    一键安装脚本适配 Ubuntu 24.04
    一键安装 ros2 ubuntu24.04
    5
    31
    26.6k
    • 5
      Wise @小鱼
      @小鱼 欢迎使用一键安装ROS和ROS2,支持树莓派Jetson,本工具由作者小鱼提供
      小鱼:检测当前系统ubuntu24.04:noble 支持一键安装ROS
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      请输入[]内的数字以选择:2
      [-]Result:success -upgradable’ 来查看它们。eleasee
      [/]libcurl3t64-gnutls/noble-updates,noble-security,now 8.5.0-2ubuntu10.1 arm64 [[/]libcurl4t64/noble-updates,noble-security,now 8.5.0-2ubuntu10.1 arm64 [已安装[/] Rust bindings to libcurl for making HTTP requests - feature "force-system-l[/] Rust bindings to libcurl for making HTTP requests - feature "ssl" and 1 mor[] Backend for an HTTP transport in libgit2 powered by libcurl - Rust source c[|] Wrapper around libcurl, it provides a fixed CMake module and an ExternalPro[] This package retrieves data from url-format files such as http://, ftp://, [-]Result:success 3 arm64dock app44
      []升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 5 个软件包未被[-]Result:success
      [-]Result:success ent (dummy transitional package)
      [-]Result:success
      Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/ros.gpg --import]
      [-]Result:success
      [-]Result:success
      [-]Result:success
      [-]Result:success
      [-]Result:code:100 /ros2/ubuntu noble Releaseeasee
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu noble Release” 没有 Release 文件。\n']
      [-]Result:success sd3 arm64rm64
      [-]Result:success
      [-]Result:code:100 buntu noble Releasey InReleasee
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “https://repo.huaweicloud.com/ros2/ubuntu noble Release” 没有 Release 文件。\n']
      [-]Result:success
      [] Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in th[-]Result:success -upgradable’ 来查看它们。
      [|] Node that enables connected ROS-based devices or robots to exchange ROS mes[] A package which extends 'ros_core' and includes other basic functionalities[-]Result:success
      [-]Result:success
      • 5
        Wise @小鱼
        @小鱼 请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
        [1]:rolling(ROS2)桌面版
        [2]:rolling(ROS2)基础版(小)
        请输入[]内的数字以选择:1
        [-]Result:success r Debian/Ubuntument files)on
        [-]Result:success 卸载 0 个软件包,有 5 个软件包未被升级。
        Run CMD Task:[sudo apt install ros-rolling-desktop -y]
        正在分析软件包的依赖关系树... 完成
        下列信息可能会对解决问题有所帮助:
        下列软件包有未满足的依赖关系:
        libgbm-dev : 依赖: libgbm1 (= 24.0.5-1ubuntu1) 但是 1:23.0.5-0ubuntu1~panfork~git221210.120202c6757~noble6 正要被安装
        [|] libgbm-dev : 依赖: libgbm1 (= 24.0.5-1ubuntu1) 但是 1:23.0.5-0ubuntu1~panfork~git221210.120202[-]Result:code:100
        确认了解情况,请输入回车继续安装
        • 5
          Wise @小鱼
          @小鱼 需要获取 266 MB 的存档。解包后将要使用 1324 MB。
          下列软件包存在未满足的依赖关系:
          下列动作将解决这些依赖关系:
           保持 下列软件包于其当前版本:
          1. ros-rolling-desktop [未安装的]
          是否接受该解决方案?[Y/n/q/?]
          • 5
            Wise @小鱼
            [-]Result:code:2
              小鱼 技术大佬 @531701079
                小鱼 技术大佬 @531701079
                确认了解情况,请输入回车继续安装
                注意这个提示
                5 小鱼小 2 条回复 最后回复 回复 引用 0
                • 5
                  Wise @小鱼
                  @小鱼 回车了,按照引导,安装还是失败
                    小鱼 技术大佬 @531701079
                    @531701079 那你手动运行命令了吗
                    测试顺序是:
                    y
                    n y
                    n n y
                    n n n y
                    n n n n y
                    .............. y
                    5 2 条回复 最后回复 回复 引用 0
                    • 5
                      Wise @小鱼
                      @小鱼 0 个软件包被升级,新安装 605 个,0 个将被删除, 同时 5 个将不升级。
                      下列软件包存在未满足的依赖关系:
                      下列动作将解决这些依赖关系:
                       保持 下列软件包于其当前版本:
                      是否接受该解决方案?[Y/n/q/?] Y
                      将不会安装,升级或者删除任何软件包。
                      0 个软件包被升级,新安装 0 个,0 个将被删除, 同时 5 个将不升级。
                      需要获取 0 B 的存档。解包后将要使用 0 B。
                        小鱼 技术大佬 @531701079
                        @531701079 这里应该输入 n 拒绝该方案,然后会提供下一个方案给你
                        • 5
                          Wise @小鱼
                          我正在NY中测试中
                          • 5
                            Wise @小鱼
                            @小鱼 ny后成功了
                            • 5
                              Wise @小鱼
                              @小鱼 感谢小鱼大佬,希望你电商有更多产品
                                小鱼 技术大佬 @小鱼
                                @小鱼 在 一键安装脚本适配 Ubuntu 24.04 中说:
                                其实一键安装中已经有提示了
                                5 1 条回复 最后回复 回复 引用 0
                                • 5
                                  Wise @小鱼
                                  中已经有提示了
                                  已经把ros2 rolling安好了
                                  • 10848863791
                                    心在远方何惧孤独
                                    啥时候ubuntu24.04支持ros1啊
                                      小鱼 技术大佬 @1084886379
                                      @1084886379 ros1注定要退出舞台了
                                      • 小伊小 小伊 将这个主题转为问答主题,在
                                      • 小伊小 小伊 将这个主题标记为已解决,在
