下列软件包有未满足的依赖关系:
                    libgbm-dev : 依赖: libgbm1 (= 24.0.5-1ubuntu1) 但是 1:23.0.5-0ubuntu1~panfork~git221210.120202c6757~noble6 正要被安装
                    [|] libgbm-dev : 依赖: libgbm1 (= 24.0.5-1ubuntu1) 但是 1:23.0.5-0ubuntu1~panfork~git221210.120202[-]Result:code:100
                    确认了解情况,请输入回车继续安装
                    • 5
                      Wise @小鱼
                      @小鱼 需要获取 266 MB 的存档。解包后将要使用 1324 MB。
                      下列软件包存在未满足的依赖关系:
                      下列动作将解决这些依赖关系:
                       保持 下列软件包于其当前版本:
                      1. ros-rolling-desktop [未安装的]
                      是否接受该解决方案?[Y/n/q/?]
                      • 5
                        Wise @小鱼
                        [-]Result:code:2
                          小鱼 技术大佬 @531701079
                            小鱼 技术大佬 @531701079
                            确认了解情况,请输入回车继续安装
                            注意这个提示
                            5 小鱼小 2 条回复 最后回复 回复 引用 0
                            • 5
                              Wise @小鱼
                              @小鱼 回车了,按照引导,安装还是失败
                                小鱼 技术大佬 @531701079
                                @531701079 那你手动运行命令了吗
                                测试顺序是:
                                y
                                n y
                                n n y
                                n n n y
                                n n n n y
                                .............. y
                                • 5
                                  Wise @小鱼
                                  @小鱼 0 个软件包被升级,新安装 605 个,0 个将被删除, 同时 5 个将不升级。
                                  下列软件包存在未满足的依赖关系:
                                  下列动作将解决这些依赖关系:
                                   保持 下列软件包于其当前版本:
                                  是否接受该解决方案?[Y/n/q/?] Y
                                  将不会安装,升级或者删除任何软件包。
                                  0 个软件包被升级,新安装 0 个,0 个将被删除, 同时 5 个将不升级。
                                  需要获取 0 B 的存档。解包后将要使用 0 B。
                                    小鱼 技术大佬 @531701079
                                    @531701079 这里应该输入 n 拒绝该方案,然后会提供下一个方案给你
                                    • 5
                                      Wise @小鱼
                                      我正在NY中测试中
                                      • 5
                                        Wise @小鱼
                                        @小鱼 ny后成功了
                                        • 5
                                          Wise @小鱼
                                          @小鱼 感谢小鱼大佬,希望你电商有更多产品
                                            小鱼 技术大佬 @小鱼
                                            @小鱼 在 一键安装脚本适配 Ubuntu 24.04 中说:
                                            其实一键安装中已经有提示了
