    服务之RCLPY实现遇到问题:waiting for service to become available...
    动手学ros2 服务之rclpy实现
    9.8k
      小鱼 技术大佬 @1785360876
      @1785360876 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
      你要使用命令请求服务来确认服务是否正常,另外应该给出代码和相关日志
        1785360876 @小鱼
        @小鱼 抱歉,服务请求显示waiting for service to become available..
        service_server_02.py的代码完全参照您的《动手学ros2》中代码(如下),本人刚入门,尚不清楚是否需要其他信息来协助找出问题
        import rclpy
        from rclpy.node import Node
        from example_interfaces.srv import AddTwoInts
        class ServiceServer02(Node):
        def init(self, name):
        super().init(name)
        self.get_logger().info("节点已启动:%s!" % name)
        self.add_ints_server = self.create_service(
        AddTwoInts, "add_two_ints_srv", self.handle_add_two_ints
        self.get_logger().info("初始化已完成")
        def handle_add_two_ints(self, request, response):
            self.get_logger().info(f"收到请求,计算{request.a} + {request.b}")
            response.sum = request.a + request.b
            return response
        def main(args=None):
        rclpy.init(args=args) # 初始化rclpy
        node = ServiceServer02("service_server_02") # 新建一个节点
        rclpy.spin(node) # 保持节点运行,检测是否收到退出指令(Ctrl+C)
        rclpy.shutdown() # 关闭rclpy
          小鱼 技术大佬 @1785360876
          @1785360876 请阅读提问前必看,并修改格式:1.不要截图 2.代码用代码块包裹 如果不知道怎么做,可以看编辑框右边的帮助:https://commonmark.org/help/
            1785360876 @小鱼
            在终端中启节点
            ~/d2lros2/chapt3/chapt3_ws$ ros2 run example_service_rclpy service_server_02
            [INFO] [1721376210.440943060] [service_server_02]: 节点已启动:service_server_02
            在另一终端请求服务始终显示“waiting for service to become available...”
            og@GalaxyOg:~/d2lros2/chapt3/chapt3_ws$ ros2 service call /add_two_ints_srv example_interfaces/srv/AddTwoInts "{a: 5,b: 10}"
            已使用ros2 node list 和ros2 service list查看结果如下
            og@GalaxyOg:~$ ros2 node list
            /service_server_02
            og@GalaxyOg:~$ ros2 service list
            /add_two_ints_srv
            /service_server_02/describe_parameters
            /service_server_02/get_parameter_types
            /service_server_02/get_parameters
            /service_server_02/list_parameters
            /service_server_02/set_parameters
            /service_server_02/set_parameters_atomically
            service_server_02.py的内容如下
            import rclpy
                def __init__(self, name):
                    super().__init__(name)
                    return response
              小鱼 技术大佬 @1785360876
              @1785360876 看起来没问题:
              尝试重启下daemon
              ros2 daemon stop
              ros2 daemon start
              然后再用:
              试试
                1785360876 @小鱼
                og@GalaxyOg:~/d2lros2/chapt3/chapt3_ws$ ros2 daemon stop
                The daemon is not running
                og@GalaxyOg:~/d2lros2/chapt3/chapt3_ws$ ros2 daemon start
                The daemon has been started
                再次启动节点后命令行请求服务任然显示“waiting for service to become available...”
                  小鱼 技术大佬 @1785360876
                  @1785360876 你运行自带的服务试试
                  ros2 run examples_rclpy_minimal_service service
                  然后尝试请求
                    1785360876 @小鱼
                    自带的服务在测试中正常运行,今日启动自己写的节点后发现服务中没有“/add_two_ints_srv”服务(前日测试中该服务在service list中),测试结果如下
                    /service_server_02
                    请问如何解决“/add_two_ints_srv”服务为正常启动的问题呢?
                    节点启动终端如下
                    og@GalaxyOg:~/d2lros2/chapt3/chapt3_ws$ ros2 run example_service_rclpy service_server_02
                    [INFO] [1721546960.212194499] [service_server_02]: 节点已启动:service_server_02
                      小鱼 技术大佬 @1785360876
                      @1785360876 打开install目录下对应的功能包,找找service_server_02对应的py文件,确认运行的文件和src中的一致。
                        1785360876 @小鱼
                        @小鱼 问题已解决,非常感谢!
                        经检查是由于install下对应python文件与src下文件不一致导致(install文件夹下保存着我此前由于拼写错误而误创建的service_sever_02.py,随后我删除了该文件并创建了正确的service_server_02.py并在setupp.py文件中手动进行了更改)。
                        我在尝试解决问题的过程中曾试过只删除build文件夹后进行整改工作空间的build,但并未检查install文件夹,今后若遇到类似的问题是否能删除install与build文件夹,再重新build整个工作空间呢?
                          小鱼 技术大佬 @1785360876
                          @1785360876 最好可以删掉install和build重新构建,防止这个问题
                          • 小鱼小 小鱼 将这个主题标记为已解决,在
                          • J Jason_Duan 在 中 引用了 这个主题
