    服务之RCLPY实现遇到问题:waiting for service to become available...
    动手学ros2 服务之rclpy实现
    9.2k
      1785360876 @小鱼
      @小鱼 抱歉,服务请求显示waiting for service to become available..
      service_server_02.py的代码完全参照您的《动手学ros2》中代码(如下),本人刚入门,尚不清楚是否需要其他信息来协助找出问题
      import rclpy
      from rclpy.node import Node
      from example_interfaces.srv import AddTwoInts
      class ServiceServer02(Node):
      def init(self, name):
      super().init(name)
      self.get_logger().info("节点已启动:%s!" % name)
      self.add_ints_server = self.create_service(
      AddTwoInts, "add_two_ints_srv", self.handle_add_two_ints
      self.get_logger().info("初始化已完成")
      def handle_add_two_ints(self, request, response):
          self.get_logger().info(f"收到请求,计算{request.a} + {request.b}")
          response.sum = request.a + request.b
          return response
      def main(args=None):
      rclpy.init(args=args) # 初始化rclpy
      node = ServiceServer02("service_server_02") # 新建一个节点
      rclpy.spin(node) # 保持节点运行,检测是否收到退出指令(Ctrl+C)
      rclpy.shutdown() # 关闭rclpy
        小鱼 技术大佬 @1785360876
        @1785360876 请阅读提问前必看,并修改格式:1.不要截图 2.代码用代码块包裹 如果不知道怎么做,可以看编辑框右边的帮助:https://commonmark.org/help/
          1785360876 @小鱼
          在终端中启节点
          ~/d2lros2/chapt3/chapt3_ws$ ros2 run example_service_rclpy service_server_02
          [INFO] [1721376210.440943060] [service_server_02]: 节点已启动:service_server_02
          在另一终端请求服务始终显示“waiting for service to become available...”
          og@GalaxyOg:~/d2lros2/chapt3/chapt3_ws$ ros2 service call /add_two_ints_srv example_interfaces/srv/AddTwoInts "{a: 5,b: 10}"
          已使用ros2 node list 和ros2 service list查看结果如下
          og@GalaxyOg:~$ ros2 node list
          /service_server_02
          og@GalaxyOg:~$ ros2 service list
          /add_two_ints_srv
          /service_server_02/describe_parameters
          /service_server_02/get_parameter_types
          /service_server_02/get_parameters
          /service_server_02/list_parameters
          /service_server_02/set_parameters
          /service_server_02/set_parameters_atomically
          service_server_02.py的内容如下
          import rclpy
              def __init__(self, name):
                  super().__init__(name)
                  return response
            小鱼 技术大佬 @1785360876
            @1785360876 看起来没问题:
            尝试重启下daemon
            ros2 daemon stop
            ros2 daemon start
            然后再用:
            试试
              1785360876 @小鱼
              og@GalaxyOg:~/d2lros2/chapt3/chapt3_ws$ ros2 daemon stop
              The daemon is not running
              og@GalaxyOg:~/d2lros2/chapt3/chapt3_ws$ ros2 daemon start
              The daemon has been started
              再次启动节点后命令行请求服务任然显示“waiting for service to become available...”
                小鱼 技术大佬 @1785360876
                @1785360876 你运行自带的服务试试
                ros2 run examples_rclpy_minimal_service service
                然后尝试请求
                  1785360876 @小鱼
                  自带的服务在测试中正常运行,今日启动自己写的节点后发现服务中没有“/add_two_ints_srv”服务(前日测试中该服务在service list中),测试结果如下
                  /service_server_02
                  请问如何解决“/add_two_ints_srv”服务为正常启动的问题呢?
                  节点启动终端如下
                  og@GalaxyOg:~/d2lros2/chapt3/chapt3_ws$ ros2 run example_service_rclpy service_server_02
                  [INFO] [1721546960.212194499] [service_server_02]: 节点已启动:service_server_02
                    小鱼 技术大佬 @1785360876
                    @1785360876 打开install目录下对应的功能包,找找service_server_02对应的py文件,确认运行的文件和src中的一致。
                      1785360876 @小鱼
                      @小鱼 问题已解决,非常感谢!
                      经检查是由于install下对应python文件与src下文件不一致导致(install文件夹下保存着我此前由于拼写错误而误创建的service_sever_02.py,随后我删除了该文件并创建了正确的service_server_02.py并在setupp.py文件中手动进行了更改)。
                      我在尝试解决问题的过程中曾试过只删除build文件夹后进行整改工作空间的build,但并未检查install文件夹,今后若遇到类似的问题是否能删除install与build文件夹,再重新build整个工作空间呢?
                        小鱼 技术大佬 @1785360876
                        @1785360876 最好可以删掉install和build重新构建,防止这个问题
                        • 小鱼小 小鱼 将这个主题标记为已解决,在
                        • J Jason_Duan 在 中 引用了 这个主题
