动手学ros2第5章进阶篇-控制OLED-自定义消息接口
python3 --version
显示的python3.10刚刚我又卸载了一遍,卸载成功了,之前还剩个
python3.6-minimal没卸载掉,显示的可执行文件是/usr/bin/python3.6m, 疑惑我半天,卸载的时候没用通配符,我还以为系统自带的卸载不了。终于可以正常编译了跑起来了
,非常感谢大佬的支持
编译一直是这个问题,不知道怎么解决 -
@1281857896 我抽空修改下库,ghproxy挂掉了
@小鱼 好嘞,感谢鱼哥
@小鱼 鱼哥这个问题解决了吗 我这里还是这个问题 挂代理也不行
@2049368121 已经解决
@小鱼 正克隆到 '/home/everbright/Ros_Codes/MicroROS_DIY_MSG/.pio/libdeps/featheresp32/micro_ros_platformio/build/dev/src/ament_cmake'...
fatal: 无法访问 'http://github.fishros.org/https://github.com/ament/ament_cmake/':Failed to connect to github.fishros.org port 80: 拒绝连接什么问题 鱼哥
@847718956 你好兄弟,这个问题解决了吗?
X xm1735492561 在 中 引用了 这个主题
Processing my_esp32s3_wroom (platform: espressif32; board: esp32-s3-devkitc-1; framework: arduino)
Verbose mode can be enabled via
-v, --verboseoption
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-s3-devkitc-1.html
PLATFORM: Espressif 32 (6.12.0) > Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:- framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b
- tool-esptoolpy @ 2.40900.250804 (4.9.0)
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Installing importlib-resources with pip at PlatformIO environment
/home/ros2/.platformio/penv/bin/python -m pip install importlib-resources
Requirement already satisfied: importlib-resources in /home/ros2/.platformio/penv/lib/python3.10/site-packages (6.5.2)
/home/ros2/.platformio/penv/bin/python -m pip install pyyaml
Requirement already satisfied: pyyaml in /home/ros2/.platformio/penv/lib/python3.10/site-packages (6.0.3)
/home/ros2/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
Requirement already satisfied: markupsafe==2.0.1 in /home/ros2/.platformio/penv/lib/python3.10/site-packages (2.0.1)
Configuring esp32-s3-devkitc-1 with transport wifi
Downloading micro-ROS dev dependencies
ament_cmake clone failed:
正克隆到 '/home/ros2/my_bot/my_bot_esp32/my_bot_ws/.pio/libdeps/my_esp32s3_wroom/micro_ros_platformio/build/dev/src/ament_cmake'...
fatal: 无法访问 'http://github.fishros.org/https://github.com/ament/ament_cmake/':Could not resolve host: github.fishros.org
小鱼,拉去不到镜像,怎么办
